Want to install new graphics card
I have a Dell Dimension 4550 and here are the specs:
Architecture: DDR SDRAM
Memory connectors: two
Memory Capacities: 128-,256-, and 512-MB non-ECC DDR SDRAM
Minimum memory: 128MB
Maximum memory: 1GB
Memory Type DDR 333 (non-ECC)
BIOS address: F8000h
It has an AGP Slot but I am not sure if it a 2.0 or higher
the graphics card I want to install is a PNY Verto GeForce 6200 AGP - graphics adapter - GF 6200 - 256 MB
I know that I will need to upgrade my power source, but will my mother board support this new card? And if not is there a good card out there that can support a monitor of 1680x1050? Please help and if you need more information let me know so I can post it. Thanks
    Genius:
  • 1,067 Answers
Use ati x850 pro
Posted on Jan 25, 2008
Can i use a ddr ram in a dell latitude c600 notebook
hi simply NO this is sdram as here are the specs for this laptop Memory Architecture SDRAM Memory module sockets two user accessible SODIMM sockets Memory module capacities and type 64-, 128-, and 256-MB
3.3-V SDRAM SODIMMS 1 Standard RAM 64-MB memory module Maximum RAM 512 MB Memory clock speed 100 MHz Memory access time CL2 or CL3 (Note: CL3 indicates a CAS latency of 3 clocks) BIOS address F000:0000-F000:FFFF
hope this helps
Jan 10, 2011 | Dell Latitude C600 Notebook
My system is recognizing only half of the new module's memory
Do you have the right memory for your Dell?
Memory Upgrade for Dell Dimension 1100 Computer, the Dell Dimension 1100 Computer takes the PC2700/3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Dell Dimension 1100 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Dell Dimension 1100 Computer.
Nov 20, 2010 | Dell Dimension 1100 PC Desktop
Addrammemory
If your desktop is a Dell Dimension 2400 then this is the technical specs for the RAM.
Memory
Architecture
DDR SDRAM
Memory connectors
two
Memory capacities
128-, 256-, or 512-MB
Minimum memory
128 MB shared DDR SDRAM
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
2 GB
Memory type
PC2100 (266-MHz) or PC2700 (333-MHz) DDR SDRAM (non-ECC)
The RAM modules are held in place with clips on the ends of the RAM modules. Push each clip down and away from the RAM modules and the RAM module will lift up.
To install the RAM modules, the RAM modules have a notch and can only be installed one way. Place the RAM module in the memory slot and push down until the locking clips swing up. You may need to push the clips into the sides of the memory modules to lock and secure the memory modules.
The price of the RAM depends upon the size of the RAM you want to install. I suggest a minimum of 1Gb of RAM and the maximum to can install is 2Gb of RAM.
Check the prices of RAM on the Internet and in the computer stores.
May 22, 2010 | Dell Dimension 2400 PC Desktop
No manual - want to install SNP J0202C/512 myself
This (4th)link should answer all your questions. If you enter your service tag number Dell can help more You can also get help from where you buy the memory it's not that hard..I like the first link to find out what memory to buy. I like the second link for pricing. Please rate me mysleuth
http://www.memory-up.com/default.aspx
http://dealnews.com/memory/
http://www.ask.com/web?q=how+to+install+ram&search=search&qsrc=0&o=0&l=dir
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central?~ck=ln&c=us&cs=19&l=en&lnki=0&s=dhs&SystemID=DIM_PNT_P4_4550
Apr 08, 2009 | Dell Dimension 4550 PC Desktop
Dell Demension 4600 motherboard memory
From the Dell specifications page for Dimension 4600:
Memory
Architecture
Dual Channel DDR SDRAM
Memory connectors
Four
Memory capacities
128-, 256-, 512-MB or 1-GB
Minimum memory
128-MB DDR SDRAM
Maximum memory
4 GB
Memory type
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
Mar 09, 2009 | Dell (2336V) Motherboard
Graphics card upgrade
Not compatable at all.
DDR SDRAM memory uses 184 Pin Dimms
Double-Data-Rate Synchronous Dynamic Random Access Memory, better known as DDR SDRAM or DDR RAM for short, is a type of very fast computer memory. DDR RAM is based on the same architecture as SDRAM, but utilizes the clock signal differently to transfer twice the data in the same amount of time.
DDR2 SDRAM uses 240 Pin Dimms.
DDR2 SDRAM improves on DDR SDRAM by using differential signaling and lower voltages to support significant performance advantages over DDR SDRAM.
If your question has to do with buying a video card that is going to use DDR2 ram, that would be a faster graphics card. You can also get video cards with DDR3 ram which again is even faster.
Oddly enough in respect to system memory DDR2 is supposed to be faster than DDR yet the DDR memory cost more than the DDR2. Go figure.
Click the link for video cards.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318&
http://www.google.com/search?hl=en&q=XFX+AGP+8x+512MB+DDR2+video+card&btnG=Search
Need help with anything, feel free & ask.
Have a great weekend!
Mike
Mar 21, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
New graphic card
ya go for it it will may lower card specks if u have any limitations but your ok agp 8x 4x slot
Jan 24, 2008 | Computers & Internet
Graphics card update
Step one is go to Dell and check the motherboard specifications.
Step two is go to pricewatch.com and (among the zillion of cards) select the one you can afford (select based on AGP rate...this sites takes a lot of the search out of the process).
Step three (and I forget where it is but you can google for it) there is a site (actually a couple) where you input your equipment, cpu, motherboard, etc.....and it calculates the power supply required.
As for good cards...the less expensive generic cards I have had no problems with...most use the same chip sets....doing a comparison of that can save more than just a couple bucks if looking for a real high end gamers video card. One thing I would suggest though is to balance the cpu and memory...particularly since DDR is cheap. Here are a couple of examples.
An old p3 850 htz machine with 256 mb memory is balanced. But that amount of memory on an Xp2800 machine is too little...256 and 128 are needed for balanced performance....meaning neither the cpu is waiting nor the memory is being underutilized (i.e. you get only a "nits" worth of improvement by going to two 512 although one 512 will give you a bit of a boost....say 4-6% improvement in response time. The sellers of PC...particularly bundled....almost always don't put enough memory and always put too much bloatware on the machines....getting rid of the latter (and particularly anything that is active in memory) can give you a boost you may not believe. Ccleaner (free) to fix the registry and Spybot to keep malware from being active plus Hijackthis will allow you to keep your machine at peak....you might want that since you (am guessing) are into either games or some real sophisticated editing.
Hope this helps....whoops...one last thought....these high end video cards do give you some super quick response but....very few games require that (of the total number of games out there) and with bus, cpu and memory speed improvements you might just be better off paying the same amount of money for a mobo bundle...(in fact I think you would be).....but that is your research project....lol.....not mine. Tango
Jan 23, 2008 | Computers & Internet
Computers & Internet Logo
198 people viewed this question
David Payne
David Payne
