Question about Maytag MAH6700AWW Neptune Front-Load Washer
Neptune MAH4000AWW Waher will fill and empty but the drum will not move in any cycle.
  • 3 Answers
Most common problem is a failed motor control to repair you will have to get a motor repair kit it has new motor and board
Posted on Feb 12, 2008
    Genius:
  • 1,554 Answers
If there are no errors then the motor controller thinks everything is ok.
Do you hear the motor spinning?
the belt in the back may be bad or jumped off.
If you want to look for yourself open the top panel.(3 screws in top rear)
Posted on Jan 29, 2008
MY NEPTUNE WASHER IS MAKING NOISE DURING SPIN CYCLE WHAT PART DO NEED TO REPLACE? MODEL # MAH4000AWW
If the noise starts before the drum starts to turn it might be the pump is obstructed. If it starts soon as the drum starts to turn then might be the drum bearing. If it is a knocking vibrating sound open the door and grasp inner drum try moving up and down and side to side . If there is any movement aside from the whole mechanism then the spider that holds the shaft to the drum is broken . Need a tech
Nov 23, 2010 | Maytag Washing Machines
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune washer continues filling with water e
Does it fill when the machine is powered down?
If it does then the fill valve is stuck open and needs replacing
If it does not then you need to check the pressure switch and the air bell on the outer drum which probably has a ball of jellyfied soap in it.
If you take the back off you will see a thin plastic or rubber hose going from the bottom of the drum to a small flying saucer type object.
If you pull the hose off the bottom connection and blow into it you should hear a clicking noise from the pressure switch.
If it clicks then clean out the air bell and refit the hose .
If it does not click then get a new pressure switch
A repairman would test it live but that is not recommended for untrained people
Jun 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune mah4000aww spin cycle
BELT IS LOOSING TENSION CAUSING IT TO SMOKE REPLACE BELT
Apr 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
What is the drum capacity size on the orig maytag neptune washer?
Drum size or capacity for the Neptune Model Number MAH4000AWW is 3.4
Jan 03, 2009 | Maytag Neptune Washer
Maytag neptune model number mah4000aww
its your pump.get at it thru the back.it may be blocked or may have failed.a volt meter will tell you if its getting voltage.if so should drain,make sure on about spin setting to check.ive had to replace the pump on my neptune
Dec 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer
Drum capaicty is 3.34 for the Neptune Model # MAH4000AWW
Dec 27, 2008 | Maytag Neptune Washer
MY NEPTUNE MAH4000AWW WORK WHEN IT WANT TO WORK
Check for low water pressure. Clear screens in inlet valve. Do-not remove screens. This unit will turn off if not filled in specified time.
Nov 08, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Maytag MAH6700AWW Neptune Front-Load Washer Logo
171 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
