Question about Hitachi 50SBX70B 50" Rear Projection Television
Need help now my Hitachi 50SBX70B 50 does not turn on .....try to unplug but nothing ...the board light turn on.. all green.. but when i push the power button everything turns off is there a soloution or need to buy a new one...is it worth to get it fix ...koz it as a very pretty image
  • 137 Answers
If the green lites on bord lites up doesnt mean it is ok. If you check on that board in the middle at the back of the heatsink in the middle, there is two lights, green lights that is not lighting up. If i am wright. You have caps an a transistor on your powersup that is shorted. Take to somebody to fix powersupply.
Posted on Jan 24, 2008
50sbx70b made sizzling noise then quit
Sizzle cound be crt arching or hv transformer. look for burn marks on transformer on deflection board. unplug set and remove crt boards from the crts and see if set will turn on. if replace arching crt. expensive. not to be attempted by amature.
Jun 27, 2009 | Hitachi 51F59 51" HDTV Projection...
Please help need to watch tv
Well this gives you someplace to start!
Symptom: NO POWER
Cause: DEFECTIVE I912
Symptom: SHUTDOWN
Cause: Q777,I901
Symptom: SHUTDOWN
Cause: E994,D724
Symptom: SHUTDOWN
Cause: DEFECTIVE I401
Symptom: SHUTDOWN
Cause: DEFECTIVE I601
Symptom: SHUTDOWN
Cause: DEFECTIVE C715
Symptom: SHUTDOWN/OPEN E995,E996
Cause: DEFECTIVE T702
Jan 29, 2008 | Hitachi 50SBX70B 50" Rear Projection...
My 50SBX70B flicks than lost the power
Symptom: NO HOR SYNC
Cause: DEFECTIVE I008
Symptom: No Horizontal Sync. When PinP is called up, main picture may lock up for a 8 moment, then it goes back out of sync.
Cause: I008 defective (Sync Switch)
Jan 15, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Hitachi 50sbx70b
This update covers to the following Hitachi models and chassis
46UX50B/51K, 50UX52B/53K, 60UX54B/55K, 50SBX70B, 60SBX72B, 70SBX74B. All projection televisions using the AP73 & 74 chassis's From Dennis Viereck
SYMPTOM:
Intermittent loss of Raster, On Screen Display, sometimes sound. BUT ALWAYS HAS HIGH VOLTAGE! Also removing power and reapplying it again restores operation.
THE PROBLEM: There is a lack of a secondary ground for the CRT Dag connected to each CRT board. You can identify this missing ground on the CRT board by locating two vacant pins on each CRT driver board near the CRT socket. The connector is named P801, P831, and P861 relative to each board. The pin nearest the socket is the ground pin in question. The pin furthest from the socket is connected to the cathode of the CRT.
OBJECTIVE: Run a separate ground wire from the "GROUND" pin on each CRT board to the chassis ground. You can use the circuit board mounting screw on the frame under the green CRT. See drawing below.
DIRECTIONS: Obtain 3 wires 10, 14, and 18 inches long. The wire is 18 gauge stranded with an insulated jacket. Attach one wire to each ground pin on the CRT socket. Choose the correct length of wire so that all wires will connect to the circuit board mounting screw near the center of the chassis frame.
EXPLANATION: The extra ground is needed if an internal arc occurs in the CRT. This energy must find a path to ground. Before, the only path to ground is through the signal ground wire on the RGB drive connector. This thin wire does not go directly to chassis ground and is inadequate ground for the CRT dag. If the energy level of the discharge is high enough it may corrupt the data flow on the data & clock lines or negatively effect the OSD microprocessor. Since electricity takes the shortest path to ground, the additional ground wire will route the majority of that static pulse to chassis ground quicker and reduce the possibility of corrupting operation of the OSD processor.
Nov 12, 2007 | Hitachi 50SBX70B 50" Rear Projection...
I have a hitachi 50sbx70b
sounds like either a tube is arcing or h.o.t is arcing.
Televison & Video Logo
69 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
