Question about Frigidaire PLMB209DC Microwave Oven
Some sensor/switch is out?
The only way to engage the microwave is to ever so slightly touch the door button down, about 1/8".  It seems to be flush with face plate when you open/shut the door.  Didn't know if it is the "spring" behind the door causing problems (but it didn't seem likely as the button sits flush with the door), or if it were #5 on the schematic - switch/monitor/fuse, or something else.  If you don't press the button ever so slightly it will count down and the light will come on, but the microwave part won't engage.
  • 5 more comments
  • IGEAUX Jan 24, 2008
    It is a DCC. From looking at the schematic, I presume I undo the black casing and screws from underneath and that should get me in? What switch/part numbers? Anyway to test which is the culprit?
    I'll let you know what I find. Does the switch part you list include the bracket?
    Well, it's kind of strange. The lever completely depresses the little red pin switch on the switch. However, there is no continuity b/w the two leads unless you ever so slightly push on the door, allowing some of the red pin to raise, then it works. I did not some arching in running mode to stopping mode (ie, when I open the door completely) The other two switches seem to have continuity with door closed normally. Anything else I should check? The plastic bits and brackets look ok. How the heck do I get the switch out w/o breaking these little white bits of plastic holding it in. From what I see, there is a white pin that goes through the body, two bigger bits that fold over the edges and a smaller bit that rests on the bottom of the switch.
    There are three switches on the bracket. With the door closed, my meter will beep between the two terminals going into each switch. However, on the bottom one, it reads 148ohms with the door closed. If I push on it however, ever so slightly, it then beeps and microwave will function.
    OK, top and bottom switch are identical. So I switched them. Now, just the opposite, the microwave runs automatically when the door is shut, so something has to have gone crazy in the switch?
    No door alignment doesn't work. Tried that first. Problem is the switch in question has three settings with the dip pin, and I believe it is only supposed to have two. When the switch is completely depressed, something goes hay wire. Lift it up just a tad and in functions normally. Open it up all the way and it turns the microwave off like it is suppose to. Local distributor has one in stock. Figure for $20 I'd give it a try. Let you tomorrow evening if there are still issues with a new switch.
  • Anonymous Mar 24, 2014
    Flat stainless door release button (to open) keeps getting stuck. Door is very hard to open. Unsure if it can be easily repaired or how to access the lock mechanism. Any suggestions?
  • 770 Answers
There are two switches there do you know how to get into the control panel?? If not let me know I will walk you thru it
Posted on Jan 24, 2008
  • 9 more comments
  • Gary Davd
    Gary Davd Jan 24, 2008
    Is the letters after the PLMB209DC an A B C or CB ??
  • Gary Davd
    you want to unplug the unit on each side there are 2 -3 screws and around the back there are some screws you will need to remove (NOTE: one maybe a safety Screw) you want to remove these screws these hold the casing on Once the screws are out put your hands on both sides and pull towards the back of the unit the case will come off spin the unit around and you will now be able to see the 2 interlock switches where the door closes to.. the switch sounds ok but it may have to be re-seated in its bracket if it (bracket) is not broken this can happen if the door was slammed shut check it out and let me know.
  • Gary Davd
    the upper and lower interlock switch part # is 5304440026
  • Gary Davd
    once you are in you will see the switches on the brackets you will need a meter with contunity test to check them
  • Gary Davd
    No the bracket # is called(Latch Hook) is part# 5304440840 cost about $20 the switch is around $16 each
  • Gary Davd
    These are little micro switches about 1" long may have 2 or 3 wires going to them these are known as Door interlock switches they need to close in order for the microwave to work if by pushing down on the door and it working then you are forcing the hook lever thats on the door to press on the switch you will see what i mean when you open the case
  • Gary Davd
    well they are held in just like you see them clipped in the plastic holder ..you may see a plastic pin going thru the switch to hold it in place but no screws on the switch As far as the electrical you will have a COM terminal then a N.O. Terminal and if it has 3 terminals a N.C terminal test with the sw out between the com and NO your meter should read open keeping the meter on it press in the sw you meter should change to closed To check the NC terminal and Common it will read closed press in the switch and it should read open
  • Gary Davd
    First off are all 3 switches the same type?? it lloks like thwe bottom one is diffrent has a cable tied to it? not sure but it does show a diffrent part number on it.. Anyway the switch is good if you are getting it to work by pressing down now the question is can you adjust the switch to make the contact better?? by either adjusting the bracket or the switch or the closer on the door itself??
