Question about Sony ACY-BR81/OB
Psp joystick problems
My psp joystick veers to the right. What am I supposed to do?
  • skyynig08 May 17, 2008
    without even touching my joystick my character will begin to walk DOWN and when i try to run UP it gives me a hard time, any solutions?
    Problem Solver:
  • 12 Answers
Have you droped it before it may need a new faceplate i bought a psp that had the same problem and the face plate was loose the spot were the screw went in had broke and the screww could not tighten and the joystick relys on that screw to be tight so it can make contact a new face plate from ebay for 18 dollars fixed it also a joystick can be purchase for 3 dollars if that is the problem.
Posted on Oct 29, 2009
    Problem Solver:
  • 9 Answers
Try powering off the system, then power on while not touching the controls at all. it may be realigning at power up and if it is off center it will think that is the center.
Posted on Jan 30, 2008
2 Suggested Answers
SOURCE: psp joystick
I have the exact same problem, this glitch as I came to call it happens to me often, I found it that after opening a PSP and closing it back up it fixes the problem, although like I said the glitch comes back after a while. I call this a glitch because I repair people's PSP's and found that their PSP's have the same problem.
Posted on May 31, 2008
Power steering electric
If the chair wants to drive left then you have a disengaged left motor clutch lever or a left motor going bad. Then M51 will not give an error code if the clutch is disengaged. If the chair is veering left as you are driving but you are still able to turn to turn right then the motor is not likely to be disengaged but has a brush or gear problem.
It is also possible that the joystick is not working well. The joystick is much less likely to be the problem unless it is damaged somehow.
Sep 02, 2014 | Invacare Pronto M51 Power Wheelchair
My psp joystick is broken. it is stuck down. when i play games, the person is always crouching or going down. and the highlighted section in the menu is always going down. I've looked for solutions on how...
The PSP of my son just so happen to have same problem as yours. Aside from the joystick, the 4 directional button (Up, Down, Left and Right) also controls the directions (hmmm... as the name implies). I was able to correct this by replacing the worn out FLEX PCB at the back of the directional button found just underneath the PSP casing. The trace of the Down Button on the PCB is already shorted to the ground which causes the signal to be always active even it is not pressed.
Oct 26, 2009 | Sony PlayStation Portable (PSP) Console
On take off all aircraft veer to the left and stall in flight
if you use mouse yoke, get a joystick if you have a joystick it may be broken.
Sep 29, 2009 | Microsoft Flight Simulator X for Windows
My joystick is not working normally as it use to be.
I know how to solve this so worry not! here's the solution:
1:your joystick may have a little part that is dismembered so buy a new one
2:ask for a assistant to open your psp to put the joystick properly
3:I have the same problem so here's what I do.
good luck
Jul 24, 2009 | Sony PlayStation Portable (PSP) Console
Joystick problems
The only way this can happen is if you have damaged the joystick function area.You have to change the joystick and put another one.
Jul 22, 2009 | Sony PlayStation Portable (PSP) Console
PSP joystick messed up
Okay This has happen to me and what it is the joystick is off track. I'm not saying you guys are handling your psp roughly but it does happen. You can try to repair the joystick yourself.
But the best bet is to buy a new one. Doesn't cost much and it is not hard to do. I paid $3 for a replacement. Word of advice if you are buying a generic brand you may want to buy at least three of then just in case one or more of them are doa (dead on arrival) you never know. Will save to time in returning and waiting for a replacement.
If you want please ask and I will post a how to for repair of your OEM joystick. This doesn't always work but what the hell it's worth a shot.
Dec 20, 2008 | Sony PlayStation Portable (PSP) Console
Joystick psp prooblem
That it is probably an hardware fault, the joystick switch stay stuck as you are pointing up.
If it happens again get a replacement joystick.
If you are still under guaranty and that happens again, call them and ask a replacement joypad, tell them you get the problem from time to time.
good luck.
Sep 11, 2008 | Sony PlayStation Portable (PSP) Console
Psp joystick
well psp were built to have its own joystick, other joystick are usually generic versions, so the chances of them being faulty for psp are high
Feb 10, 2008 | Sony PlayStation Portable (PSP) Console
Psp joystick
Jan 18, 2008 | Sony ACY-BR81/OB
Good day all
I recently ran into this same problem of a PSP joystick "jumping" or hopping around. Since I'm an electronics engineer I was determined to get to the bottom of this annoying problem, I read all the posts on the site and none helped, but the problem turned out to be much easier fixed than I first anticipated.
First of all I assume that you know how to take the PSP apart and take out the joystick module as well. The Joystick module connects to the PSP mainboard by means of 4 contacts, seperated by a spacer conductor that appears like a rectangular rubber, be careful not to lose this during the process.
Here is why the problem occurs, when you have a faulty joystick module, one or more of those 4 contacts don't connect to the main board anymore, so the when the PSP is trying to measure the resistance to determine the joystick position, it reads a varying value, i.e. the contact is floating.
This happens for mainly 2 reasons, dirt or a faulty module, as stated in the previous posts, the contacts could be dirty, but this can usually easy be seen, and this wasn't the problem in my case, I had a faulty module, but luckily all is not lost.
Here's how to fix a faulty module in most cases. Remove the joystick module from the PSP completely, put that little rectangular rubber on the 4 contacts (clear in my case) aside and keep it safe. There is metal clasp on the bottom of the module, you can simply pop it off with a screwdriver, by slightly bending the clasps on the side and taking it off. Now you should be able to see a VERY SIMPLE mini circuit board with tracks on, on the bottom of the module, you can indeed pop this off too. On this you will see tracks where the joystick sliders move. Put the circuit board aside too. Now look at the now completely open joystick module, you will see the two sliders each having a metal part, each of these metal parts has 2 very small contacts that run on the circuit board tracks that you just removed, most times these small contacts get bent inward and they can't make contact with the circuit board tracks anymore. Just bend them slightly outward again, so that when you put circuit board back, they touch the tracks on the board nicely. Put the circuit board back, it just slips back on, put the metal clasp back, put the rubber back in over 4 contacts on the module and voila, if all goes well you will have a nice working joystick module again. Put it back in the PSP and test it to see if it worked. In my case it worked 100% and saved me a few bucks. Hope this helps everyone. Let me know if it worked.
Oct 16, 2007 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
228 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
