Sony Dual DVD +/- RW
I installed this unit in my Dell Optiplex 210L. I found that both the original cd and newly installed dvd did not work after thre installation. In the BIOS the Drives are as follow:
Drive 0= SATA 2, Controller= serial ATA, Port= SATA 0, Harddrive= 80GIG
Drive 1= SATA 2(off)
Drive 2= PATA 0, controller= Parallel ATA, Primary IDE Master (DVD)
Drive 3= PATA 1, controller= Parallel ATA, Primary IDE Slave (off)
The hard drive is set on "Cable Sellect".
The dvd drive is set on "Master"
What is the problem?
  • antricos Jan 25, 2008
    Thank's a lot for your assistance, your suggestion was right on the money.
    Good job guys!!!!!!!!
  • ruddy2107 Feb 12, 2009
    were do you find that
    Sergeant:
  • 226 Answers
Set the hard drive to master and the dvd to slave
Posted on Jan 24, 2008
6ya staff
SOURCE:
Error Message: Drive 2 not found: Parallel ATA, PATA-0 (PRI IDE MASTER)
Anonymous,
Did you set the jumper on the drive to cable select? Check to what the jumpers on the back of the drive is set to. You should have 3 selections. primary,secondary and cable select.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 21, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
My dell optiplex 210 L cannot see DVD drive in "my computer" and also in device manager. Even after going through registry as advised, i don't see lower and upper entries that iam supposed to...
Check the DVD Drive cable connections, make sure they are plugged-in properly. Check BIOS if DVD is detected; you may have to reset to default configuration. If it's detected in BIOS, press F12 while on the Dell screen to access advance boot menu & select CD/DVD drive option. Insert a bootable disc like windows installer & see if your drive will read it. For cabling setup refer to this link http://support.dell.com/support/edocs/systems/op210l/en/ug/mtdrvs02.htm#wp1136008
Mar 24, 2011 | Dell OptiPlex 210L PC Desktop
Installed Samsung SH-182 SH-S182 DVD Burner But my computer windows XP is not reconizing the newly installed unit
Which OS Service Pak is XP using? Have you tried to update the drivers? ' System ' Hardware ' Device Mgr
Can you test the burner on a 2nd PC? My older PC's dont see the DVD-RW but the burning software does.
Feb 21, 2011 | Samsung SH-S182 DVD±RW Dual Layer Burner
I have an NEC ND-6750A installed in an HP Pavilion ze5570us laptop. I installed it after the original cd drive failed. Windows recognizes the drive but considers it a CD-ROM drive with no DVD...
did you buy this off of eBay? this unit may need to be "flashed" so to speak. the term is firmware upgrade. the HP website has this and i have supplied the link for you. here is thre link for the firmware update:
http://liggydee.cdfreaks.com/disclaimer/en/6750a/261_orig.zip.html
windows should not only recognize it but should reload the drive with the correct parameters.
Feb 21, 2011 | NEC ND-6750A DVD RW Dual Layer Burner
DVDs do you think are the best that can be RW for copying files on the Dell Optiplex 960
most any dvd manufacturer will work. the only thing you need to know is if your dvd/burner is + or - read capable. some are both.
Jan 20, 2011 | Dell Precision 530 XEON Workstation Dual...
Sony DVD unit not reading DVDs
try to clean the drive's lens with a lens cleaner CD ...
Oct 16, 2009 | Sony DRX-S70U-R DVD±RW Dual Layer Burner
Dell won't acknowledge installed DVD/RW Driver
try running this patch..
http://dell.driversdown.com/dell-drivers-downloads/Roxio-Easy-CD-Creator-5.3.4-Patch-Upgrade_23173.shtml
or try calling Dell Tech. They normally remotely access your system and run a patch and your dvd drive will show up in Sonic/Roxio
Nov 22, 2008 | Dell 16X DVD±RW Serial ATA Internal Drive...
Open Questions:
AOL MAil HeLpliNe {1-855*536*5666}#[email protected] PHoNe NuMbER IOWA call or contact AoL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL mAiL USA Calling AoL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL mAiL USA's phone numbers against each other. Contacting AoL mAiL USA in General WhileI:855:,:5365666 is AoL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL mAiL USA.
Nov 12, 2019 | AOL Computers & Internet
AOL MAil HeLpliNe {1-855*536*5666}#[email protected] NuMbER NEW MEXICO call or contact AoL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL mAiL USA Calling AoL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL mAiL USA's phone numbers against each other. Contacting AoL mAiL USA in General WhileI:855:,:5365666 is AoL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL mAiL USA.
Computers & Internet Logo
232 people viewed this question
Ekse
Marvin
Marvin