  • Gary Davd
    you maybe able to tork the door down a little ..if it only needs a small amount to close that switch.. Worth a try
  • Gary Davd
    did holding or tweaking the door make it work???? I think your best bet is to not replace them also it sounds like you have one switch that is N.O and one that has the NC( wires crossed) put them back like you found them,and try again with the door aligment your switches sound good from what you are describing
  • Gary Davd
    Ok sounds good
Latch on Dacor micro (DMT2420S) not engaging sensors.
The latch interlock may be defective or in need of adjustment.
Dec 14, 2017 | Dacor Microwave Ovens
Something in the door is causing microwave to shutoff. Sensor is on, but then shuts down unless,also you hold a certain pushing in the button.
Adjust the latch switch assembly to make sure that the door hooks engage with the switches. Loosen the 2 phillip screws holding the assembly and slide back and forth to adt. Retighten when the door hooks are making solid contact with the switches.
Dec 15, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
PANASONIC Microwave Inverter #NN-SD697S. Everything works except the START button. Works sometimes, and not other times. Checked outlet, all was good.
This is either the door sensing switch (most likely) or a bad membrane switch [start switch] (that's what Panasonic calls it) on the touch pad. The contacts on the door sensing switch can be slightly contaminated and not read "zero ohms" to the control PCB. The control board thinks that the door is open and it will not allow the cook cycle to start.
Sep 11, 2013 | Panasonic NN-S251 Microwave Oven
When I turn the micro on it does not turn nor heat unless I lift up on the door. Seems like door needs to be adjusted slightly
The problem you're seeing is nearly always a result of a safety switch that is not being activated by the door. The result is that the oven thinks the door is not shut fully. Pressing the door closed at the latch or downward from the top opposite of the hinges will usually provide enough movement to activate the switch. One of these methods is what I suspect you are doing to get it to work.
Inspect the prongs on the door. Make sure both are not damaged or broken in anyway. The size and shape are critical for effectively engaging the safety switch. Repair or replace parts as needed.
The switch itself is usually connected to the latch striker assembly or to a switch deeper inside the oven - to the latch itself - to detect its position. The striker assembly is partially visible behind the two openings of the door frame - the two prongs on the door push them down and when fully closed, keeps them down. Since accessing these parts requires disassembly of the oven by qualified persons to maintain safe operation - the oven should be service professionally to ensure that the door is closed completely before allowing the microwave to function.
Sep 03, 2013 | Dacor DCM24 Convection/Microwave Oven
Microwave seems to run, but won't heat.
We have a similar problem! It sounds like a problem with the microswitch inside the unit that the door is suppose to engage when closed. If not engaged properly, it will not cook. We had the switch replaced last March but it has started acting up again. We can press in on the door and/or lift it slightly and it will cook. Try putting time on the counter and hit start. It the word "cook" appears then try moving the door slightly and see if the turntable starts turning. If not, then you may have a more serious problem. Good luck!
Oct 09, 2009 | Frigidaire FMV156DC Microwave Oven
M/w only working when slight pressure applied to door button
That would be a defective secondary interlock (lower door switch) or its mount.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
If you only need a switch, you can order a universal type here for $5 postpaid.
Jan 03, 2009 | Dacor DMT2420SS Microwave Oven
Sharp R-1450 microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
On these, it's usually a broken tab on the upper switch holder.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
That sounds like what's happening when you hold the Start pad - maybe you're moving the frame and chassis enough to help it work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 19, 2008 | Microwave Ovens
Keypad doesn't work
check control panel and clean the control circuit, any moisture is there clean the circuit. any dry solder is there check overall circuit and confor it ...door switches and sensors
Oct 26, 2007 | Emerson MW8779W Microwave Oven
Frigidaire PLMB209DC Microwave Oven Logo
109 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
