Question about Oster 6678 14 Speed Blender
Blades won't turn
For some reason, my Oster blender's blades have jammed up. Even when there isn't anything in it, it won't spin anymore. The motor is running and everything else appears to be working okay. When the glass container isn't on top, the metal disk is spinning on the base. It is just the the blades that seem stuck.
Andrea
  • 1 more comment
  • huntpro13 Mar 06, 2009
    My cutter assembly still turns by hand, but barley.It won't turn under the motor's power. Should I just replace it?
  • rudy t Jul 29, 2012
    I've only had my blender for less than 6 months with minimal use and the blades don't turn
    i think it should be replaced by the manufacture.
If the problem is that the blades are jammed and you can't turn them manually, you can let it sit ( and dry out ) for a few days, or you can try adding some oil. I had the same problem and this worked. My problem now is that the blades don't reach to where the motor is turning, so even if they're not jammed the don't turn. If anyone knows and answer to this I'd appreciate it.
Posted on Feb 12, 2008
Why won't the blades turn?
One or both of the drivers are broken, check the clutch on the top of the motor and the other one on the bottom of the beaker. You will find something there worn out or broken.
May 24, 2015 | Blenders
How to fix the blender,the motor works ok but the blades don't move
check to make sure the drive stud is spinning with the motor. If it is, make sure the blade assembly is lining up correctly as well as fitting tight on the drive stud. How to Repair Blender How to Repair Small Appliances Tips and Guidelines
Dec 09, 2014 | Oster Blenders
Blades won't spin
The motor may have failed.
Dec 25, 2013 | Cuisinart Blend & Cook Soup Maker
Blades on ninja blender won't spin, but motor seems to be working.
I don't have one, but inspect the shaft, it looks like there is a key on the shaft, then inspect the inside of the blade where it goes on top of the shaft, see if it looks like the shaft has spun out the blade and this is why it's not spinning.
Remove the blade and the container, then turn on and see if the shaft is spinning, it should be most are a direct drive.
So now if the shaft is spinning, that most likely means that the blade hole is broke where it sets on top of the shaft.
Look closely at the inside of the blade, you should see some type of damage like the groves are worn, I hate to see you buy one and it was the shaft that wore, but usually the blade will go first.
Mar 31, 2013 | Blenders
Blades won't turn when cup is on
check to see if shaft is turning when cup is off if it is somthung is binding it
Sep 24, 2012 | Oster 6804 16 Speed Blender
My wolfgang puck 1.6 hp professional blender will not spin the blades if there is anything in the blender container.
This is not really the solution it is just a better description of the problem that I am also having. This is a great blender however the part where the cup blades conect to the motor is made of plastic.
So what has happened here is that the motor is fine, the cup is fine only the plastic part that makes the motor turn the blades has worn down therefore rendering the blender useless. I would like to know where I could get this small part to change on my blender!!!
Jul 30, 2012 | Wolfgang Puck 1.6 Hp Professional Blender...
My ninja blender motor starts but the blades don't turn
As stated earlier it could be the shaft needs lubing, remove the bottom part of the blender blade... the rubber thing that engages on the motor. I started with WD-40 and worked some lithium grease into it. Spins like new now.
Jun 18, 2012 | Blenders
Motor base is working and container jar base turns by hand but won't work together to spin blades
Just fixed my blender. Motor was working fine, but the bladea wouldn't turn. I removed the blade piece from the base and tried moving the blades by hand and they wouldn't turn. So, I lubricated the blade at the location where it's supposed to rotate. I kept trying to move the blades by hand and gradually they started to loosen up. All fixed!!! I guess they get stuck after a few years of use.
Aug 13, 2010 | Back to Basics Smoothie Elite Work Top...
Poor function of my Oster classic blender
Yeah, the blades probably need to be replaced. The replacement blade assemblies for most models can be ordered directly from Oster - their phone # is 1-800-334-0759 - you have to go through an elaborate menu tree to get to the right place.
Apr 03, 2009 | Oster 4093-8 Osterizer Classic Blender...
Blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 24, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Oster 6678 14 Speed Blender Logo
2,177 people viewed this question
Top Oster Blenders Experts
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Oster Blender Expert? Answer questions, earn points and help others
