Question about Ovens
Oven Overheating with Fault Code F1 displayed after reaching temperature.
Jenn-Air JDS9860AAP Dual-fuel range
I have read much about the F1 fault code. Most postings indicate that there should be a secondary code (two extra digits) that my oven doesn't display them- just "F1". The oven seems to be very hot when it shuts down almost as if the sensor has failed (control panel is hot to touch).
From my research, I have been pointed in the direction of replacing either a faulty keypad or ERC/ clock. Since the ERC/clock is one unit on this model that narrows the possibilities; however, the ERC/clock board is very expensive compared to the sensor and I have read they don't fail much. Is it worth checking the temperature sensor first. I would probably buy both parts and return the ERC if not installed since this is a rental property and I need to fix it fast for the tenants.
The oven is about 8 years old. Does it make sense to replace the temp sensor even if the problem turns out to be the clock? How long do they last on average?
  • 3 more comments
  • Bakes6040 Jan 24, 2008
    I'll try it. Won't get a chance till next week. I'll let you know how it goes.
  • Bakes6040 Feb 07, 2008
    I am using your Jenn-air service manual you provided to troubleshoot my touchpad (F1 error) problems. The touchpad actually appears to be working fine for a while. After heating up for about 30 minutes, I get the F1 error. I notice that the touchpad area right above the door is hot to the touch. I noticed that the fan ( small cooling fan in rear electrical panel area not the convection fan) in the rear of the oven is not running while it is in bake mode. Should it be running right now, and is my problem likely that the touchpad is overheating because it is not getting cooled. Any ideas on how to troubleshoot the fan.
    Also, I have ohmed the temp probe already and it checks out fine.
    Thanks.
  • ovenowner Aug 28, 2008
    I have a WW2780 dual built in oven. While away on vacation my cat sitter said the oven kept beeping. So, it was not in use when it started. I have an F1 code and oven warms to a low temperature without commanding it to do so. Any ideas on how to fix it?
  • Anonymous Dec 07, 2008
    I have a similar problem. My oven is Ok at temps up to 400. If I go higher, it runs up to temp and is Ok for about 30mins then the whole oven shuts down. There are no error codes but the control panel seems very hot. I hav eto re prgram teh temp and start again and it does the same thing.
  • Swill777 Jan 26, 2009
    I have the same issue with my JGW8130DD oven.. If I set it for 550deg, it will reach 550, then it seems the oven never turns back on when its supposed to, to keep that temperature... if you bress bake, it will show the temp is lower, 450 or so, and it never heats back up. I have also noticed that the supposed built in fans on top never come on?? is the control panel overheating and causing the oven not to work? the oven and broiler fire up every time when the oven is cool, so I know its not the ignitors.. any ideas??
    President:
  • 1,314 Answers
It varies first thing to do is check the connections if there is a plastic ribbion on yours can clean it with a pencial eraser unplug the wires and plug them back up a couple of times in case there is some restiance there now by sensor i assume you are talking the oven probe some where on your range you will find a techsheet that will tell you how to ohm the probe and they dont always
show the right code that should help let me know what you find ill be here
Posted on Jan 24, 2008
  • robert samples Jan 24, 2008
    do that please ill be here for additional help
6ya staff
SOURCE:
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
What does F1 mean on the display panel on my Jenn Air gas oven? It won't allow me to heat up the oven, and the igniter is fine.
F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode or
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor gotsta be within spec or it will cause the F1 code. As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode. This is equivalent to 350°F in the oven. The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit). The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms. The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness, harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad. If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously. If the F1 code is given immediately (instead of during or after a heat cycle), remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes, then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner. The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied, the surface material can break down causing shorts. If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel -don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Hope this helps.
Jun 03, 2011 | Jenn-Air Ovens
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-air w156, displays f1 fault code. how do i
This is a Defective touch pad or membrane
Replace touch pad or membrane (this problem is usually the touch pad)
Jun 17, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
F1 fault code on Jenn-Air jwg 8130
hi,
The F1 ErrorOn a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
Disconnect the power
Gain access to the back of the ERC
Disconnect the ribbon cable that connects the ERC to the touchpad
Check nothing will short when power is reconnected
reconnect the power and switch on
Watch for F1 and listen for the beep
If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
or follow the link for more info:
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-ranges.html#Admiral
thanks for your question.
Jan 03, 2009 | Jenn-Air JGW8130DD Gas Single Oven
F2 fault, continuous fan after clean cycle for Jenn-Air electric convection wall oven. I haved turned off power at breaker and restarted. Fault reoccurs. Oven is definitely cool. It has been 36 hrs...
The "F2" means the oven control senses runaway temperature. The cause of the problem could be the oven sensor, the oven sensor wire harness or the power relay board.
PS:please disconnect your oven from power supply completely before continuing.
Open the control panel and measure the oven sensor resistance at the control board. It suppose to be about 1100 Ohms at the room temperature.
If the reading is wrong do the same test at the oven sensor connection (where the sensor wires goes through the back panel).
If the reading is still wrong - replace the oven sensor.
If the reading is correct, check the wire harness and the connector itself (it's better to eliminate the plastic plug and hardwire the oven sensor).
If there is nothing wrong then the power relay board has to be replaced.
Nov 07, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
824 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
