Toshiba Tecra M7 Tablet PC Logo
Posted on Jan 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tablet pc rotation
Ever since I accidently hit some certain combination of keys (a keyboard shortcut), my tablet PC has not rotated it's screen properly.
I've tried pressing the button on the screen, but that does nothing.
Please help if you know which keys to press!!!
Stiff Screen
  • Anonymous Mar 31, 2014
    How can I get this repaired. When trying to turn on tablet the on and off button dropped down inside the tablet. Also two keys on keyboard fell off
Roshan Rijal
Level 2:
Sergeant:
  • Expert 361 Answers
  • Posted on Jun 13, 2009
Roshan Rijal
Expert
Level 2:
Sergeant:
Answers
361
Questions
Helped
158819
Points
942
U can use once time alt+ctrl+ any type arrow to roated screen
Screen will not rotate
Some tablets will have a physical rotate lock switch. There is also a setting that locks the rotation. Settings > Display. Auto Screen Rotate.
Ipad screen not rotating
Hit home button 2 times then slide ur finger copper and click the cerved arrows
6helpful
My laptop screen is flipped upside down and i need to know how to reset my laptop!
No reset is necessary to fix this problem. Screen rotation is a typical feature on many laptops.
To rotate the display on the screen 180 degrees, simply press CTRL, ALT & down arrow on your laptop's keyboard.
1helpful
What is the combination of keys (shortcut) to change the screen resolution (not orientation).
There is no Fn-Fx key combination to change screen resolution (at leat on my R10 running Windows XP. Even if you create a shortcut to open the graphics properties you still have to open the relevant tab manually to change resolutions.
You can open the Intel Extreme Graphics 2 for mobile icon on the tray, go to the graphic properties change the resolution and save as a scheme. With a customized scheme defined you will be able to click the Intel Graphic properties and select that scheme. But be careful, your tablet pen will no longer be calibrated with the available screen area.
I tried on my R10 (native resolution 1024x768) and all I could select was 800x600@ 60Hz.
1helpful
Rotate windows on a toughbook
Is it just that the window is upside down??
1. Try pressing Ctrl + Alt + arrow (left, right, up or down) to rotate the screen.
2.Press the hotkeys and arrow keys until you have the desired rotation. This works with most video drivers on Windows XP. If this doesn't work let us know.
Screen won't rotate
Please press Ctrl + Alt + Up Arrow keys to rotate the screen. This feature is completely depending on the Video card installed in the Computer.
1helpful
4helpful
Screen rotate
Hello snapshots,
Here is what you do:
1) Click on a blank area of the desktop (not sure why, but sometimes this is necessary). 2) Press the toolbox button on your monitor. It is located in between the rotate screen button and the secondary "Esc" button. A tablet shortcut menu should appear in the middle of your screen. 3) Select "Settings" at the bottom left of the menu. This will open a "Customize Tablet Shortcut Menu Settings" Window. 4) In the "Auto Screen Rotation" portion of the window, make sure the "Enable ActiveRotate" box is checked.  5) If you choose, you may also want to click the "Calibrate" button. This will step you through customizing the ActiveRotate to your personal preference. 6) Click "Apply" and then "Ok".
Please note, that with the internal wi-fi connection enabled, you cannot use the X61 in tablet mode in certain orientations. Nothing bad will happen if you attempt to do this; but you will notice a message popup telling you this, as well as having the screen automatically switch orientations on you. This is normal and has something to do with the wi-fi antenna location.
Hope that helps!
Jeff
Top Toshiba Tablets & eReaders Experts
k24674
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
