Question about Remote Controls
Universal remote control manual
Dear sir i bought universal remote control URC22B. But i didn't know how to install it. My TV is thomson QNADRA NTSC PB.
SOURCE: Programming a URC22B universal remote controller
How generous of Tisaclli, I just bought one in my local pound shop. Yep, only a pouind :)
Posted on Jan 02, 2008
SOURCE: URC22B universal remote controller 15 in 1
Doing some searching I came across this, I hope it helps.
From instruction booklet
Power on the control device or VCR and put the tape in.
Press on the SET key continuously,then press the device key you want to set.For example, TV1/2,or VCR1/2,or SAT/CBL or AUX.
Then the LED is on, release the key you press.
Press the SET key again and release it,then you will go into QUICK SEARCH MODE and the LED will flash all the time.
Press the POWER key once at the device,URC22B will send another POWER signal of the next code.(If VCR/AUX, you will press the POWER or PLAY key). Observe if the device works(POWER OFF or PLAY),if it works, go to next step , otherwise repeat the step
whenever you want to leave SEARCH MODE,please press the device key,(TV1/2,or VCR1/2,or SAT/CBL or AUX.)
then the LED is off.
Then check other keys like [CH+/-],[VOL+/-] if they can be controlled.If cant be controlled,go back to the step
Posted on Feb 22, 2008
SOURCE: bush tv remote code
need codes for universal control bush
Posted on Apr 13, 2008
SOURCE: urc22b universal remote controller code
hi i buy me a URC22B universal remote contoller and i lost my codelist, ples can you send it
Posted on Oct 18, 2008
Here is the manual in pdf format
Posted on Dec 02, 2008
i have a bush lcd tv 27 inch an its stuck on stand by i have an urc7740 one forall remote how can i take my tv of stand by with this remote.
Posted on Feb 02, 2009
0 characters
1 Points
I cant install remote control urc22b for my jvc tv
Check this link for more details.
Jan 03, 2013 | RCA Universal Remote Control
I have a Thomson 20LB020S4 and lost the remote control, now I bought a universal remote which can be used by thomson, but I cannot switch on the TV since this only works with a remote which is programmed...
Dear Sir:
1) Read you user manual and see where is the power on.
2) Get from radio schack one universal remote control.
3) Programmed it. according with the codes coming the literature from R.C.
4) However you can get from the next web: www. fitness.manualsonline. com get you model, etc and download free.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 20, 2012 | Thomson Remote Controls
I need code for my nse urc22b-10 universal remote control
i have a panasonic tv i want code for urc-22b-10 remote controler
Oct 07, 2009 | Teac RC-L2 LCD Touchscreen Remote Control
Lost my manual for my urc22b controller
I need codes for remote unviersal 22b to control panasonic tv
Mar 23, 2009 | Remote Controls
Urc22b universal remote controller code
Just ask at
- they find you every remote code. Send them model #s of TV and remote!
Jul 05, 2008 | RCA Universal Remote Control
Jan 08, 2008 | Zenith ZN110 Remote Control
Turn device on
Press and hold [SET] button, then press and release DEVICE button eg tv, vcr , sat, aux
release [set] point the remote at device and pres [POWER] or [PLAY]
until device turns off or plays
Press [ DEVICE] to lock up the code
check other buttons
Nov 17, 2007 | Jensen JR500 Remote Control
Remote Controls Logo
178 people viewed this question
Top Remote Controls Experts
Are you a Remote Control Expert? Answer questions, earn points and help others
