Question about Kenmore 16764 Dishwasher
None of the lights come on Dishwasher doesn't work
None of the lights on my 16764 Kenmore dishwasher will come on.  I've checked the power both where it is hardwired in and at the circuit board and there is power in both areas.  I've also checked the power to the latch and it seems to be operational as well.  I have replaced the circuit board ($160) which was recommended, but it didn't solve the problem.  Any help is appreciated!!
  • mick19bball Mar 07, 2008
    Dishwasher has no power. It stopped in the middle of a cycle and will not turn on again. There are no lights on the display. This problem happened once before and a repair man fixed the dishwasher. I don't want to have to pay somone if possible. I have taken any corrective steps yet.
Ive got the exact same problem, but the thermal fuse is OK. Also the thermal cut out on the base of the machine is testing OK too. However like the other two people no lights no noise nothing !. Yet tests show there is power to the Circuit board.
Posted on Aug 02, 2008
  • 770 Answers
Check the thermal Link
Posted on Jan 24, 2008
Wash cycle won't start
I'm so sorry to hear about your issue. I know it can be frustrating. I did a little search on Google and it may be a shorted circuit board from steam/heat getting behind the panel. Here's the link I found on "Just Answer" have Kenmore 1374 Dishwasher that is driving me crazy
Nov 21, 2017 | Kenmore Dishwashers
Blinking light on Kenmore Pro 13873K dishwasher: won't run
May be the drain pump is jammed. Try to clean the area and after that try to reset the panel. Download the user manual and there must be the reset sequence.
Nov 18, 2017 | Kenmore 13873 Stainless Steel Built-in...
Kenmore dishwasher model# 16769000 LIGHTS WILL COME ON, CANNOT GET WASHER TO CYCLE/RUN. IS THERE A RESET BUTTON SOMEWHERE?
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 25, 2011 | Kenmore 16764 Dishwasher
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
Clean light flashes continuously. None of the cycles work except drain.
Might help if you provide the model number of the dishwasher.
It is likely the float switch at base of dishwasher is cutting in. Have you tried to turn the power off and back on.
Need model no.
Jan 22, 2011 | Kenmore Dishwashers
Water is not pumping into the machine - water is coming up to the machine but not going in
Most likely need to replace water solenoid valve located where water line connects to the dishwasher
Sep 16, 2009 | Kenmore 16764 Dishwasher
Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Feb 05, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore dishwasher 16764 Quick Rinse Light won't go off
you can try reseating the ribbon cable on the board however i strongly believe you have a stuck key and the key panel will need to be replaced.
Feb 02, 2009 | Kenmore 16764 Dishwasher
Kenmore elite dishwasher not running
I had the same problem with mine. The whole circuit board, buttons and all, need replacement. If you look online, you can find this part for a bit over 100 dollars. Definetely worth it over paying 5 bills for a new one.Simple to install too, just turn off power at breaker.
Jun 20, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 16764 Dishwasher Logo
300 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
