Question about Microwave Ovens
RV Microwave/Convection by Panosonic Model NN-8501V, touch controls go crazy when cold, indicating the AUTO DEF button is in continuous contact. CLEAR/STOP only works for a second and then AUTO DEF starts again, beeping continuously (I disconnect power cord at night to avoid be awakened by beeping). Use of a hair dryer to warm up the touch pad solves the problem until the outside exhaust allows cool air to reduce keypad temperature (I now keep the outside exhaust vent closed except when cooking). The unit was made Aug 1994) Can the touch pad be fixed (there is no obvious way to pull it off before taking the microwave out of the built-in cabinet in the RV)? Or must the touch pad be replaced? If yes, can I do it myself? (I am fairly handy with tools and even a soldering iron) Or is it easier/less expensive to replace the whole microwave (finding that model or a similar size model to fit the built in opening in the RV might be difficult though I am in Yuma AZ where thee are lots of RVers RV stores)? I joined FixYa and did get a reply from an earlier request that I was being contacted separately but no email or phone message has been received. My email is bspivy@yahoo.com, ph 509-280-9983(cell-ATT). Thanks in advance... a full time RVer, retired Army guy living on a pension so costs are critical... Bert
  • 579 Answers
I tried looking up the part number for this model and they don't identify clearly what the touch pad is. Would have to get one of the parts companys (andrewselectronics.com) to do research on it.
I've done surgery on a few touch panels and it usually works out. Have to break through the plastic tabs holding it together, then you can clean the contacts. Then do something like find little tiny screws to fasten it back together.
Hope Ya Fix It!
Posted on Jan 24, 2008
My Panasonic Microwave Dimension 4 Convection is showing FFFF in the time display when I try to use it. What does this mean?
https://www.manualslib.com/manual/652153/Panasonic-Dimension4-Nn-C988w.html
FFFF is not mentioned in the user manual, but there may be some helpful information or contact information in it.
PANASONIC Dimension4 NN C988W Operating Manual And Cook Book
This is not certain, but it may be a part that is expensive to replace according to this other web site for a similar model Panasonic oven. That person said their microwave was still working.
https://www.justanswer.com/appliance/6045n-good-day-panasonic-dimension-iii-microwave-convection.html
Good day, I have a Panasonic Dimension III Microwave/Convection Oven 1983
Model NE-9910A.
I went to use it today and when I entered to nuk my coffee a FFFF display appeared where the clock normally appears. I went and found my operating instruction booklet and it indicated to "stop/reset" which I did. Next it indicates to contact a Panasonic Servicecenter. Can you help me out? ps. It still works great!!!!!
Answered in 1 minute
12/24/2011
FFFF means that your display control board has an internal short. The only way to fix the problem is to replace the display control board which is no longer available. If you really wanted to fix the microwave you'd need to remove the display board and mail it to a place like Appliancetimers.com to have the part refurbished. The cost to have the part repaired is usually about $200-250 or so.
---------------------------------------------------------- Good day have Panasonic Dimension III Microwave Convection
May 10, 2018 | Panasonic Microwave Ovens
Panosonic Microwave convection Model NN-8501V Touchpad appears dead
The unit has a fuse in the power board, but when the fuse is gone it does not even start up. If it starts it is not the fuse.
Look rather a problem with a faulty touchpad, or the magnetron that is not working and need to be changed.
Check also the door sensor.
Oct 03, 2008 | Microwave Ovens
Need user manual for National model no: NN-8655 Microwave oven user manual...
I would suggest that contact the dealer from whom you purchased the oven or call any number listed on the model tag of the oven.
Jan 06, 2014 | Panasonic Microwave Ovens
NN 8501V Panasonic Dimension 4 Convection/Microwave oven keeps blowing fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
Apr 16, 2013 | Microwave Ovens
I have the same problem with Panasonic NN-8501V Microwave Oven
I took the touch pad control unit apart, clean the connector for the ribbon wire connection between the key pad and the control unit, reseated the ribbon wire in the connection. Everything worked like new.
Oct 16, 2009 | Panasonic Microwave Ovens
Instruction book required for High-Point microwave/convection
Here's a roundabout way to help you:
You can find a different High-Pointe RV microwave owner's manual here.
That manual should have contact info to help you get in touch with High-Pointe to get a new one, or it may be close enough to your model to work for you.
Nov 24, 2008 | Microwave Ovens
Our NN-8500/NN-8501V Micro/Convection is no longer repairable
hi Peggi and john, have a look here for repairs and new in Dallas TX area:
http://www.superpages.com/bp/Dallas-TX/Affordable-Appliance-Repair-L2069127442.htm?SRC=portals&C=Range+%26+Oven+Sales+%26+Service&lbp=1
regards from the UK :)
Nov 21, 2008 | Panasonic NN-T888S Convection/Microwave...
Microwave beeps for no reason. Panasonic NN-8501V
There may be an F type fault code on the display, or the display may reflect that a key has been pressed when it has not.
If you can supply more details along those lines, that can help in the diagnosis.
The rest of the answer assumes you have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can order Panasonic parts from Tritronics, but if you don't find what you're looking for there, try here.
Or you can find an authorized Panasonic servicer here.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Nov 05, 2008 | Microwave Ovens
Panasonic NN-8501V Convection beeps on AUTO DEFROST when cold
I'm replying privately with complete details.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 13, 2008 | Microwave Ovens
Microwave Ovens Logo
251 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
