Question about VinoTemp (VINO-24GN)
VinoTemp is displaying "L L"
What does the "L L" display mean? There is lots of condensation. Many thanks in advance for your help!!!
  • kborman Jan 24, 2008
    I am seeing the "L L" instead of a temperature and lots of condensation on the door/window. (actually I am at work but that is what I saw this morning). should I get it serviced? Who should service it? I bought it from Costco.
    President:
  • 1,944 Answers
I would advise you to contact them here for free support.
http://www.vinotemp.com/service-request.php
Posted on Jan 24, 2008
  • 770 Answers
LL= Low temp means the unit is freezing up you will need to get service out to look at it if it is under warrty
  • 871 Answers
Hi there
what exactly are you seeing now? what exactly is happening?
i have here a pdf of vinotemp and it has some error written.
http://www.vinotemp.com/winmate_instruction.pdf
  • earl norman llanera
    earl norman llanera Jan 24, 2008
    as indicated here in the pdf, whenever you get some errors, contact them asap.
    Low Temperature Limit a.k.a. L L
How to get access to the evaporator
the evaporator is visible inside the cabinet
the condenser is probably concealed and you can't find the leak
to check for a gas leak use orange /yellow coloured glasses and an ultra violet light and any leak will show up as a yellow green spots or area
test set can be obtained from any goo tool shop that sells ac equipment
Jul 28, 2015 | VinoTemp VT26 Compact Wine Cooler
Hi, I have in my ptcruiser factory car radio. On the display is "Waiting". I know code, but when I type the code noting happens. Please can You help me? Thank You in advance.
The display should normally show CODE
WAITING on the display normally means that a wrong code (or codes) have been entered previously.
Leave the radio SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset
(It should then display CODE )
If your code is incorrect then the correct one will be available from here.....CLICK HERE
Jul 03, 2011 | Car Audio & Video
Hi, Fn+f1 and Fn+f2 keys are not working to change screen resolution in my new hp probook 4320s laptop after i replaced its LCD. Please help me as early as possible. Thanks a lot in advance.
The screen rsolution is changed in the Display settings.
Open Control panel - click on Display - Settings Tab then move the slider on Screen Resolution to adjust the screen resolution. - then Apply
Mar 19, 2011 | HEWLETT-PACKARD ProBook 4320s C Notebook
Error Code H2
H2 means the thermistor is open or defective.
Try to press the copy button when h2 appears you'll see the sub 00. You dont need to replace the whole fuser unit. Try first to cancel the trouble by entering the simulation.
Try to press the # - interrupt- C- interrupt (one after the other.) then enter 14 then copy button. If it doesnt work replace the thermistor.
The last part that you'll replace is the main board but that rare. Mostly the thermistor is defective when that trouble appears. Hope it could help you a lot.
Jul 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
Freezer is always reporting an error.
The defrosting issue is normally due to a rear brd failure as this controls most of the appliance. Dependant on the model the F90% is normally indicating how much time is left on your water filter before it needs replacing.
I hope this helps
Jul 02, 2009 | Whirlpool GD2SHGX Refrigerator
Vinotemp VT-60 Condenser won't shut off, unit running way too cold
It might be a sensor or control board problem. Any appliance repair place should be able to help you out with this. Or you can try contacting the manufacturer directly for help or if you need to purchase replacement parts. Otherwise, my cheapest suggestion would be to hook the cooler up to a timer, so you can turn the unit on and off maybe every 20 minutes or so. That should help keep it from causing more harm and then you can monitor the temperature with a thermometer. Hope that helps!
Aug 29, 2008 | VinoTemp (VT60GNV) Wine Cooler
Wine-cicles
I found the vinotemp trouble shooting webpage that has good info for several different VT models. Here is the link. http://www.vinotemp.com/troubleshoot_pdf.htm
I emailed VT and they gave me a price for the parts
VT-TC32ECB -$34.95 (control board)
VT-60Sensor -$14.95
here is their services information
Jane Barron
Service Department
VINOTEMP INTERNATIONAL
jbarron@vinotemp.com
T 310.886.3332 x231
800.777.8466
F 310.886.3310
Mar 18, 2008 | VinoTemp (VT60GNV) Wine Cooler
Sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
VinoTemp (VINO-24GN) Logo
660 people viewed this question
Top VinoTemp Refrigerators Experts
Vernon Taylor
Ilia Bichin
Are you a VinoTemp Refrigerator Expert? Answer questions, earn points and help others
