Question about Kenwood KAC-848 Car Audio Amplifier
Kenwood kac-848 My amp is not working I have sound out of one channel but when i touch the other one my stereo cuts off and starts over again. the other two channels the speaker just move no sound. This all happened when i turned my volume up the louder the amp stopped I changed one of the ohm it worked and then it happen again. The problems i said earlier is now waht happens
  • Mark Payas
    Mark Payas May 11, 2010
    pls clear your problem sir so we can understand it.
    Sergeant:
  • 203 Answers
You have blown outputs , faulty channels. What kind of amp do u have and what were u running to it? Most likely a bad amp, u might need a new one.
Posted on Jan 28, 2008
How to bridge a kenwood kac-9105d
Are you referring to something like this, using two different amps? It is a mono amp, meaning there's one amp in the box.
"KAC-9105D also has a Dual Mono Drive connection that allows you to strap two KAC-9105D amps together to power a single subwoofer."Quoted fromhttp://www.kenwoodusa.com/Car_Entertainment/Amplifiers/KAC-9105D
Here's a link to a page out of the Yamaha Sound Reinforcement book. the top shows a stereo amp (1 box, two different amps inside) hooked up to drive two different speakers, which is known as 'stereo' mode.It then shows the two amps hooked to the opposite sides of the same speaker, which is known as 'bridge' mode.http://books57.net/ampOuts.gif
Any help?
Feb 24, 2012 | Kenwood Car Audio & Video
What is the rms outpur of my kenwood KAC 848 amp
rms at 4 ohms is 50x4 in 4 channel mode if your in 2 channel mode then its 150x2 if at 2 ohms then it would be 4 channel 75x4.
Jul 28, 2010 | Kenwood KAC-848 Car Audio Amplifier
Leads for old kenwood car stereo amps
Hey wdalley69, I've got the KAC-8070. My setup has the crossover module for it.
Oct 27, 2009 | Kenwood Car Audio & Video
The subs aren't pushing out bass.
Hello crobins2,
The Kenwood KAC-6202 2-channel is only rated for 60 watts RMS per channel into a 4 ohm load. That just isn't much power for a pair of 12" subs. Even the bridged output is only 200 watts into 4 ohms, still at the low end for a sub, much less to share between a pair of subs.
Assuming that your subs are 4 ohm, you could probably get more sound by driving just one of them on the bridged terminals. But to get the best power with what you have, connect one sub to each channel, set the filter switch to the far right (LPF), set the operation switch to stereo (both channels driven), set the filter frequency (Hz) to 100 or lower, and adjust the input sensitivity as far clockwise as possible without causing distortion.
But, to do the subs justice, you really need at least 300-400 watts to share between them.
Hope this helps.
Sep 27, 2009 | Kenwood KAC-6202 Car Audio Amplifier
I have a kenwood kac-8452 4 channel amp that makes the speakers pulse after the volume gets turned up to 10. I also have a kenwood amp doing the same thing with my subs. any ideas?
Its not pulsing, its called clipping. The sound is being clipped due the amp being pushed past is power capacity and distorting the signal. This will damage your speakers very quickly. No amp should be turned more then 3/4 up. If its not loud enough you need to purchase a larger amp or be comfortable with the wattage it produces at 3/4 volume. You may also have speaker wires touching/crossed causing th issue.
Sep 10, 2009 | Kenwood KAC-8452 Car Audio Amplifier
My sons kac 848 amp just stopped working
There is an Internal Fuse on Most of these Models that will blow from time to time. You might also check the Ground Connection. A loose Ground can cause the Same Problem. Please Rate My Response! Thanks!
Feb 02, 2009 | Kenwood KAC-848 Car Audio Amplifier
Kendwood kac-848 audio problem
Are you sure you have the speakers wired to present a safe load to the amp?
Aug 11, 2008 | Kenwood KAC-848 Car Audio Amplifier
Schematic
Try manualsparadise.com or go to the Kenwood web site and look in the support section.
Dec 18, 2007 | Kenwood KAC-848 Car Audio Amplifier
Kenwood KAC-848 amp not working
It sounds like the amplifier is going into protection mode. This is generally due to shorted output transistors but can also be caused by shorted wiring. Disconnect all of the speaker wires and signal cables from the amp. If it still does the same thing, confirm that you have adequate voltage across the B+ and ground terminals (at least 11 volts DC). If the votlage acrosss the terminals is OK and the light still flashes with no speakers connected to it, the amplifier is in need of repair.
Oct 11, 2007 | Kenwood KAC-848 Car Audio Amplifier
Car Audio & Video Logo
136 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
