Question about GE 46GW945 46" Rear Projection Television
Horz. Output Transformer for a GE Mod#46GW945
Where can I get the following part
GE Mod. 46GW945YX1
Part # 215541
The numbers on the old Part are 30949060 M9813
Problem was shorted Flyback & Horiz output transister
The voltage on the horizontal output transistor collector 19v to high
spec says with color bars the Collector = 140v I measured 159.3v
also the Base = -0.07v I measured -0.026v Scope wave form should be
15v @10us I measured 12v@10us.
Removed Horz Output transformer secondary & meas. R. Should be 0.2ohms. I measured 0.1ohms
LOOKS Like transformer has a shorted winding !!
Thanks AL BD,WI
  • 2,326 Answers
Check this guys: //
This guys may carry that part: //
Posted on Jan 24, 2008
It won't turn on
I would check the fuse first and if thats good then I would suspect the flyback transformer
Apr 02, 2013 | GE 46GW945 46" Rear Projection Television
Have someone check to see if the Horizontal output transistor is shorted==that and the high voltage transformer were common failure parts in this model
May 23, 2012 | GE 46GW945 46" Rear Projection Television
GE 46gw941
MOST likely a bad high voltage transformer or a Glycol leak both of which were common in this set and the parts for this set are nearly impossible to find (I think by the model number set is newer than 92).
I liked these sets but I would not invest big money to fix one this old.
May 20, 2012 | GE 46GW945 46" Rear Projection Television
Popping noise and stopped working
ge version of rca itc222 is known to have a bad flyback transformer usally repaceing it and the horizontal output transistor is what required
Jun 16, 2009 | GE 46GW945 46" Rear Projection Television
After pushing the power button on there a chirping noise coming from the back of the tv and doesn't turn on.
hi, the chirping noise is either the switch mode transformer or the flyback transformer, more likely the flyback as thomson built sets are infamous for them failing, nothing you can do you`ll have to call a tech to verify which has failed, not a major repair job, gl, video-tek
Jun 08, 2009 | GE 46GW945 46" Rear Projection Television
Rca 36 " F36650
horz output transistor goes out with the fly
Nov 20, 2007 | RCA F36650 36" TV
Sony TV not working
This is not an easy fix for most people! I suspect the ps is blown, R607, Q601,Q602 (use all org Sony parts, lots of factory 2nds around). This stuff blows to protect the fuse!!!!! Very rarely the input bridge rectifier or filter cap short.
Check R622, if open or discolored also replace VDR601(doesn't go bad very often). Check Horz output Q502. Inspect whole board for any bad connections, all parts with heat sinks(regulator ICs). Horz driver transformer, 0.47uf to horz driver tr. There could be other parts bad (flyback??). Make sure no supplies are shorted, check audio output supply, vert output supply, etc. Easily $150 repair at a shop. Good luck!
Oct 27, 2007 | Sony KV-32S36 32" TV
GE 46GW945
Bad IHVT ( flyback transformer ) average repair cost 400.00.
Do you want part # ?----------Please give complete service #
off the back of set........T.
Oct 13, 2007 | GE 46GW945 46" Rear Projection Television
Will not turn on.
  • proceed as given after your power supply is ok (your statement)
  • isolate power supply from h/output stage.
  • check diodes & capacitors connected with flyback transformer.
  • check for print short.
  • ckeck h/output transistor.
  • connect supply to h/output stage.
  • put on the set.
  • hope this will help.
  • good luck
still there is a drop in voltage then your fly back transformer faulty.
Oct 12, 2007 | RCA F32450 32" TV
GE 46GW945 Projection has color alignment problems after power outage
Try unplugging for 12 to 24 hours. if that doesnt help replace the convergence IC's
Sep 08, 2006 | GE 46GW945 46" Rear Projection Television
Televison & Video Logo
151 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
