Cannon MPC200 Printer
I have a cannon MPC200 printer (3-in-one) and it says that the ink tank is nearly full. How do I go about emptying this? Can you help. Thanks
  • Takka1 Feb 04, 2008
    I have a connon MPC200 printer (3-in-1) and it says that the ink tank is nearly full. How do I go about emptying this? Can anyone help. Thanks
  • dotprint Apr 03, 2008
    my canon mpc200 is power on ,it says " Check printer press resume key", pls help me to solve it.
    Problem Solver:
  • 14 Answers
If this is an inkjet printer there is large tank below the home station that fills with ink from the machine testing & priming the cartridges. This needs to be removed and cleaned out. Very messy job! Wear gloves.
Posted on Feb 10, 2008
6ya staff
SOURCE:
Waste ink nearly full LCD ERRoR on Cannon multipass F60 printer
HiHello try ths
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 printers.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 17, 2009 | Canon MultiPASS F60 All-In-One InkJet...
The waste ink tank is full. Where is it located?
This is something that needs to be done by a service department..... however it may not be full. Cannon has a 3 year clock on these so you may be able to clear the error code and continue printing.
Waste Error Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
6: Press Power to set data
Sep 26, 2009 | Canon BubbleJet i560 InkJet Printer
Cannon pixma 1500 printer stopped printing color ink is full
Print a test pattern print first to make sure that the problems is the printer and not the file you are trying to print , then check you color cartridge if it's empty.
Aug 17, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Cannon ip90 waste ink tank is full
These is all that u need to do:
4 step to Reset waste ink tank counter CANON PIXMA iP 1000
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
There's a lot of methods and choice on how to reset it and this is all my best to share to you.
If i am helpful please rate me.
Thank you.
Yboyandrei
Aug 15, 2009 | Canon PIXMA iP90 InkJet Printer
Cannon printer MultiPass.MP390 waste ink near full the waste ink tank(which holds the ink, used for print head cleaning) is nearly full. What do I do The printer tells me this when I am using it. It says...
1)Printer on, press Additional Functions, Scan, Copy, Scan
Now you should be in service mode from there for waste ink tank reset it is simalar to what has already been posted
2)Select Test mode which is like the last avalabe selection
3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button
The menu will now say EEPRON Clear
Select Ink count which is option (0) and press set
Then press Stop/Reset Followed by the power button and then wait for it to restart.
Oct 22, 2008 | Office Equipment & Supplies
Cannon i350 error
that means that you need to empty the overflow ink tank. got the user manual?
http://tinyurl.com/6qcpgy
Aug 19, 2008 | Canon Office Equipment & Supplies
Cannon Printer
would help to know which printer model you are currently referring too.
Jan 17, 2008 | Office Equipment & Supplies
Cannon Bubble Jet 4100 Printer
Does the machine beep 5 times and flash both the power and error lamps? If so then the Waste Ink tank/pad is full and needs to be cleaned and the printer counter reset.
Sep 24, 2007 | Cannon i70 Printer
217 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
