Question about Dell 3200MP Multimedia Projector
Green tint I just purchased an epson powerlight s1. All the highlights are green. I tried adjusting the color and tint, but nothing seems to work. Even the main menu screen is not blue. Do you have any ideas what is wrong? I'm having a problem with green tints in yellows and grays and everything else is fine.
  • 2 more comments
  • kernel Jan 24, 2008
    Cables: USB plus 15 pin from computer. Both need to be connected to get any picture.
    Tried factory reset and it doesn't improve.
    Also, projector is a Dell 3200 not an epson powerlight
    Brand new laptop - everything updated.
    the pic doesn't project unless both are hooked
    Genius:
  • 1,067 Answers
What cable are uusing coumpount vga 15 pin to coumpunt or u try new cables
Posted on Jan 24, 2008
  • 4 more comments
  • Anonymous Jan 24, 2008
    maby one is mixed up colers on cable not right input that can cuse it chech conection again
    try factory reset if it has it in menu or do uuse hdmi cables to it or yellow reg comsite or s video let me know try other cables try runing it direct to projecter ok cheak pins on cables any missing broke bent
    so uuseing from your computer then what about leatest video card drivers install on labtop ect updates
    gotta be the light system then on that dell can u take bulb out then re put back in tigt reseat it u know cheak for dust and the coler wheel see if its dirty
    why does usb need to be connected ? for sound only teh 15 pin the use fn on labtop to shoot out that back crt port whats purpse of teh usb cable try it with out it
    that dont make sence shoudl work with vga port in on benq only vga cable from labtopp to it input vga mode pc ok what does the usb cable call for what info do uuse it for
6ya staff
SOURCE:
The screen has a dark green tint and cannot be adjusted. More specifically, the green section of the RGB setting on the monitor can't be changed (the G setting is permanently gray and I cannot move to that...
Take it in for repair seems to me that you have done all that you could to fix this monitor it is a flat maybe worth the repair if the repair is slightly less or more I would consider spending the green on a new one they are getting down in price. Thanks for using FixYa! John
Apr 02, 2011 | Sony SDM-HS73P 17" LCD Monitor
Is there a way to access the tint function on the Apex4088? It is not accessable when we go into the picture setup menu. It appears to be locked.
Hello
The Tint function can be accesed by the following steps.
The PICTURE menu offers options to enhance and refine the picture displayed on your TV based on ambient room light and personal preferences. Adjustment options include contrast, brightness, color, sharpness and color temperature
Press the MENU button on the remote control. Navigate using t u arrow buttons to select PICTURE. Press the down q arrow button to highlight PICTURE MODE, then press the u arrow button to select your viewing preference from 4 factory options:
STANDARD > DYNAMIC > MOVIE > PERSONAL. The STANDARD setting is recommended for most viewing environments. Depending on the ambient light level in the room, you may find one of the other options more pleasing.
To make more critical adjustments based on your own preferences in PERSONAL:
• Use down q arrow button to highlight Contrast. Navigate using the
t u arrow buttons to increase or decrease contrast intensity.
• Use down q arrow button to highlight Brightness. Navigate using the t u arrow buttons to increase or decrease overall brightness.
• Use down q arrow button to highlight Color. Navigate using the
t u arrow buttons to increase or decrease color intensity.
• Use down q arrow button to highlight Tint. Navigate using the
t u arrow buttons to adjust colors toward green or reddish tint.
• Use down q arrow button to highlight Sharpness. Navigate using the t u arrow buttons to soften or view crisper edges in the picture.
• Use down q arrow button to highlight Color Temperature. Navigate using the t u arrow buttons to select COOL (more bluish tone), NORMAL or WARM. The default setting is NORMAL. WARM mode will provide color that is calibrated to D6500° Kelvin, the standard color that broadcast stations and the Motion Picture industry consider as the most accurate to view programming.
Note: When adjustments are completed, you may select another menu by pressing the Menu button.
OK
Jan 14, 2011 | Apex Digital LD4088 LCD TV
Can"t find white or comfortable background screen other than a light green that is hurting my eyes
If you have a screen that gets "tints" of various colors on a corner or edge, check that the monitor plugin cable is not near or laying on top of a power cable, the magnetic field around a power cord will cause a monitor to get strange tints or lines in the screen. Option two if the entire screen has a tint equally all over it is possibly the color is out of adjustment or failing - a technician should be able to adjust it internally.
Apr 29, 2009 | AOpen A75PF Monitor
Magenta Color
Here is something that may help from the toshiba.com website under your model number television. Q. Why are people on my screen green?
Models: 32HL17, 37HL17, 42HL17, 42HL167, 47HL167, 52HL167, 42HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00107
If the problem is not the connections, try adjusting the tint on your television. A high tint setting will usually create a green
image on the screen where as a low tint will create a more red hue. In order to access your television's tint:
1. Press the “MENU” button on your remote control and use the LEFT or RIGHT arrow keys and select the
VIDEO menu.
2. Then use the UP and DOWN arrow keys to highlight PICTURE SETTINGS and press the "ENTER" button on
your remote.
3. Next use the UP and DOWN arrow keys to highlight TINT then use the LEFT or RIGHT arrow keys to adjust the
TINT. If the picture is too green the tint will need to be lowered.
4. Once you have adjusted the tint to your liking, use the DOWN arrow key to highlight DONE and press ENTER. The toshiba customer service telephone number is : 1-800-631-3811. I hope this helps you with your problem.
Feb 01, 2009 | Toshiba 42HL167 42 in. LCD Television
Green color
reset all color settings from the unit's menu.
disconnect any source and turn off the unit
turn on the unit and wait for the manufacturers logo to show up (and it must be BLUE).
not blue ? reseat the lamp. replace lamp if it doesn't work.
Nov 21, 2008 | Epson Powerlight 8300NL Multimedia...
Greenish tint
Not sure if this is the solution, but I believe the color polarizer filters have been burned. I have a yellow haze circle on mine and I'm pretty sure that's the problem. In my case the blue filter is burned, leaving the red and green stronger yeilding a yellow blur.
Aug 27, 2008 | Epson - PowerLite S1+ Multimedia Projector
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Big Green Bar
Hi Tom017
Does this green bar show even when there is no signal inserted into the Projector ?
If it doesn't then you can try using a different cable - that should solve this for you.
If it doesn't then you might be in for a quite expensive Mainbaord repair or replacement.
Good luck and thanks for using Fixya !
May 06, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Green color on Samsung ln-t4042
If the whole screen has this tint problem, there is nothing you can do. It must be repaired. You will need to take it in for service.
Mar 15, 2008 | Samsung LN-T4042H 40 in. LCD HDTV
Green tint
LCD projectors can have a green tint for a fiew reasons. Either the signal processor is out which can cause all sorts of funkyness, or the lcd panel itself is not seated properly. Also the memory driver for the lcd panel can be messed up in some way.
Bottom line, if you are getting a green tint even on the menu then it would be a problem you would need to have addressed by a trained technician.
For now, you can try to do a through cleaning and try to dust out the light path.
I do not know how deeply you want to dig into the thing but if you can get to it make sure the optics are clean.
Also look into the optical path while it is off and try to locate any weird films or dust. Sometimes hard to spot I know.
Good Luck.
Oct 20, 2007 | Office Equipment & Supplies
Dell 3200MP Multimedia Projector Logo
1,117 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
