Verticle hold transistor?
My Symphonic Model number WF2702 has only a thin white line across the middle of the screen. I am thinking it's something in the verticle hold module?
  • Don359 Jan 26, 2008
    Ok, My theory as well, I have a bad transistor somewhere in the verticle control. I am 100% with you-- verticle output transistor. How can I tell which transistor is bad?
  • 2,130 Answers
The vertical hold keeps a normal picture from rolling either up or down. You don't have a normal picture (raster) here.
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace.
Good Luck!
- Jim
Posted on Jan 24, 2008
I have a LG 32LH30 TV. When I power on the TV I get a picture in the top half of the screen and vertical lines in the bottom half. Also I get a thin white dashed line across the middle of the screen....
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook: a thin verticl line across the screen...
it might be due to static on the notebook
turn off the notebook and then remove the battery from the notebook press and hold the power button on the notebook for 4-5 sec and then put the battery back and then turn on and check
if the line is still there check it in the safe mode or in BIOS if its still there then replace the screen
May 17, 2010 | HP Pavilion dv6000z Notebook
No audio and have a thin white verticle line across tv
Always suspect a bad EEprom...very common on this TV! See a tech, he will have to select one of six eeproms to fix this!
Jan 10, 2010 | Philips Magnavox 27MS343S 27" TV
Horizontal line across screen
HELLO
This is called "Field Collapse". Line collapse is different (a single vertical line) in the centre of the screen.
But field collapse is usually a fault in the field circuit (possibly a field output IC has gone short circuit) or electrolytic capacitors have dried out. The same can happen in a CRT TV - looks as if LCD panels are the same way! I think you will have to take this to a service centre.
GOOD LUCK! (:-)
Sep 12, 2009 | Memorex Televison & Video
36" RCA Proscan TV no picture
LINE ACROSS THE MIDDLE IS THE VERTICLE CIRCUIT--COULD BE A LOOSE CONNECTION-TRY TO TAP GENTLY ON TOP OF SET AND SEE IF YOU SEE THE PICTURE ACTUALLY JUMP TO FULL RASTER,,IF SO LOOSE CONNECTIONS IN VERTICLE CIRCUIT---THE OTHER PROBLEMS WOULD BE ACTUALLY PARTS BAD IN CIRCUIT --IC,CAPS ETC... TUNICA
Oct 21, 2008 | RCA P52926 52" Rear Projection Television
Thin horizonal line in middle on dark screen
The several thin white lines at the top of the screen is the warning that the vertical output IC is not getting the boost voltage it needs to run correctly. The IC cannot operate for long like that and shorts out inside, which is when the vertical collapses altogether and you get the thin white line through the center of the screen. The good news for your son is that he had nothing to do with that, and it has nothing to do with the cable F connector. The set needs to be serviced by an experienced tech who will restore the boost supply and replace the vertical output IC, and when I do that I charge $75 but techs in your area will vary, so be sure to ask around.
Jul 26, 2007 | GE 24GP653 24" TV
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Televison & Video Logo
465 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
