Question about Motorola Mobility V262
Display screen The display screen on my Motorola V262 is black. The phone charges, receives and places calls, but I cannot access my address book nor see who is calling me because I can't read the display. This happened right after I ran my phone completely out of battery on a vacation.
  • yaudrey Jan 25, 2008
    Thank you! One question...how would I "have it flashed?" Sorry, I am technologically illiterate!
    Sergeant:
    Champion:
  • 241 Answers
That is wierd - you can try the first solution to have it flashed, but 30% that's the answer, somehow your lcd probably burnt out so a simple replacement is required - it would cost about $30-40 for the lcd and the installation
Posted on Jan 25, 2008
  • Anonymous Jan 26, 2008
    For the flash you will be best off by going into a Verizon or Sprint store (your carrier) and ask them to update the firmware - it should be free.
    Call you customer service, and ask for the closest repair shop for your area.
    thanks
6ya staff
SOURCE:
I can place and receive calls but screen does not display, is black
My sister had the same problem. I looked on the bottom right corner and saw the casing was separated a little and squeezed it closed. It popped into place and the screen went on.
Dec 19, 2009 | Motorola Mobility RAZR V3
Inside Diplay not not working
Look on HowardForums there are tutorials for that.
Aug 03, 2009 | Motorola Mobility RAZR V3
My v262 won't turn on
have the flexcable replaced or the lcd on the phone take the phone to a mobile tech and have diagnosed it and fix it for you....
Aug 01, 2009 | Motorola Mobility V262
Formatting
u must now go to motorola service center to get it a software update
Jun 03, 2009 | Motorola Mobility L6 Cellular Phone
Razor display not working
it could have a damage in its display connectivity cable or it could be the display also, take it to the motorola service center or call me for guidance my no. is {{0-9999-916148}} ;- Himanshu
Jun 04, 2008 | Motorola Mobility RAZR V3
V262 constantly beeps "low battery" alert
your battery might need to be changed. even if it has a full charger it might not be able to properly charge you phone.
try a new battery.
Mar 06, 2008 | Motorola Mobility V262
Address book
try to master reset and clear the phone then try it again.
Feb 19, 2008 | Motorola Mobility RAZR V3
NO DISPLAY
i have the v3i and it had the same problem its usely the flex cable that messes up if its opend some times fast the screen gos white if you change the flex that should solve your problem . [email protected] cumputer tech
Nov 26, 2007 | Motorola Mobility RAZR V3i Cellular Phone
My inside display doesn't work
I would order a new phone under warrantee. Go to a motorola shop and they will switch your contacts from one phone to the new phone once received. I just had to do that. It only took two days to receive the phone. Not too bad. Let me know how it goes.
Cynthia
Nov 02, 2007 | Motorola Mobility RAZR V3
Kyocera oyster
Shine a bright light on it and see if you can see and resemblance of the display on the screen. If you can see a display, the backlighting on the screen is broken - if you can't see a display, it's likely the screen is broken or the display controller is broken. Backlight would be the cheapest fix, usually. Also, you should be able to transfer your phone numbers over to a new phone by using the same SIM card so long as the phone numbers were stored on the SIM card - the only way to find out is to put it in another phone and check out the address book.
Sep 07, 2007 | Kyocera Oystr KX9 Cellular Phone
Motorola Mobility V262 Logo
81 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
