Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
MyBook 500GB Home Ed hangs WinXP SP2 boot up process
MyBook 500GB Home Ed connected to WinXP SP2 box via firewire. When I turn the box on, MyBook won't let Win XP SP2 boot up. I get as far as the "WinXP flag" boot window - but then it hangs. Only works if I plug in the MyBook *after* I get to the WinXP login screen. Not very convenient. Any hints how to solve are appreciated. Thanks.
  • 4 more comments
  • cannoncocker Feb 05, 2008
    I have the exact same problem and have been shutting down and then have to boot up with the last known good config. I've checked the bios and don't even see the My Book listed.
  • stealth57 Feb 27, 2008
    Same issue here. My Book isn't listed in the BIOS and neither is any legacy USB drives, which are known to conflict with My Book. I got all the way to Level 2 support and all they offered was to return it. Clearly, this is a major issue and WD knows it.
  • lemun Mar 05, 2008
    same problem with 1tb home my book.
  • Anonymous Jun 16, 2008
    I have the same problem with a 1T Essentials Edition (USB only). Will try disabling USB Legacy.
  • Anonymous Jun 17, 2008
    Mine developed this exact problem yesterday, after months of working fine. It's connected by Firewire so legacy USB shouldn't be an issue, and in any case I didn't change anything in the OS config (or BIOS, which I've never touched at all) between the last successful boot and shutdown. XP will boot into Safe Mode but doesn't see the MyBook there (which I'll have to investigate further since I have Norton Ghost write all its files on the MyBook and need them to be restorable in an emergency). If I plug it in after booting, Windows Explorer (file browser) gets an error on access and has to close (and then DrWatson does too). No errors about it in the Event Viewer, although there are some error 51's on partition D (a PC Angel partition on the main hard drive), but CHKDSK on that finds nothing. Does this mean it's actually the MyBook that's going bad?
  • jcradio Jan 23, 2009
    My 500GB MyBook Home ed drive started doing the same thing over the last six months. I had it connected to my previous computer via firewire, and it was booting slow. I thought it was the age of the machine. I built a new one, that booted in record time. When I connected the drive via firewire and installed the software, it would not recognize the drive. When I connected other firewire devices they worked fine. So I switched over to the USB cable. Worked fine for about a month and a half and now the system goes to a black screen during cold boot. Need to warm boot to get it to go, and sometimes the drive just disappears. I'll try some of the suggestions, but this is indicative of some issues I had with some of their internal drives, in the past. This may be the sign to steer clear of WD in the future.
Try disabling the "1394 Connection" in the "Network Connections". It seemed to work for me.
Posted on Jun 10, 2008
Thanks to Guest above. I was having the issue with USB of my WD drives causing the system to hang upon boot up. Disabling USB Legacy did the trick. It's only my WD externals that were causing me the issue but no mor
Posted on Jun 08, 2008
To allow your computer to boot with MyBook attached, disconnect the MyBook. Boot the machine. Then go into BIOS system setup.
Look for Legacy USB setting and set it DISABLE. Do not use AUTO. Connect MyBook and enjoy!
This works for me after much trial and much error!
Posted on Jan 15, 2011
Followup to my June 17 "same problem" comment above:
Although it got fixed at the time (without rolling back XP or any other drastic solutions), the problem showed up again a few months later and gradually got worse. By November I realized this was due to the drive hardly ever spinning up, and by December it wouldn't do it at all. I suspect the controller or a weak internal power supply, because the rare times when it did come alive, the files on it were fine.
So if you are experiencing this problem, I would consider it early warning of component failure, and either send it for repair or make sure you always have alternative copies of whatever data you keep on it. And if you have backups on there, encrypt them in case you have to send it out. There have been a number of reported cases of refurbished or "scrap" drives being sold with the previous owner's data still on them.
Posted on Jan 29, 2009
  • 4 Answers
I was experiencing the same symptoms with a My Book Home Edition 1Tb drive.
I use XP SP3 and was getting the same boot hang.
Right click on My Network Places and select Properties
If you have a 1394 connection listed, right click on it and select Disable
now reboot with your firewire drive running.
