Question about Epson Stylus Photo R300 InkJet Printer
Epson Photo R300 CD/DVD Tray Printing Problems
When I align the arrows, per the manual's instructions, the printer ALWAYS pulls the tray in slightly and then immediately pushes it out and the red error light comes on. As instructed, I close the tray and click the Eject button that the program presents me on my Windows XP Pro screen.
The only times (and these have been very precious few) I am successful in printing onto a CD occurs when I push the tray in more than I am supposed to do--as a result the arrows are not aligned; and then I have to exert a little, but steady pressure on the tray as the printer starts to pull it in. Sometimes it will then go ahead and complete the printing process.
But even then it does not properly align the image printed onto the CD. I have gone through the process in the printer's menu window to move the image, e.g., 4mm left. Whenever I succeed in getting it to print again, I see no realignment of the printed image.
I am extremely frustrated and I really want this printer to faithfully print properly aligned images onto my CDs without me having to hope and pray (and play with it) every time. I will be supremely grateful if you can help me make this thing work as it is supposed to do.
I have owned the printer a few years but this is my first time trying to print onto CDs. I have wasted tons of hours within the past week or so trying to achieve this. Please help!
    Genius:
  • 2,985 Answers
1. make sure there is enough room to the rear of the printer to allow clearance for the try to pass out the back and back in.
2. when initiating the processes and thing start to happen gentle pressure on the back of the try to help the start the ball rolling helps
3. Do examine the lead in strips at the front of the try to ensure they are no distorted.
And 4 a search og Google and EBay can reveal a revised design tray for a modest sum.
Finally take a look at www.fixyourprinter.com.
Posted on Jan 24, 2008
R300 error message close cd dvd guide the guide is closed but it will not print
Have you contacted Epson directly? I had a problem with the R200 some time ago and it was down to the tracking of the CD/DVD tray being out of alignment. Due to cost of the printers now it is not worth paying to get them fixed. Lookout for Epson deals where you can trade in your old R300 for a newer model. I still have my R200 still going strong and an RX858.I am sorry I have no firm advice to fix it direct.Mac#
Oct 25, 2011 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 Inkjet Printer When I try to print on a cd/dvd I line up the arrows hit print but it keeps telling me to close the cd/dvd tray, there is no way it will print with this tray.
The cd/dvd tray door has a small opening on right edge. Inside there is a slide switch. Use a toothpick to see if it is stuck. Check where it closes to the main body. A thin strip protrudes out to mate and close the plastic actuator of the switch. The door may not be closing well enough the actuate the switch. Make sure it is fully closed and retry to print. Also, there will be a small click as you raist the door before it snaps into place. If not, check to see if there may be some debris causing it to not actuate properly.
Good luck,
Feb 21, 2009 | Epson Stylus Photo R300 InkJet Printer
Need CD/DVD designer/ printing R300 stlyus photo software
I may be able to help. I have the disc with the 2.5Mb CD Printer folder on it. I can email you the folder which contains the install. Let me know. RMS
Nov 28, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson stylus photo R300 cd/dvd tray not set correctly
I had the same problem. Restarted the printer. Reinstalled the drivers. Scratched my head ... nothing! then I moved the printer away from the wall - problem solved! I can't say that this will work for you but if everything else is working, as it was and still is on mine then it's worth a try.
What I didn't realsie was that the cd tray comes out of the back of the printer when it's checking the alignment. I had inadvertantly pushed the printer back, too close to the wall. Moved it forward slightly and it's fixed.
Hope that solves it for everyone.
Nov 16, 2008 | Epson Stylus Photo R300 InkJet Printer
Mac OS 10.5 Leopard
As per someone elses post here:
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Oct 18, 2008 | Epson RX595 Photo All-In-One Printer
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson R300 CD/DVD Tray ERROR message with Leopard any Solutions?
One of the guys on this site said read the manual over and over again, and he was right.
You must go to system preferences and choose print and fax. Set the default media to A4. Then in the Print CD program when you hit print your will see fifth line down Epson Print CD on offer. Hit the arrows on the right and choose print settings from the drop down menu and then media type and choose CD / DVD. All should then work. It does on mine.
Regards and best wishes. David
Dec 30, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
158 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
