Question about Xerox Phaser 6250DP Laser Printer
Image Drum The printer will not recognize the imaging unit after installation. A new one was installed and it still won't reset. It's asking for it to be reseated or installed whether the new or the old is put in. Any suggestions?
  • 2,072 Answers
Check a couple of things. Make sure all the seals and tape strips are removes.
Also if you have a 6200 and not a 6250 cartridge, they will not interchange, different chips.
After those 2 things, suspect a defective cartridge that needs to be exchanged.
Posted on Jan 24, 2008
Reset drum counter 130f
Do not reset drum counter unless the drum has been replaced.. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Apr 17, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
C530DN 142 error
Image drum up-down movement position detection error. Is the image drum unit removed and installed smoothly? If yes then re-install it If no then Be sure of the connection of the image drum
up-down clutch connector.
- ALSO -
Is the connector of the image drum up-down clutch is connected properly? If yes then Replace the toner sensor board. If no then Connect the image drum updown clutch properly.
Mar 04, 2014 | Oki Electric Industry C530DN Led Printer
Image drum unit
Remove the image unit that the operating screen indicates then install the new one don't for get to pull the protective sheet once the image unit is installed Also en sure to shake the image unit There is what is called developer inside it shake I/U side ways to spread the developer along the hole I/u if not and all the developer is sitting at one end when the motor for that unit turns you will get a code or burn out the motor,
Jan 31, 2014 | Minolta C350 Printer
How to reset drum counter on bizhub 200
Utility counter, details stop00 stop01. Counters. Has the drum been replaced? if not you reset the counter the machine will assume that a new drum is install and select the proper voltages for a new drum since the drum is not new? it might code and get poor image quality issues. Replace the developer with the drum. Machine uses the counters to determine setting in the machine, developer also has a counter. Does the front panel say replace PC drum? If so replace developer and drum and cleaning blade at the same time. You clear counters before pulling out the image unit. and you don't exit all the way out of service mode after clearing the counters you hit exit once the turn off main power, Rear left side. Once new drum and developer installed. RUN F8. Do not allow copies Prints or fax until F8 is run. Or start all over again.
Jan 03, 2014 | Minolta bizhub 200 All-In-One Printer
Change drum kit
Remove the old drum unit,remove the drum and the drum cleaning blade,clean the charge corona wire and grid,install the new drum and drum cleaning blade,clean the image transfer /separator corona wire,clean the optical parts(mirrors ,lens,glass)clean the AIDC sensoe located under OPC drum,reinstall the drum unit in the copier,enter in the technical Rep mode,place 5 sheets A3 paper on the original glass and perform F5 AIDC sensor(Auto image density control).
Mar 19, 2013 | Minolta EP4000/5000 CS/PRO Copier
After changing toner it displays the call service 7410-0066564
Error 7410 - Drum unit non- installing error
The drum unit is not installed or not installed properly.
Install the drum unit (See page P.1-5-10 of your operation guide). See image below.
The numbers after 7410- are the number of pages printed on this printer.
Nov 23, 2011 | Kyocera FS-3900DN Laser Printer
OKI C6100 has the following error when printer is turned on: Replace Image Drum 562:C Drum Life
Try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Nov 11, 2009 | OKI C6100dtn Led Printer
Xerox Imaging Drum reset ? for Xerox Phaser 2135
The only way to reset the image unit drum is installing a new one. The new image unit has a fuse which once blown it resets the counter on the machine. You can call I have their information in my ad place. They are good techs. I once called for a 7300 image unit reset and they said it was almost the same as a 2135 and they gave me this information. well goodluck.
Jul 24, 2009 | Office Equipment & Supplies
Print quality problems after installing imaging unit.
Put the old image unit back in, if it prints normaly then you might have bought a defective image unit.
Apr 16, 2009 | Xerox Phaser 7750GX Laser Printer
Changing Drum
The drum is where the image is applied before being transfer to the paper. If the drum is wearing down the image will become poor. Changing the drum unit will make the image like new. So, yes you can run the drum catridge until you get a poor print out.
Apr 24, 2008 | Brother MFC 4800 All-In-One Laser Printer
Xerox Phaser 6250DP Laser Printer Logo
273 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
