Question about Kicker S10L52 Car Speaker
Subs how do u hook up audiobahn immotals they have 4 (-) & 4 (+)
    New Friend:
  • 101 Answers
Http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
THIS SHOULD ANSWER YOUR QUESTION.
I9 USE TO BE A CAR AUDIO INSTALLER GET BACK TO ME IF YOU HAVE MORE QUESTIONS.ALSO WHAT YOPU HAVE IS A DUALK VOICE COIL SUBWOOFER.DEPENDING ON THE OHMS OF YOUR AMP ,IS THE WAY U WILLL WIRE IT.NICE SPEAKER RATING PLEASE.
Posted on Jan 26, 2008
  • chris ZAMBROTTA
    chris ZAMBROTTA Jan 29, 2008
    DID THE LINK HELP? IF SIO RATING PLEASE
I have 2 audiobahn 12 inch 500 watt awc12t dvc woofers with 2 pos and 2 neg hook ups on each side of the speakers like this (- -) (+ +) and the same on opp side i need to know how to wire them to each...
OK. Sometimes manufacturers put two flat prongs to each of the positives and negatives of the voice coils. This allows for daisy chaining multiple subs to be easier. Here is how you want to wire your subs in the box.
From the positive post of the box to the positive posts of both voice coils (just choose one prong on each of them, you do not have to connect all 4 of them). So you will have 2 wires going from one post on the box to 2 posts on the sub. Got it. Not go from the negative post on the box, to both negative posts on the subs. Repeat this with the other sub. Now you can hook each channel of the amp to the box regularly pos of amp to pos of box and neg of amp to neg of box.
This set up is called parallel and will drop the ohms resistance of two 4 ohm voice coils to a 2 ohm load. You will get 2 ohms for each sub, thus connecting one sub to each channel. This will allow you to get the max power out of the amp or 150w RMS per your post. Hope this helps.
Aug 23, 2011 | AudioBahn AWC12 Car Subwoofer
Hello..im trying to find a diagram on how to wire my subs down to 1 ohm..i have 2 12 in. Audiobahn alum12n..they are currently runnimg at 3 ohms on a hifonics 2500 watt 1 channel amp that only supports 1 2...
Hi, if you wire all voice coils in parallel, you will get down to 1.5 ohms. That is the lowest you can go with these 2 subs. Just hook the amps' positive to all 4 positive speaker terminals and the amp negative to all 4 speaker negative terminals. Please let me know if you have more questions, and thanks for using FixYa.
Mar 22, 2011 | AudioBahn Car Audio & Video
I got 8 terminals on a my 15 audiobahn sub how do i hook at 2ohm load
Yes audiobahn do make a QUAD coil, and some people get confused with the - - + + on the terminal, This is called a dual lug, Check out Audiobahn.com and go to tech suport. Thier you can look up the wiring diagram for this sub... TRUST ME hope this was helpful positive feed back be nice lol
Apr 08, 2010 | AudioBahn AW1206T Car Subwoofer
I need help hooking up a 12" alum audiobahn
check out audiobahn.com and click on the tech support. then you while see some diagrams for subs, for different ways check it out it helped me out with my aw1508x being pushed by two a2300hcx
Mar 01, 2010 | AudioBahn AW1206T Car Subwoofer
I need to hook up two audiobahn A1200Q subs to a A1300hcq amp
The amplifier is only stable to 2 ohms.
Assuming the cubs are dual 4 ohm voicecoils - a 2 ohm load with 2 subs is not possible.
You can only wire up 1 dual 4 ohm voicecoil sub (both positives to amp... and both negatives to amp) to get a 2 ohm mono load.
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 17, 2009 | AudioBahn Car Audio & Video
I have 4 gauge wire to my audiobahn2200 htc and it cuts off after a while and smells like its burning out or something. hooked up bridge and 2 ohmed. there audiobahn dub1200 sires subs
I would take an ohm meter and check the ohms on the subs sounds like you are dropping below 2 ohms.If the subs are new then that is normal its the coating on the voice coil getting hot but it will pass in time. I would recommend a 1-2 farrad cap for that set-up though.
Oct 24, 2009 | AudioBahn A2200HCT Car Audio Amplifier
Subs will not work right.
the subs coils are melted and shorting out so the amp shuts off
Apr 22, 2009 | AudioBahn AW1206T Car Subwoofer
Audiobahn sub settup
audiobahn.com has a tech support with diagrams on thier website check it out
Jun 03, 2008 | AudioBahn AW121T Car Subwoofer
Wiring subs
audiobahn.com can help you with the free diagrams under tect support
May 03, 2008 | AudioBahn A4075HCQ Car Audio Amplifier
Audiobahn 12' subs and audiobahn amp
First thing is first. What subs do you have? Audiobahn makes several kinds of 12" subs. What model sub do you have?
Without knowing this, it would be hard to recomend an amp without knowing how much power your sub can handle. Audiobahn makes from very power amps that can put out up to 5000W RMS, but if your sub can not handle that power, then you will blow your sub.
Dec 20, 2007 | Car Audio & Video
Kicker S10L52 Car Speaker Logo
24 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
hoyzee1
Marvin
Marvin
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