This fixed the problem for me. No bios update, no disabling USB legacy Support, or USB boot option, or anything else (these are turned ON in my bios currently)
Posted on Jan 05, 2009
I uninstalled the drive, rolled back xp to pre install. Updated my bios (ASUS m2npv-vm motherboard). reconnected using firewire again and now it works ok. On the 1st install I changed the drive mapping as soon as I had connected. this time I left it, rebooted and once it was working then I changed the drive mapping. Now it works fine.
Posted on Mar 06, 2008
Remove the support for USB legacy, that will do the trick, at least for USB connection. I don't know about FW, if someone knows please tell, because FireWire is much faster...
I had a similar problem that I think I've sorted now. I'd bought a new disk (MyBook 750GB) and copied all my documents from an existing external drive to the new one. I removed the old disk and used Administrative Tools>Computer Management>Disk Management to assign the old drive's letter (G:) to the new one. After that, when I booted the computer it would hang indefinitely at the xp logo. I solved the problem by plugging the old drive back in and using disk management to give it a new letter (P:).
As far as I know, once you've got to the xp logo, you're already booting off your main drive so editing the bios won't help if that's where you're hanging.
Posted on Mar 01, 2008
  • 3 Answers
Make sure that you don't have this disk listed in your system BIOS Boot Sequence. Remove it if it is listed, some drives still want to act as boot drives even if not listed.
Posted on Jan 25, 2008
Screen goes blank after booting with WinXP SP2 CD.
Hi, your will need to delete your windows XP re format that part of your hard drive, then re install XP
Jul 04, 2010 | Microsoft Windows XP Professional SP2
E-machine C2881 runs good with winxp sp1 hang winxp sp2
Press F8 repeatedly after turning on power and select safe mode. Then go to ctrl/panel - add/remove apps and remove sp2. Reboot.
May 16, 2010 | FIC Crusader VC37GV (73-40682-00)...
Dropped the TB from about 2 feet onto the lights up, does not open but requires me to remove hardware, it has everything I have ever done in the Army on it, plus pics....I have a 500GB drive as...
Let's try to recover the data because the cost for disaster recovery is unreasonably high, approaching a thousand dollars.
Do not take the drive to any national computer supply stores/chains. The geeks will format the drive, if they get a chance to do so (and tell you to restore from backup).
These steps will not further risk losing your data.
You may also need to request "FixYa Premium Support".
Please keep in touch via comments or a new post and refer to "Gort007" if you need to contact me.
Read Options A and B completely before deciding which to do.
A. This requires opening up the unit.
1. Unplug all cables from the drive.
2. Open the WD World book
3. Re-seat the data and power connectors.
4. Check the connections again. Re-seat the data and power conenctions, again.
5. Carefully re-assemble.
6. It should work, if not do the steps in "B."
B. This does not require opening up the unit:
1. Purchase Avanquest Partition Commander ($50). Other experts may suggest a different or free utility. I trust Partition Commander.
2. Purchase a 500GB (or enough to copy your data) hard drive or another WD My Book, or any other external USB (or eSATA if your computer supports it).
3. Connect the NEW disk and delete all of the partitions. This is the NEW disk or external drive.
Do not create any partitions on it. The "Partition Commander" will do it.
4. Connect the damaged WD Mybook to the computer and boot the computer with the Commander CD.
5. A list of the disks will appear after selecting the default menu selections.
6. If the Mybook does not appear, then this option will not work until the steps in the "A." section above.
7. Copy the Mybook partition to the new hard drive.
8. If unable to do so, then try to browse the Mybook and copy folders to the new hard drive.
9. At this point yu may have to create a new partition on the NEW drive in order to copy your data to it.
10. If this does not work for you, please either do the seteps in "A." above, or explore Partition Commander more.
11. Partition Commander will triple check with you to be sure you do not do any steps that you didn't mean to.
12. Do not format your damaged drive, even after you recover the data. It is your ultimate backup.
Oct 08, 2009 | Western Digital MY BOOK HOME 1TB EXT...
