Question about Toshiba 43H70 43" Rear Projection Television
I can't find the settings in my toshiba 43VJ22P menu to adjust my convergance, please help!
    New Friend:
You need to press must on the remote and whilst holding mute, pess menu on the left hand side of the tv. that will let you in to service mode. im sure if you press 7 in service mode it will let you in to the convergence menu.
Posted on Feb 01, 2010
SOURCE:
Toshiba 43VJ22P, the colours blue and red go in double vision, tried convergence didn't work. can you help please?
You will need to replace the Convergence ICs ,they are Big Black ICs and will have part number on them. Example STK392-110
Mats Electronics has Parts 1-800-628-1118
Jun 30, 2011 | Toshiba 43A10 43" Rear Projection...
I have a toshiba tv model tp50g90 I have replaced the convergence chips stk392-110 convergence was corrected but I have a problem yet red not managed to focus on the user menu in the option of...
Thats the way it works. You have to adjust the other colors to the red. You adjust the red from the back of the set using the convergence magnets on the tubes. Then you adjust the other colors to match the red. It's much easier if you have the plastic screen from Toshiba used to align this set.
Feb 20, 2011 | Toshiba TP50G90 50" Rear Projection...
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    Toshiba 43VJ22P convergence trouble! I have a Toshiba 43VJ22P, the red convergence was out in the x plane, and could not be adjusted, however it could be adjusted in the y plane. So i've changed the...
    Hi
    Thanks for using FixYa. Then it means the problem is with the convergence board and it’ll require to be replaced to resolve the issue.
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Feb 26, 2010 | Televison & Video
    Toshiba Model 43VJ22P Shadows on the screen? Adrian
    Ur convergence is dead.Must replaced these 2 convergence ICS and all it resistors.The shop will cost U $300 for parts and labors.
    Feb 02, 2010 | Toshiba 42H81 42" Rear Projection...
    Convergence problem
    Are you trying to adjust it in the customer menu?
    There is a hidden tech menu where you adjust and SAVE THE ADJUSTMENTS.
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} TOSHIBA CONVERGENCE ADJUSTMENTS
    MUTE,
    MUTE & HOLD ----THEN MENU ON TV SET
    “S” SHOULD SHOW
    MENU AGAIN
    7 FOR GRID, 3 FOR EACH COLOR
    7 AGAIN TO SAVE AND EXIT
    NAVIGATE WITH 2, 4, 6 AND 8 BUTTONS
    If it does not save you have a problem with either the convergence output chips or the part of the set that stores the adjusments.
    If this helped you rate this solution as I do this here for free.
    SD TECH
    Dec 10, 2009 | Toshiba 57H83 57" Rear Projection HDTV
    Toshiba 43VJ22p rp tv has lost bottom half of picture and has bad convergance but is impossible to read menus to adjust settings, no obvious component issues or wiring faults, any ideas?
    the redgun of my toshiba 43vj22p is out of focus, so much that i can't adjust it anymore. does this mean i have to change the lamp or is it something else?.
    Nov 05, 2009 | Toshiba Televison & Video
    Toshiba 43VJ22P
    TOSHIBA 43VJ22P I HAVE NO PICTURE BUT THE RED LIGHT IS ON.. HELP
    Aug 13, 2008 | Toshiba 57H81 57" Rear Projection...
    Shadows on Rear Projection TV
    http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
    http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
    Sony Convergence
    http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
    http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
    Jan 25, 2008 | Televison & Video
    Toshiba 43H70 43" Rear Projection Television Logo
    249 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Steve Allison
    Steve Allison
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
