Question about Haier HLH32ATBB 32 in. LCD HDTV
Help with hook up
HI I have a lcd hdmi with dvi and i got a hook up for hdmi to dvi well I don't have a dvi in any one of dvr or vhs or anything not either dish with the reciver that i have so what did i get the wrong one please help thanks for your time kerri
  • 579 Answers
A lot of people buy digital TV's only to discover that they need to upgrade the rest of their stuff as well. You can hook up the dvr and vcr with composite or component cables of course, but that isn't digital.
Posted on Jan 24, 2008
Upgraded older HD TV to a Sharp 70" smart TV & Home Theater Receiver (Yamaha RX-V575. Have AT&T U-verse HD Cable box. What is the connection sequence using HDMI cables. Searched Yamaha and AT&T sites and...
I dont know about your particular hd hookup , but I take the hdmi cable out of my dish reciever/dvr [digital video recorder] and run it straight to the hdmi input #2 in the back of my apex 40 in lcd-hd-tv
I think take the hdmi output from the at&t u-verse cable box and plug it into the hdmi input of your 70 in sharp smart tv
that will get the input signal from your cable box ,both video & audio, into your tv set.
on the back of your tv set
there should be audio outputs for home theater audio systems that would plug into the audio inputs of the home theater system.
prehaps i am wrong because you say that your yamaha is a home theater* reciever.* is the yahama more than a home theater audio system? What does it recieve?
Idea-- the salesman that you bought it from should be willing to help tell you how to hook it up.
also consider that there are many different ways to hook up vcr's and then dv recorders and dvd recorders and external 2 tera bite hard drives into my tv & dvr . I got that all hooked in & a rats nest of wires. so i can record in hd or sd,on vhs or dvd or dvr
point is that you cant hurt anything by plugging the wrong plug into the wrong jack, as long as the same type of plug goes into the same type of jack.
If its right,it works, if its wrong, it wont work until you plug it into the proper jack.
im sorry ,im 65 am not into knowing all the latest and greatest cutting edge tech ,but i am begining to catch up on my hobby, movie recording tech.
Oct 08, 2013 | AT&T UVerse
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
Mar 21, 2011 | LG Televison & Video
When I connect HDMI from a Time Warner DVR to my Vizio thru a DVI/HDMI adapter, I get no sound. I can only get sound if I use Component input (RGB+ audio R&L). Is this a DVR issue or a Vizio issue?
Use the Time Warner remote and hit the settings button twice. Scroll down to "audio: digital out" and select HDMI. That solved it for me.
The only issue I have now is that I also have component sound outputs going from the cable box to a receiver. When I turn off the TV while the HDMI cable is hooked up to both the box and the tv the sound goes out to the receiver...
Nov 15, 2009 | Vizio P42HD Television
No Pc Audio on HDMI
bad hdmi cable common problem
Apr 27, 2009 | LG 37LG30 37 in. LCD HDTV
HDMI Cable?
Hi CrysR,
Although you may not be able to locate a cable with one HDMI male end and one USB male end, it is possible you may find a solution with an adapter.
I recommend looking for an adapter that will accept USB input and output to either HDMI or DVI. If you only locate DVI, you can then add a DVI to HDMI adapter at the end.
Be aware with these extra pieces and signal transfers included, it may degrade the quality of your picture.
Thank you,
Go Ahead. Use Us.
Jul 05, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
cheak the out put on the cable box setting hdtv out put is it at 1080 i try 720 p ok
Jan 19, 2008 | Yamaha RX-V661 Receiver
Moxi box hook up to to an HDMI input
You need the dvi to hdmi cable or the 3 colored component cables.
Sep 01, 2007 | Westinghouse TX-42F430S Television
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
Protron 37" HDMI not producing sound
Check the volume control on the DVR box. This is sometimes turned down. Good Luck
Mar 29, 2007 | Protron PLTV-37 37 in. LCD Television
Haier HLH32ATBB 32 in. LCD HDTV Logo
124 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
