Question about Logitech Internet Chat Consumer Headset
Replacement ear pads
I have searched high and low for replacement ear pads for this thing with no luck. They are oval shaped about 2" diameter at the widest diameter. Found a site that advertized replacement pads, but they were out of stock and could only back-order them.
Anyone know where to find oval foam replacement pads?
Http://headsetpartsunlimited.com/orderinfo.html
Posted on Mar 09, 2008
Tip
Identifying Your Reebok / Robix Studio Cycle
  • 9600
    Black matte finish on 1-piece welded frame. Black crank arms (generally) and dual brake pads.
  • 9800
    Black matte finish on 1-piece welded frame. Black crank arms (generally) and single brake pad.
  • 9900
    Glossy finishes w/angled back legs (stabilizer). Bolt-together frame (assembly required). Rectangle shaped stabilizers.
  • 2000B
    Glossy finish w/angled back legs (stabilizer). Bolt-together frame (assembly required). Oval shaped stabilizers and single brake pad. Silver crank arms and belt driven.
  • 2000C
    Glossy finish w/angled back legs (stabilizer). Bolt-together frame (assembly required). Oval shaped stabilizers and single brake pad. Black crank arms and chain driven.
  • 3000B Robix
    Black glossy finish w/angled back legs (stabilizer). Bolt-together frame (assembly required). Oval shaped stabilizers and frame down tube. Belt driven with single brake pad.
http://www.sportsmith.net/Categories.aspx?did=CEF96124-843A-4128-9B53-8E10980C9920
on Mar 11, 2015 | Exercise & Fitness
Are there replacement ear pads that will fit on my 2005 Sony headphones ?
There are lots of generic (Chinese) replacement ear pads for Sony on ebay or Amazon, you'll just have to take some measurements and try to match what's available. Check the diameter in centimeters, and the shape (round or oval). You may not find a specific listing for MDR-RF960RK but a lot are interchangeable.
Nov 10, 2014 | Sony MDR-RF960RK Consumer Headset
Severe squelch in left ear phone
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a significant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the shape of the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs.
If the foam in the ear cushion has weakened/deteriorated to the point that it no longer has it's original shape, (in particular the lower half of the ear cushion), the size and shape of the air chamber inside of the earcup is directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback.
On my QC-3 headphones, I can cause the feedback squeal in both earcups, with the left earcup being more sensitive to the shape change than the right.
It is probably time to replace the ear cushions. If so, they are available from Bose for $35/pair.
QuietComfort 3 Acoustic Noise Cancelling Headphones Bose Product Support
They are also available aftermarket at Amazon.com for $16.99/pair
Replacement Earpad ear pad Cushions For Bose QuietComfort 3 QC3 Headphones...
or $5.69/pair.
Bluecell Pair of Replacement Earpad Ear Pad Cushion for Bose Quietcomfort...
Aug 29, 2013 | Bose QuietComfort 3 Acoustic Noise...
EAR CUSHION
Sony parts suppliers sell replacement ear pads. Part no 2-320-280-01 about US$16 each (not pair).
Old ear pads slip off - pull gently to stretch the part that sits in the groove of the headphones until one side slides out.
The creative sewer can remanufacture new pads from thin soft leather by following the pattern of the old ones.
No cost fix is to scrape off the remaining peeling urethane leaving the soft fabric backing. Headphones will still work but the soft earpads should absorb high frequencies.
Sep 12, 2012 | Sony MDRXD400 Professional Headphones
Need a gate for oval shaped grill
Lowe's and Home Depot carry generic grill grates in all sizes and shapes. Just make sure you know the diameter of the one you need or take it with you to match it to what's available.
Feb 14, 2011 | Patio Classic 2000 Series Grill
How could I know which sunglass suites me?
Well, here are some advices on how to match your sunglass to your face: 1. Suare face: Most complimentary style of sunglasses for a square face: To minimize the width of the face, it is best to choose sunglasses that add length. This can be best achieved by buying sunglasses that are not as wide as the widest part of your face. It is also a good idea to soften the "squareness" of a face by more fluid, rounded style frames, so as to decrease the perception of a broad jaw line. 2.Oval face-Most complimentary style of sunglasses for an oval shaped face: Generally any type of sunglasses suits an oval face, but just make sure that the size of the frame is proportionate to the face. 3.Round face: Most complimentary style of sunglasses for round shaped face: To sharpen a round face, select frames with straight or angular lines that will help make the face look thinner and longer.
4.Diamond face:Most complimentary style of sunglasses for a diamond shape face: Glasses that are oval, shaped or rimless are very complimentary for this type of face.
5. Rectagle face-Most complimentary style of sunglasses for squar shaped face: To compliment this style of face, it is best to choose sunglasses that will shorten the face and widen the face, both at the same time. The best style of frame to choose is one that is round, or deep to help soften the face.
6.Triangle face-Most complimentary style of sunglasses for a Base-Down Triangle face: To compliment this style of face, it is best to emphasis the top part of your face with strong balancing frames. 7.Inverted triangle-Most complimentary style of sunglasses for an inverted triangle face: Choose a type of frame that balances your face and broadens the lower part of your face. Low temples and rimless style of sunglasses are a good style to consider.
Nov 07, 2010 | Clothing Accessories
Need replacement earpads for Sony FM/AM Walkman SRF-H4 headset radio
LIKE YOU ALL, NO CURE OR REPLACEMENT FOR THE ROTTED PADS. WENT TO HOME DEPOT AND BOUGHT ECONOMY PLUS BRAND AIR CONDITIONER FILTER MATERIAL, ABOUT $3.00, FOR A WALL AC. THEN WENT TO DOLLAR GENERAL AND BOUGHT SCUNCI BRAND BLACK HAIR ELASTICS, EIGHT OF THEM FOR $2.00 TO KEEP PONYTAILS, NOW EAR PADS, IN PLACE. CUT THE AC MATERIAL TO FIT, AND ATTACHED WITH HAIR ELASTICS. ONLY A PURIST WOULD COMPLAIN ABOUT LACK OF COLOR MATCH. THERE WAS A SOLUTION, ONLY A MATTER OF FINDING IT. GOOD LUCK ALL OF YOU. R J BURNS, PENSACOLA, FL
Jul 17, 2008 | Audio Players & Recorders
Looking for a lifter rock lever plate pad for a singer 211g156
Bit confused here, what is the 'make' of the machine and what do you mean by 'pad'
Mar 25, 2008 | Sewing Machines
Roger, ear pads are US $3.54 each. plus tax and shipping.
follow link:
http://servicesales.sel.sony.com/ecom/accessories/web/viewItemDetail.do?operation=getItemDetail&itemID=81781&searchOperation=modelSearch&searchText=SRFHM33
Good luck. I had the same problem.
Mar 20, 2008 | Sony SRF-H4 AM/FM/Weather/TV Radio
Logitech Internet Chat Consumer Headset Logo
2,547 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
