Question about Intel D865GBF Motherboard
My D865GBF motherboard restarts after try to shut down
The problem begun when i updated the bios to P25, and i didn´t create a backup recovery. Can someone help me?? pls. Tks
    Genius:
  • 1,067 Answers
Pull battery out reset cmos cheak all your settings close in there ok power options in stuff blow dust out if u have any
Posted on Jan 24, 2008
Intel desktop d865gbf working in good condition .when i update bios did not boot and no display.
same problem as mine too.. the reason is you installed a wrong bios update program in your motherboard.. the thing i do is buy the exact brand and model of the bios of my motherboard. its easy to replaced.
Jun 30, 2011 | Intel D865GBF Motherboard
Dear Bother, I have 865gbf intel motherboard, i updated p25 but after that i have changed several bios p11 to p25 but my pc hangs some time during boot, some time doesnot display even bios information...
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then you should test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your (((motherboard to your hard drive)))
then click start all programs accessories system tools defragment your hard drive
you might have to install more RAM random access memory to check how much ram you have
to check the details on your computer
click start all programs accessories system tools system imformation you will see all of your computers imformation from there another way of doing this
click start right click on my computer select properties you will see all imformation about your computer including installed ram
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer if you see something running that you don
May 19, 2011 | Intel D865GBF Motherboard
Intel D865GBF Motherboard Reboot problem
Dear friend you know restarting is a problem can create for Power Supply, Power circuit, and Power system, Check all. Please try change the Ram also. Best Regards. Sumon (jisfy@yahoo.com)
Mar 17, 2009 | Intel D865GBF Motherboard
Hi my motherboard restarts by itself
possibly ur snps [power unit] got damaged u better replace it with a new one...
Aug 29, 2008 | Intel D865GBF Motherboard
My windows alwyas restart & recovery bios
orangmedn
pc r restart for several reason like power supply problem, over heated, os problem. if ur pc restart when u try to access any drive or insart cd or dvd in drive means ur power supply is faulty. and if it restart after a fixed time (approximately) means over heated. (u reinstall xp so operating system is not infected.) if one of above symptom r their then no need to update bios.
2nd if some problem heppen during ur bios update and it not wirte properly and u restart ur pc in this situation the ur pc can not start and result is no display condition. if it happen then contact with any mother board repear centre or mother board service centre. (because if bios program r corrupt it need to repalce or rewite).
(**2nd time if u update any BIOS be Cautious. at first take backup then update. if any problem happen then restor with backup copy, then restart ur pc. until u sure update successfully do not restart ur pc).
Jul 10, 2008 | MSI PM8M-V Motherboard
PC Freezing !
Update BIOS to P25 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=N&Inst=Yes&ProductID=948&DwnldID=10130&strOSs=44&OSFullName=Windows*%20XP%20Professional&lang=eng
Reset BIOS to default settings.
Check CPU Temperature, Prescott CPUs run hot.
If board is under 3 years old and was a retail box package, it will be under warranty, contact Intel.
Jun 29, 2008 | Intel Motherboard
BIOS update
1. Check your PC or motherboard manufacture for BIOS upgrade and upgrade BIOS firmware.
2. Try to start your PC in a safe mode by pressing F8 before windows starts. Then select a safe mode with or without network support.
3. If your computer starts in the safe mode, check if your hard drive is not full or close to full. If it is close to full you need to remove some data from your disk. Try to remove temporary files and clear your Recycle Bin. Restart your computer.
4. You might run low on your memory. If your PC doesn't have enough physical memory, windows is creating virtual memory by using space from your hard drive.
5. If neither solution works, try to run a "CHKDSK C: /R" from recovery console.
Good luck!!!
Jun 11, 2008 | Umax Computers & Internet
Intel Desktop Board D865GBF starts up as soon as I turn on the UPS
flyer2,
try to revert the switch connection on the board.
Thanks
Iqbal
Apr 06, 2008 | Intel Motherboard
Directly gets on
  • Open control panel > open the system control panel
  • in the system properties, click on the advanced tab
  • in the startup and recovery section, click the settings button
  • In the startup and recovery dialog box, under system failure, remove the check from the automatically restart option
click ok
click ok
Dec 24, 2007 | Intel D865GBF Motherboard
Intel D865GBF Motherboard Logo
158 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
