Question about Kenmore 62602 Electric Dryer
Kenmore dryer mod:86873100
Dryer motor will not run.start button tests good and so does door switch yet motor will not run and is not hot
  • 10 more comments
  • wojo03 Jan 24, 2008
    yes there is 220 power.
    The timer motor even runs ,yet the motor for the drum still will not run.if i had a schematic I could test the motor with my meter but I am not sure of the connections with out that.
    I appreciate any help you can give.
    there is no tech sheet behind the control panel. so if you could send the schematic i would appreciate it. I want to be honest and tell you I am an a/c tech so I have a little experience I am just not sure of the wiring for the motor, and i do not wanna take apart the switch on the motor till I see what the circuit looks like.
    i still need the schematic for my problem so if you can help I would appreciate it.
  • wojo03 Jan 25, 2008
    Thanks for all of your help the problem turned out to be the fuse link that went to the motor, it is a non resetable fuse. I could not have fixed it without your help.To think the belt and fuse only cost 15.00, much cheaper then a new dryer.
  • sharlaparson Jul 11, 2008
    All aspects of the dryer works well but the motor sound like it is single phasing and the drum will not turn.
  • Anonymous Jul 31, 2008
    When I press the start switch the dryer tries to start but dies as soon as I release the switch. I checked the switch and the thermal fuse, both test out OK.
    Any advice as to what I should try next would be appreciated.
  • molly_morris Aug 21, 2008
    seems to run, yet no heat.
  • Anonymous Feb 23, 2009
    My dryer will not start but the start switch works but noyhing else will
  • dchittur Mar 01, 2009
    I have this same problem on the same model. Can you tell me how to remove and replace the fuse? Thanks,
  • robert samples May 11, 2010
    have you checked for power at the out len must make sure you have 220 there light will work if it has 110 check for 220 and let me know
    President:
  • 1,314 Answers
Take the back panel off there should be a tech sheet there with the schmetic there if not ill send you one thats the back of the control panel
Posted on Jan 24, 2008
6ya staff
SOURCE:
Our Kenmore Front loader Dryer Mod # 110.61402310 i put our clothes in the Dryer and powered it on and then Nothing wont Power on
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released. hope it helps
Feb 13, 2015 | Kenmore Dryers
Kenmore elite sensor smart electric dryer Model 110 65066500 I have power but won't start
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com Kenmore Whirlpool Dryer Won Start Easy Fix
Jun 24, 2014 | Kenmore Dryers
My Kenmore 500 mod 110.69522800 type DWSR-ELE-2406026-FM54 start button wont turn it on. How do I fix this?
I will help you please contact me [email protected] I have neen repairing appliances for 34 years
Feb 01, 2014 | Dryers
My Kenmore Dryer model # 110.65942401 will not start. The door switch seems fine. When I hold the start button in I can here the timer clicking, that's it. Any suggestions? Thanks!
Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Apr 29, 2011 | Kenmore 659 Electric Dryer
Kenmore mod 110 87870110 gas dryer- at first push
the vent could be plugged and unit is going into thermal overheat if it works in timed dry properly then the moistier sensor is faulty.
Dec 01, 2009 | Kenmore Dryers
Dryer will not run
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down
Sep 27, 2009 | Whirlpool GEQ9800L Electric Dryer
Dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
May 22, 2009 | Kenmore 73952 Gas Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Dryer stpped working
with power disconnected
if any wire disconnected before any test, reconnect & test dryer, reconnect wires after each test
disconnect wires from start button and test, conduct when pushed, no conduct when release
if fail replace start button test dryer
disconnect wires from door switch and test, conduct when pushed, no conduct when release
if fail replace door switch test dryer
follow leads from start button to relay(relay is first device connected to start button), and make sure all wires connected at both ends. If any wires disconnected, test dryer
locate thermostats and thermal fuses on fan housing and ducts
individually disconnect wires from each and test. conduct good, no conduct fail
replace any failed thermal fuse or thermostat test dryer
if all prior test OK
replace relay, test dryer
Oct 10, 2008 | Magic Chef CYE4000AWW Electric Dryer
Dryer won't stop running
The hot wire runs through the start button as a bridge to complete the circuit until the motor centrifigal switch closes the circuit when running. Now if you manually start your dryer and the timer doesnt advance keeping the dryer on until you open the door or advance the timer manually then the timer is good but the motor to advance the cam is faulted. The second scenario is that the dryer is off when the door is open, but when you close the door the dryer starts. With the second scenario we have a closed circuit at all times. At this point you have either a stuck start button or the centrifigal switch is closed. Usually it is the start button on this model.
Sep 08, 2008 | Kenmore 67082 Electric Dryer
Kenmore 62602 Electric Dryer Logo
1,979 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
