Figidaire GLTF1040ASO Washing Machine
The washing machine runs but does not operate the high speed spin
  • 3 more comments
  • theimerTJ Jan 24, 2008
    The door is locked and will not open. The drum spins right and left as it does at the end of the cycle, however the drum nevers spins in the fast mode to extract the water.
    The water is all pumped out. The motor runs, the water is pumped out, however, all the clothes are soaking wet because they did not spin in the fast cycle.
  • lisl Jan 12, 2009
    Mine is doing the same thing. It will fill, do the right then left slow spin like it normally does when washing, but never drain or spin fast. I can hear the switch click, then a buzz noise from the motor when it should be going into spin mode.
  • lisl Jan 12, 2009
    Forgot to mention a repair man replaced the board in the bottom left corner last week.
  • robert samples May 11, 2010
    what happens when it gets to spin and is the door lock light on
    President:
  • 1,314 Answers
So is there still water in the washer it did not drain
Posted on Jan 24, 2008
  • robert samples Jan 24, 2008
    ok do you have a small or normal load thees washer will not spin a load that is too small they just rock back and forth trying to find the balance second remove the lower panel and inspect the motor control unit on the left loose wires burned componets etc
6ya staff
SOURCE:
GE GFWN1100LWW. Can the high speed spin work on the lower wash cycles?
From my experience, the lower wash cycles are set to only do certain things. For example: the Delicate won't do a high speed spin, even though a high speed spin wouldn't really be destructive to delicates, but would force more water out of them! I usually just run a "Drain/Spin" after the Delicate cycle.
Nov 27, 2015 | GE Washing Machines
What will cause my Whirlpool washing machine to set on low speed spin cycle?
The machine uses automatic load sensors to balance the load and when you put something in the machine that is big, like a comforter, it knows that it cannot balance that item. So with a front loader it wont spin at high speed because it would be off balance and either damage the machine or the machine would "walk" because of the off balance motion.
Apr 28, 2014 | Whirlpool Washing Machines
My washing machine won't go to high speed spin to remove water from clothes.
Possible there is no switching for the cycle from the controller or there is speed limited due to sensor action for vibration. Check the leveling of the machine, if not use rubber footing to hold the machine steady.
Also check the drives for friction , if so reset and lubricate.
Jan 21, 2013 | Washing Machines
Washing machine wont spin fast
If the motor has a twin speed check the high speed winding. If the washer has a gear box for high speed , check and see if the high speed is initiated while it is on high speed spin.
Feb 05, 2011 | Washing Machines
Hotpoint aquarius wf620 washing machine,machine very noisy when in high spin working ok when golng through program
While spinning every washing machine is very noisy as it rotates in very high speed.This is normal and no need to worry.
Thank You
Sep 08, 2010 | Hotpoint Washing Machines
Does not go into high speed spin
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 22622 will not shift into high speed during spin cycle leaving clothes very wet every now and then it will go to high speed. i tried turning the dial around a couple of times and it went into high...
Possible overloading or a situation many people do not consider is underloading ,if your machine has an out of balance sensor this will operate in either event and hold the spin to protect your machine .
Nov 03, 2009 | Kenmore 22622 Top Load Washer
Kenmore mod. #417.44092500 high speed spin doesn't
replace speed control board located right rear base of unit
Sep 12, 2009 | Kenmore Washing Machines
Not spinning in high speed
possibly a faulty "off-balance" detector, but not sure...try to purposely make it go off balance during wash...maybe a few pairs of sneakers?
Jun 02, 2007 | Hoover Nextra HNF 3157 Front Load Washer
Washing Machines Logo
346 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