WD Hard Drive Not Detecting
Yes, this can be done via the user web interface, by typing in mybookworld or wdstorage into the web browser and the shared storage manager should come up. If you go to general setup there should be an option to update network settings.
Oct 31, 2008 | Western Digital 500GB My Book World...
Integrate SP2 in WinXP CD
Step 1
Create 3 folders - C:\WINXPSP2 C:\SP2 and C:\XPBOOT
Step 2
Copy the entire Windows XP CD into folder C:\WINXPSP2
Step 3
You will have to download the SP2 Update, which is 250MB.  Rename the Service Pack file to XP-SP2.EXE  Extract the Service Pack from the Run Dialog using the command:  C:\XP-SP2.EXE -U -X:C:\SP2
Step 4
Open Start/Run... and type the command:  C:\SP1106\update\update.exe -s:C:\WINXPSP1
Click OK
Folder C:\WINXPSP2contains: Windows XP SP2
How to Create a Windows XP SP1 CD Bootable
Step 1
Download  Code:  Code:
( no download manager !! )
Extract file (xpboot.bin) in to the folder C:\XPBOOT
Step 2
Start Nero - Burning Rom.  Select File > New... from the menu.  1.) Select CD-ROM (Boot)  2.) Select Image file from Source of boot image data  3.) Set Kind of emulation: to No Emulation  4.) Set Load segment of sectors (hex!): to 07C0  5.) Set Number of loaded sectors: to 4  6.) Press the Browse... button
Step 3
Select All Files (*.*) from File of type:  Locate boot.bin in the folder C:\XPBOOT
Step 4
Click ISO tab  Set File-/Directory length to ISO Level 1 (Max. of 11 = 8 + 3 chars)  Set Format to Mode 1  Set Character Set to ISO 9660  Check all Relax ISO Restrictions
Step 5
Click Label Tab  Select ISO9660 from the drop down box.  Enter the Volume Label as WB2PFRE_EN  Enter the System Identifier as WB2PFRE_EN  Enter the Volume Set as WB2PFRE_EN  Enter the Publisher as MICROSOFT CORPORATION  Enter the Data Preparer as MICROSOFT CORPORATION  Enter the Application as WB2PFRE_EN
* For Windows XP Professional OEM substitute WB2PFRE_EN with WXPOEM_EN  * For Windows XP Home OEM substitute WB2PFRE_EN with WXHOEM_EN
Step 6
Click Burn tab  Check Write  Check Finalize CD (No further writing possible!)  Set Write Method to Disk-At-Once
Press New button
Step 7
Locate the folder C:\WINXPSP2  Select everything in the folder and drag it to the ISO compilation panel.  Click the Write CD Dialog button.
Press Write
You're done.
Oct 19, 2008 | Computers & Internet
Mionet is not showing up after login
Go into task manager, kill all Mionet processes. Then start it again from the start menu. You should now have access.
Yes it's the Mionet's rubbish.
May 17, 2008 | Western Digital 500GB My Book World...
Installing Firewire 400 on a Western Digital 500gb external My Book Pro
Don't connect the USB and firewire at the same time, use one or the other. In general for USB, for the very first connection, it is better to have the computer fully booted, and the MyBook spun up, before connecting the USB cable. After that, you can boot the computer with or without the MyBook connected or turned on. For the firewire connection, check your manual for the correct order of connection and power on.
USB and firewire 400 are roughly comparable. USB is theoretically a little faster, but you will see little difference. There are other factors that can affect your actual performance, so your best answer is to try a test yourself. Time a copy of a very large file, and a copy of a folder with a very large number of files.
Dec 03, 2007 | Western Digital MyBook Pro WDG1T5000 500...
XP-SP2 hangs on boot after installation
I think maybe better uninstalling driver, but leave card in and boot system and let windows find the card(hardware) first instead of wot sounds like windows looking for driver and freezing in the boot up process as it will look for a connection to internet for an update or driver. Normally any usb periferals should be connected after driver installation, but any pci or agp cards inserted first, then driver.
Nov 05, 2006 | X-Micro Technology XWL-11gCAG 802.11g/b...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
1,459 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
