Question about Toshiba TZ50V51 50" Rear Projection Television
Toshiba TZ50V51 - Power light flashes, tv won't turn on
Hi, I know this has been posted but so far I've not found a reason for this. If I unplug it it takes a bit longer for the solid red to start flashing. I don't know at present how long it flashes, it appears to be continuous.
I hear the power trip on but nothing other than the red flashing happens. Can this be the fuse people have mentioned (I wish!) or am I looking at an expensive repair?
Thanks!!
Jim
  • jpierce237 Jan 25, 2008
    Thanks Slinteriors,
    Unfortunately I can barely hold a soldering iron let alone repair a power supply. My reason for posting was mostly to determine the problem and potential repair cost. While the TV is hardly state of the art, it's got a good picture and the kids love it...hate to dump it without at least looking into the repair.
    Thanks again!
    Jim
  • Toshiba Master
  • 8,617 Answers
It is hard to say Toshiba is one of the few manufactures that have good step by step procedures for diagnosing ad repairing your television. There is a manual called Toshiba power supply and shutdown circuit troubleshooting. This is a valuable asset to save hundreds of dollars on repair. You can get this manual at the following link it has your model covered in it for 10.99. It is on page 2 of the toshiba section bottom of page. They will even email it to you if you are interested in trying to repair your own set. Hope this helps here's the link.
http://servicemanuals.vstore.ca/
Posted on Jan 24, 2008
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Tv problem
Hi
Tell me the model no and brand name so that we can help u ya.
Turn off the tv for five minutes and then turn on.
thank you
Oct 09, 2008 | Toshiba TZ50V51 50" Rear Projection...
Describe your WD-62725 62 in. Rear Projection HDTV-Ready Television Problem Green light is blinking the TV won't turn on. We've unplugged it and tried to push the reset button and the green light...
If the led light flashes green continuously, the fault came from the DM power supply. The faulty parts there are the electrolytic capacitors. Let me know if your handy with electronics and I will assist you to fix it yourself.
Jdvillanueva
Sep 16, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Toshiba TZ50V51 powering down...flashing led
Resolder all pins of Z801 on power suppy board.
If that didn't fix it post back.
Jun 17, 2009 | Toshiba TZ50V51 50" Rear Projection...
Toshiba Rear Projection TV Problem
common problems on toshiba are the stk ic and it is not ease to replace them you will need a technician
Sep 15, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba tz50v51 problem
Hi!
Seems that it's not a well-known problem, but I'm adding a link to the "troubleshooting" part of the manual - hope it will help!
Aug 09, 2017 | Toshiba 51H83 51" Rear Projection...
Intermitant failure with blinking light
Is your tv a Toshiba TZ50V51 ? If so, You can get the manual to trouble shoot your toshiba for 10.99 at the following link. It is called power supply and shutdown circuit trouble shooter. It covers your model number. It has step by step instructions to get your set up and running. It is located on the bottom of page 2 in the Toshiba section if your interested.They will also email it too you instantly, If you return to the site and leave your email address. This is a good manual. I have used it myself many times. Here is the link, If you're interested in it.
Oct 20, 2007 | Toshiba TZ50V51 50" Rear Projection...
Toshiba TZ50V51
Small dog or large==coincidental/unrelated to problem!General service includes some very precise soldering==requires chassis pull. One or more micro-fuses will be bad and STK IC's should be replaced.Alignment in servicer menu may be needed after repair completed.
Oct 03, 2007 | Mitsubishi WS-55807 TV
Toshiba TZ50V51 50" Rear Projection Television Logo
149 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
