Question about Supra SW5L65D Front Load Washer / Dryer
Problem in starting
My machine is not working, actually i didnt use it for more that 2 years
whaen installing it now the switch is on but the programms are not working
the timer seems to be not working , i tried all the programms and no solution , even the water is not coming inside ,
  • elsaronnie Apr 30, 2008
    For some reason the water will not fill. The dryer works fine.
We bought a Supra three years ago, and it is nothing but a
piece of junk. We have paid our last dollar to repair this mess.
Posted on Feb 05, 2008
  • 126 Answers
Try to replace the doorlock with a new one. Worth a try.
Posted on Jan 24, 2008
I hv nokia 2700c having restart problem. its screen become white and phone is switched off. reinstall software didnt work. what is the actually problem?
Hello Jeetunav,
It seems that your phone memory card contains the virus.So scan your memory card using the anti virus installed in your machine.You can scan you memory card for antivirus using the Avira anti virus.Please download the anti virus from :
http://www.avira.com/en/free-download-avira-antivir-personal?
Download the .exe file from the link.
Install the software in your computer. Remove the memory card from the phone and connect in your machine using the memory card reader and scan the card for viruses or malwares.
Aug 16, 2011 | Nokia Classic 2700 Cell Phone
1 1/2 yrs ago a mechanic replaced the oil pump on my 89 f-150 and now it is beginning to knock every once in a while (it comes and goes). i suspect he didnt change the oil pump screen could it be that or...
Actually the rear main bearings are known to be noisey. For a long time ford could not use a knock sensor because the engine had so many to start with. Your truck could run for years with this noise.
Jan 05, 2011 | 1989 Ford F 150
Will not turn on . started filled with water then shut off and will not power up now. it still has water in machine this washer is a little over one year old .
Sounds like the timer motor didnt engage. Soon as the fill switch activates, when its full, the timer motor advances forward and starts the cycle. Since the water stops when full. Then part of the switch is working. The one that is nc at same time the one that is no engages. Try advancing the dial couple clicks into the cyckle then pull back out.
May 31, 2010 | Washing Machines
My washing machine is leaking water even with the water shut off and the amchine not running. Is this a drain pipe problem or a oump proplem or another problem?
Hello there
whaen awashing machine does not stop putting water into a machine even after it has stopped then this means that the water fill valve needs to be replaced or repaired this valve has 2 small solinoid valves on it one for hot and one for cold and over time they will start to fail and the result is water entering the machine even after it is off looks like this b9e1869.jpg
May 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
No power to the display. Have changed fuse and
It is possible that the display is damaged, due to a steam leak in the machine, remove display and check for corrosion on board.
Mar 06, 2010 | Gaggia Titanium Espresso Machine
When i write a message and then i try to send it,
check wid ur msg setings..jus contact ur customer care sentre abt it..try doin wid less words and actual meaning.mayb dn smthin wid d msg settings. go to menu..messages..settings and change.
complete d msg wd proper info..
Feb 10, 2010 | LG GW520 Cell Phone
Supra SW5L65D Front Load Washer / Dryer Logo
125 people viewed this question
Top Supra Washing Machines Experts
Andrew Taylor
Andrew Taylor
Are you a Supra Washing Machine Expert? Answer questions, earn points and help others
