Question about IBM ThinkPad T41 Notebook
T41 screen intermittantly flickers then locks up
I'm pulling my hair out trying to figure out what is going wrong with my T41 2378DHU every now and then the screen will flicker and glitch then I can't do anything it just locks up and I have to just hit the power button, and even after that it takes a few times to work again I usually get a gray screen on the reboot?
I've run onboard PCdoctor diagnostics and Geeksquad full script diagnostic both passed no problems found? updated all the drivers and bios from system update utility any help is greatly appreciated
  • 2 more comments
  • DJTOPCAT71 Jan 25, 2008
    actually I'm a former Navy aviation electronics tech and I wield a pretty mean soldering iron I successfully resoldered 2 of those tiny brown caps on the mb a long time ago so tell me what I need to do and I'll get it done :)
  • LindseyW Aug 05, 2008
    My thinkpad t41 locks up all the time. It'll freeze, then the screen gets fuzzy and flickers. I have to restart the thing and then after than the computer will constantly lock up....what is going on???!!??!
  • Anonymous Aug 08, 2008
    DVD LANSE
  • mushadow Nov 06, 2008
    I have what sounds like the same issue. Randomly, the screen will flicker or lines appear across the screen and the laptop will lockup. If I press down on the left wrist pad the screen will clear up, but it stays locked up. The last thing I did to the computer was add more memory about 6 months ago to the DIMM slot on the back side of the board. The issues started happening about 1 month ago.
    Scholar:
  • 163 Answers
BGA RAM For the Video chipset is the problem.. Weve repaired a few of these..(Wish I could tell you its an easy home fix but its not)..
ikenfixit.com
Posted on Jan 24, 2008
  • Ken LaDere Jan 28, 2008
    Soldering Iron will not help.. You need to Hot air bathe the board on the bottom and use Hot air or IR on the top to reflow the components..BGA = Ball Grid Array.. Google and you can find more info.. Good luck!..
    (Theres postings of individuals doing this with a Automotive heat-gun but the preheat and timing as well as temperatures are critical to the process so I'd say its a No-go w/out a rework station).. Temp fix to a perm. Problem if it does work...
HDMI from new laptop is causing intermittent flickering.
i would suggest a different refresh rate. should be in display properties.
Jun 17, 2015 | Sharp Televison & Video
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Flickers after 5min of use. Perfect sound, turns on fine and excellent picture quality when in blue screen menu mode. Why?
This intermittent problem is very difficult to rectify. Just contact the authorised service center for Hitachi at your town. The work is really a skilled one, that a user cannot do it with ease.
Jul 13, 2012 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
IBM T42 2379 screen flickers very much
We have the T40 model laptops at my work and I have found that when the screen begins to flicker that the internal video cable is beginning to break. It is possible to replace the cable by purchasing a used, and same model laptop from EBay and trading the parts.
To attempt this you will need to remove the keyboard, upper framing, and the framing around the monitor. You should be able to replace just the cable.
Sep 06, 2011 | IBM ThinkPad T41 Notebook
IBM thinkpad T41 -> get
The IBM Thinkpad has a very strong security system.
If you are seeing a lock symbol when booting then somebody has set the supervisor password. If you can't remember it or guess it (try "password", "admin", "pass", etc) then you need to find the person that set the supervisor password.
Once the supervisor password is set the T41 is very well protected and it can't be reset by removing the laptop battery or CMOS battery.
There is a way to read the password from the protection chip but this is very complicated and requires taking the laptop apart and building your own chip reader.
The instructions for doing this are are:
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Hope this helps,
Chris
Mar 08, 2011 | IBM ThinkPad T41 Notebook
The tube in the back looper must be blocked as I can not get the air to push the thread through. How do I unblock it
Are you sure you're not trying to thread through the 'chain' port? I've done this a few times, almost pulling my hair out trying to figure out why the thread wouldn't go through. Then realized this simple mistake on my part.
Dec 30, 2010 | Baby Lock Evolve
T41 will turn on and then immediatly go to sleep
Check that the hard disk is in working order.
If the hard disk will not spin up... sometimes the system will just shut off.
It may be a bad motherboard.. usually a damaged or failing capacitor will cause the system to not stay powered up long enough.. capacitors usually create a steady flow of electricity... if it can't hold a steady charge it will behave as you've mentioned.
Dec 08, 2008 | IBM ThinkPad T41 Notebook
42 inch screen
Did you measure diagonally from corner to corner? This is usually how all manufacturers quote screen size. Hope this helps
Dec 07, 2008 | Polaroid FLM-4201 42 in. LCD Television
Ibm t41 thinkpad display problem
actually its the problem of the cable that gives display to your screen , open your laptop and replace this cable
rate this solution
Oct 15, 2008 | IBM ThinkPad T41 2373 Notebook
IBM ThinkPad T41 Notebook Logo
868 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
