PSU problem I am looking to get a new power supply APEVIA ATX-CW500WP4 ATX 500W Power Supply 115/ 230 V UL, CSA, TUV, CE. The main connector for this unit is a 20 +4 point connection, my current connection is a 20x1, are these two compatible? If not then could you recommend a 500W power supply that is compatible? thanks
  • jflynn Jan 24, 2008
    so is a 20+4 pin a standard power supply or am I going to end up buying PSU that doesn't work with my set up?
  • 407 Answers
The total connection is two part if you disconnect 20*pin one part then four part is other part. when you connect 20 pin in mother board .the four pin connect anther port. then the power supply is on.
Posted on Jan 24, 2008
2 Suggested Answers
SOURCE: New power supply for my Dell Dimernsion 4550
A 20 + 4, and a 20 are industry standards. The latter for earlier mobo's and viceversa. I don't know (but I could possibly be surprised) of anyone that makes a 20 + 1....and more importantly you said 20x1 which equals 20. My suggestion is go with the 20 + 4 if for no other reason that it will come in handy when you upgrade (your old board or processor dies). As for 500w compatible power supplies check pricewatch.com....they list in price order hundreds of power supplies sold by many different companies. If unsure drop an email to one of the companies or use their free long distance numbers to make sure (I am already). One other item...500w is a lot of power...it is doubtful you need that much unless you are running a lot of equipment. There is a site on the net (and no I don't remember) but it is one of the power supply manufacturers where you can input you equipment and it calculates the wattage required. If you are a normal user, with an older board, 350w is more than enough in all probability and 450w would be enough for the foreseeable future. These manufacturers are touting 500w and up in the same fashion as disk drive mfg make bigger and bigger drives. As examples I have a 40 gb drive with 1000 songs, multiple operating systems, more software than 5 average users at least and I barely touch 18 gb. Bigger is not better...only more expensive...just ask all those soccer moms driving 80 lb kids to practice in 6000 lb vehicles at x miles per gallon at today's gas prices. Summary buy what you need with an eye on the future but (as always) the semiconductor industry goes (to the extent possible) in the opposite direction....wattage = heat, heat is no good for components, low power designs make sense....future boards, components and processors will take less power as they shrink the chip and anything beyond the current dual core processors (finally - I hated changing motherboards every few years to accommodate operating systems) will not be required by either the typical business or home user. My opinion obviously but I believe we have finally (less a truly reliable operating system) reached equilibrium. That's all (and probably too much)...have a good day...Tango
Posted on Jan 25, 2008
Main fan is off not warking
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
Apr 25, 2011 | Antec SP450 450W SmartPower ATX 2.0 20/24...
My power went out and when it came back on the computer would not come on
eMachines uses low quality hardware components inside their computers. This is the way they can sell them at budget prices.
One main hardware component is the low quality power supply they use.
A generic power supply made by Bestec. (A generic power supply manufacturer)
(PSU. Power Supply Unit. The type of PSU used is a SMPS.
Switched-Mode Power Supply,
http://en.wikipedia.org/wiki/Switched-mode_power_supply )
Low quality;
A) Electrolytic Capacitors (Radial Aluminum Electrolytic Capacitor)
B) Rectifier Bridge
C) MOSFET/s
D) Wiring is too small in gauge
to name a few of the components.
However IMHO it is also best to check out the Power On switch.
There is a simple test to see whether the problem is a faulty Power On switch, or a faulty Power Supply.
The test involves bypassing the Power On switch. The Power On switch is not involved in this test.
A jumper wire is used on the Soft Power On wire, [ PS-ON ], and a Ground wire in the ATX main power cable connector.
If you bypass, and the Power Supply comes on you have a bad Power On switch.
If the Power Supply does Not come on you have a bad Power Supply.
If you would like to know more in detail on how to perform this simple test, simply post so in a Comment.
The Power Supply used is just a common ATX version.
ATX refers to the Form Factor of the power supply.
Regular size ATX form factor is approximately 6 inches Wide, 5-1/2 inches Long, and 3-1/2 inches Tall. (Height)
There are also differences in the pinout of the ATX main power cable.
Yours may have 20-pins, or 24-pins.
Power Supply's sold now take this into consideration.
Their ATX main power cable can be used as a 20-pin, or a 24-pin version.
[ General example of a 20-pin ATX main power cable, and it's connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Example of a 24-pin ATX main power cable, and it's connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Your motherboard may also require an additional power cable, commonly referred to as a P4 power cable, or P4 ATX 12V power cable, or just ATX 12V.
The actual name is 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
If you would like help in finding an inexpensive reliable Power Supply, please post in a Comment.
I will need to know what Model Number of eMachine you have. It's on the back next to the Windows product key, or up on the side of the computer tower.
If you need anything explained that I have stated here, please let me know in a Comment.
