Question about Arris DSR922
DSR9SS PROBLEM SIGNAL IS 100% BUT THE QUALITY IS ONLY 14...CAN NOT STAY LOCKED ON TO THE SATELLITE
  • JOHN440 Jan 25, 2008
    TNXS FOR THE SUGGESTIONS, STILL HAVE THE PROBLEM.
    NOT ABLE TO GO UP AND CHECK THE CONN. AT THE LNB
    DUE TO WX HERE IN SOUTHERN CA. WILL TRY TO CHECK THE ALIGNMENT BUT HAVE NO IDEA HOW....TNXS FOR YOUR QUICK REPLY TO MY POST...JOHN
  • Anonymous Jan 28, 2008
    I believe that I cannot get a signal due to very little dc voltage to the lnb. 24 volts is required, but reads only 5. . Is a motorola repair service close to Albuquetrque? Whio repairs these 922 receivers?
  • 2,336 Answers
I would suggest to check the RG6 cable connections on the LNB and the receiver and make sure they are tight, also the dish may have lost the alignment and that is why you have low signal.
If you use some sort of switch in between the dish and the receiver, I would say to by-pass it and connect it directly.
Good Luck.
Posted on Jan 24, 2008
TV picture not clear
First we need to know a little more details about the kind of TV you have, the kind of service (Cable, Satellite or off Air).
Comparing showroom to your home is also something we need to know. Was the showroom using Cable or Satellite. Satellite will always have a better picture quality wise.
If you are using composite input for the signal path between TV and source this would not produce a High Dif picture Composite = Yellow for video, red and white for audio. If you are using Component source that will produce a HD signal cable is RED/BLUE and Green with different audio.
The best quality is using an HDMI cable, this is all in one cable and the sources is the best. One last thing, if you are using the RF *cable as source it will not give you a quality signal.
Apr 22, 2014 | Intellian i9P US HD System with 85cm Dish...
I've a problem. When i switch on the tv. It says no signal. I've thought of turning the satellite but it keeps saying no signal and the signal quality stays at 4%. How to do? Configuration: technosat.
firstly the satellite dish antenna must be correctly aligned to satellite you want to receive.
technosat setup" initial setup" select the correct safelite ,once selected u should see signal strength /quality then tune the channels...auto works best, after this you can create your own favorite channel list
Nov 17, 2013 | Televison & Video
Ive got a freesat dish and reciever but we get 90% signal but no quality any suggestions
Your on the wrong satellite, If your on any satellite youll get a high Signal but you wont get a high quality until your on the specific satellite. Astra 2A is for freesat. If you can bring that up on the menu then just keep moving the dish until the quality goes above 50% and that will suffice for a decent picture.
Mar 14, 2011 | Televison & Video
Satellite signal strength is good 56% but the quality is 0% how can correct this problem
Please try to increase the satellite signal to make this channel works.
Feb 02, 2011 | Televison & Video
Hello- using dish 500 with twin lnbf, 311 receiver. 119 locked in easy with 70 signal . When trying to find 110, I cannot get a strong enough signal to lock. 129 signal shows strong along bottom of point...
Hi CharlieO my name is Mike of DISH Network and I was reading over your post and seenwhere your 110 satellite is not locking in or on your install summary screen. Iwould be more than happy to help with this issue and to research further I willneed to look at the account to look what satellites they have setup on youraccount. I will need your account number or your phone number; I will leave mye-mail so you can contact me directly. Michael.houston@dishnetwork.com
Jan 30, 2011 | RCA DISH Network(r) 311 Satellite System
With the bell dish we have the oblong dish can get 100% signal for satelite 91 and 100% on satelite 82 but not both at the same time?
Guest 10
With multiple satellite dishes, you will get a lower signal strength on mulitple satellites as opposed to individual satellites. The reason being when pointed at one satellite, you are pointed directly at that satellite. With multiple satellites, you are pointed in the general direction of the multiple satellites so the signal will not be as strong compared to pointing directly at the individual satellite. Normally, a signal strength 50 or above is sufficient. I hope this helps.
Ray Calo
DISH Network
May 20, 2010 | DISH Network IR Remote Control
Signal 67% quality 0% auto scan set up no channels found
When you place a call, does it go from 4 bars of signal to 0. If this is what it happening, then your 9505 satellite phones signalling processor has become out of allignment, and needs serviced. We service all forms of satellite equipment. 877-258-3496
Oct 04, 2009 | Motorola Satellite 9505 Cellular Phone
No Signal since 6/14
From the Nextar Support Web Site
"Q: NOTICE for all US customers with M3 and Q4 series that have been having a problem recently with receiving a satellite signal.
A: Recently it has come to our attention that there has been a problem with a US GPS satellite, in the early morning of June 14 launch a sudden change in the code signal, leading to some GPS signal anomalies. It is told that the satellite signal should be running properly by June 22, 2009."
Jun 18, 2009 | Nextar Q4-04 Car GPS Receiver
Dish 625 shuts off without warning and fan runs high
Unfotunately this is an event known as power cycling and the only resolution is another receiver. This issue is due to faulty internal components and has nothing to do with anything other than that fact. If you have further questions feel free to contact me. Thanks for using Fix Ya.
Jan 12, 2009 | DISH Network DVR-625 DTV Receiver /...
Sirius 100 repair manual
my sirius stiletto 100 power on/lock switch slides up and down freely. feels like something came apart inside the device. any solutions?
Sep 16, 2008 | Sirius Satellite Radio Sirius SIR-ALP1...
Televison & Video Logo
74 people viewed this question
Top Arris Televison & Video Experts
Marvin
Marvin
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
