Question about Dryers
Ctd00 hi my dryer wont heat, but spins ok
  • 1 more comment
  • Anonymous Jun 11, 2008
    Dryer wont heat but spins freely
  • Anonymous Jan 29, 2009
    my gas duet runs, but will not heat up. I pulled the glow plug and it is fine. Checked the power to the glow plug and it seamed to be getting power. It does have that wet clothes sensor and i am thinking it may be that?
  • weeds212121 May 16, 2009
    my dryer spins but wont heat. i wanna try and fix it but i dont know how to get at the parts. how do i get at the inside of my dryer to fix it?
  • 126 Answers
Check the heating element. Or if there is a security thermostat at the backside that have a reset buttin, push the button in if it is possible.
Posted on Jan 24, 2008
My hotpoint aquarius ctd00 dryer won t spin when turned on but makes noise and heats up
We have made a few videos on these dryers and there are some very good repair guides on these.
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair
Jun 26, 2012 | Hotpoint Aquarius WD63 Front Load...
Hotpoint dryer ctd00 spinning but no heat. How do I fix it?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 11, 2011 | Hotpoint NWXR473EV Dryer
My dryer spins but with no heat - Hotpoint Aquarius CTD00
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 25, 2010 | Dryers
CTD00 drum does not turn,heating OK,belt OK,motor OK
you have a bad motor,most likely.
Mar 03, 2010 | Dryers
My hotpoint ctd00 wont heat up
I would suggest that you check the heater and thermostats, these are located behind a removeable cover at the rear of the dryer.
You will need a meter to test them with, you are checking for continuity
Feb 10, 2010 | Hotpoint Dryers
The drum wont spin on my Hotpoint CTD00 dryer
Remove top cover, and see if the belt is intact, if it is then it could be the motor is not working for one reason or another, this would entail further investigation.
Please rate my solution.
Thanks.
Nov 04, 2009 | Hotpoint Dryers
Drying Problems with a Hotpoint CTD00
There is a thermal fuse at the back that you must check. The thermal fuse can be tested using a multimeter.
If the fuse is ok, then check the heating element , the temp probe, wiring harness to heating element and temp sensor, and if there is nothing in there , then test control timer board.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Apr 27, 2009 | Hotpoint Dryers
DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Hotpoint CTD00 condenser dryer not heating up
sounds like a thermostat fault, there is two on these machines and although only one will be at fault both should be replaced
Jul 24, 2008 | Dryers
Open Questions:
Dryers Logo
347 people viewed this question
Top Dryers Experts
