Question about Motorola Mobility RAZR V3
RAZR is frozen
When I power up the Razr, it goes to the screen which asks for an unlock code, but it won't take any input from the keypad. Tried removing battery while it was on and replacing etc. Any hope? I really need my numbers and pix of my son that are in the phone.
  • 1 more comment
  • mikesky Jan 24, 2008
    I am having a similar problem. When I power up, the screen remains frozen with "No Service" shown on the display, None of the keypads function except when I turn on the phone. I cannot turn off the phone using the keypad. I can only remove the battery to shut it off. This morning, I called Customer Service and they could not assist me. There's a lot of contcats that have my current cell number so I would like to be able to restart this phone. Any ideas to restart the phone would be appeciated.
  • Darryl J Rasmussen Jan 26, 2008
    Thanx bajanguru. Is there a way to retrieve phone numbers and pix before getting it repaired which will likely cause loss of those? Remember keypad doesn't work.
  • safari_troy Apr 20, 2008
    have same problems i like so need my numbers and pics
    Brigadier General:
  • 7,752 Answers
What you both need to do is take the phone to a mobile service center and have them replaced the flexcable on both phones for you and that will correct the issues that you have at present.
Posted on Jan 25, 2008
6ya staff
SOURCE:
I got an old razr v3xx from pawn shop but it has a subsidy code on it i cant get into the phone i tryed all 0000 didnt work tryed 1234 didnt work can anybody tell me how to remove it or reset the phone...
The mobile is locked with a particular network.You need to remove that restriction.You have tried the default unlock codes meant for the keypad lock.To get the unique unlock code(subsidy code) for your Motorola Razr V3XX from Theunlockspot.com wherein you need to specify the country and network to which the mobile is locked to.You will receive the unlock code along with free unlock instructions.
Apr 18, 2013 | Motorola Mobility RAZR V3xx Cellular Phone
Unlock for motorola razr
You can unlock your Motorola Razr using unlock code. You an get the unlock code from www.Prounlocking.com at affordable cost with complete guidance on unlocking process.
Jun 16, 2012 | Motorola Mobility RAZR V3
I have a Motorola Razr V3r mobile phone.The only key that works is the power up key & There is no display.Changed display,keypad & flexible keyboard connector.Still no joy .Any suggestions
Hi, No one will give you free unlock code for your motorola Razr v3r mobile phone unlock code
but you can get motorola Razr v3r mobile phone unlock code at cheapest rate from others or 100% money back guarantee from this third party Thanks http://motorola.imeiunlockcode.org
Hi, No one will give you free unlock code for your htc wildfire but you can get htc unlock code at cheapest rate from others or 100% money back guarantee from this third party Thanks http://htc.imeiunlockcode.org
Oct 14, 2011 | Motorola Mobility RAZR V3
Motorola RAZR V3 phone's keypad accepts no input, but lights up.
The keypad of the phone controls both power and the numbers on your phone..
It needs to be replace.It's still useful for usage,it can be fix..take it ti a repairer...
Feb 10, 2010 | Motorola Mobility RAZR V3
Razr V3 keypad disfunction
I found free assistancer and fixed the phone from different chat rooms. You're just another site that's trying to make money rather than help people out; I won't use your site again and I won't refer anyone.
Thank you
Oct 08, 2008 | Motorola Mobility RAZR V3
Accidentally locked my razor keypad
If you have not previously set a security/lock code, when it asks you to input the unlock code, enter in the last 4 numbers of your cell number. If that does not work, you can use 0000, 9999, or 1234. Those are most common used default codes. If that doesn't work, see if your phone will allow a network update with *228 or *22899 followed by the send button. If a network update goes through, that will usually reset the code back to default if you had ever changed it, then try the last 4 of your cell number again.
Sep 13, 2008 | Motorola Mobility RAZR V3
Motorola razr freezing
your phone problem is the keypad flex of your phone'
you can fix it by replacing the keypad flex'
motorola dealer has the keypad flex'
ask for a skilled cellular technician to re-place your keypad fle..
i hope it will helf to your prob...
Jan 07, 2008 | Motorola Mobility RAZR V3
Keypad frozen
try a new battery if still can't swtch on then your flex is faulty need to be replaced by a cell thech.
good luke.
Dec 07, 2007 | Motorola Mobility RAZR V3
Keypad goes to voice recorder
try and shock the phone take battery out while phone is on then preform a master reset def code is 000000 that wil set phone back to defalt settings
Sep 23, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
27 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