Regards,
joecoolvette
Apr 21, 2011 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Where is the fuse inside the power supply model fsp200
The unit is only 200watt and the fuse cost about $2,Thats if there one built into it,
The replacement power supply is about $20-00 NZD
Probably 20minutes to fix (for a novice) depending on their skill level and tools available,
BEST ADVICE Replace it
Power is something you dont want to mess with because it can kill.
The power packs are replaceable but people arent.
Be very careful and dont mess with the power.
I am an Electrician and I respect power.Misterdj
Mar 24, 2010 | AOpen (FSP200-60SAV) 200-Watt Power Supply
Is there a comptable power supply to replace FSP250-60HEN
Although ATX power supplies conform to various specification guidelines, there is not, unfortunately, a standard ATX power supply. To find a suitable replacement power supply for your machine, we would recommend that you have the following information to hand when making your purchase:
- You will require a PSU with a 24-pin ATX connector, SATA power connectors, and a 4-pin 12V motherboard connector
- Make a note of the wattage of your existing PSU
- Make a note of the external dimensions of your existing power supply
- Be aware that your PSU has a power connector for speakers. Most PSUs do not have this, so you may need to purchase a separate power supply for your speakers.
So it is a slight variation to a standard ATX power supply. If you are not using the speaker power off the power supply, then any standard ATX power supply will work for you
Feb 20, 2010 | Computers & Internet
I have a Bestec atx-300-12az and i need to know which power supply harness to use on a Samsung model#HD103UJ hard drive.Thanks,Tony
Technical Details
  • Samsung Spinpoint HD103UJ 1 Terabyte SATA/300 Hard Drive General Features:
  • 1 Terabyte formatted capacity 7200 RPM spindle speed SATA/300 interface 32 MB buffer
  • 8.9 ms average seek time 4.17 ms average latency 3.5-inch form factor
  • Improved recording stability over temperature with PMR
  • Advanced dynamic FOD control for best data integrity
SATA Power3 Peripheral4 Floppy5 02 +3.3V (Orange)
03 COM (Black)
04 +5V (Red)
05 COM (Black)
06 +5V (Red)
07 COM (Black)
08 PG (Gray)
09 +5VSB (Purple)
10 +12V (White)
11 +12V (White)
12 +3.3V (Orange)
13 +3.3V (Orange)
14 -12V (Blue)
15 COM (Black)
16 PS-ON (Green)
17 COM (Black)
18 COM (Black)
19 COM (Black)
20 Blank
21 +5V (Red)
22 +5V (Red)
23 +5V (Red)
24 COM (Black)', CAPTION, 'Pin Signal (Color)', WIDTH, 150, BGCOLOR, '#000000', FGCOLOR, '#FFFFFF');" onmouseout="return nd();" href="javascript:void(0);">matx24pin.gif
atx12v.gif sata.gif drive.gif floppy.gif This ATX12V power supply is a 300W, five output unit with remote on/off, and UL, CSA, and TUV approvals. RoHS compliant. Original HP part number 5188-2625 used in many Media Center, Pavilion, and Presario computers. Also serves as upgrade for HP/Compaq part numbers 5189-3964, 5188-0131, 5187-5116, 5187-6114, 5188-0129, and 410507-001. Airflow drawn out of case into surroundings by 80mm internal fan. Built-in power status LED above AC inlent. 2 x 12 (24 pin) main board power connector. Includes two daisy chained Serial ATA connectors. Bestec model ATX-300-12Z CDR, also replaces ATX-300-12Z BC, ATX-300-12Z BD, and ATX-300-12Z CC. i trust this helps
Jul 15, 2009 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Need physical dimensions of HEC HP585D 585W ORION HP585D ATX
No, given your old PSU's dimensions the HEC PSU would be too large. It sounds like you have a micro-ATX case.
Apr 06, 2009 | HP HEC HP585D 585W ORION HP585D ATX 12V...
Power supply not working?
To see if power supply works
unplug the psu from the motherboard and drives
then plug the power cord into psu and wall
the fan should come on letting you know that it works.
you can also get a multimeter and check each individual connector on the 20/24 pin connector to motherboard.
check the psu docs for the correct voltages to each pin
If you smelled smoke then chances are that something may have gotten toasted.
remove all expansion cards and try to turn on computer if nothing happens then the motherboard may have gotten toasted.
Check the motherboard and expansion cards along with memory for shorts and burn spots.
A+ Technician
Apr 02, 2009 | HP HEC HP485D 485W ORION HP485D ATX 12V...
3 beeps every few minutes
That maybe a memory beep code. Turn it off and remove and re-insert the memory modules on the mainboard.
If this doesnt work, get back to me.
Feb 13, 2009 | Apex Computer Technology Apex Power Supply...
Jan 23, 2008 | Computers & Internet
P4T-E PSU
your connector is of two part.it has total of 24 pin, can be divided into 20 and 4 pins.connect  20 pin  in your mother board .switch on ur psu and connect 4 pins to another port.
Jan 19, 2008 | Powmax 400 Watt ATX Switching Power Supply...
Computers & Internet Logo
234 people viewed this question
Alun Cox
David Payne
David Payne
