Question about SpeakerCraft BB835 8-Channel Amplifier
SpeakerCraft BB835 8-Channel...
Hi
i live in norway and we have 240 volt here. just got hold of a SpeakerCraft BB835 8-Channel... amp that runs on 110 volts. i open the caseing and followed the power cords from the power inlet. says there is a jumper for 110V and one for 240V , will it run here on 240 V if i move that jumper ??
thanks
Jon Valset
  • 107 Answers
Take the risk if you will attempt to change the voltage. but if your are willing to use the amplifier just take it to any authorized personels who knows. OK?
Posted on Jan 25, 2008
What spect of voltage conventer transfer to convent the Voltage 110 to the 220-240 V printer??
110 volt to 220 power converter 220 volt to 110 voltage ...
www.dvdoverseas.com/voltage_converters.htm
110-220 volt voltage converter power transformer 220 volt voltage converters 240 ...run on 120 volt 60 cycles (60hz) and most of the worlds run on 220/240 volt ...
Oct 07, 2015 | Canon F151300 LBP 3100 Mono Laser Printer...
How do i convert a makita charger model DC18RC at 110 volt to 240 volts?
The DC18RC are most likely to charged the BL1830 battery, which is the most popular of 18V Makita power tools. It is a Li-ion battery.
And the DC18RC battery charger has two volt 110 Volt and 240 Volt.
The 240 Volt DC18RC charger can replace model DC18RA & DC18SD because of its improved performance and full compatibility with Makita's NEW 'Star' labelled batteries that communicate between the tool, battery & charger. And, it is a fast charger.
It can charge a Makita BL1830 Battery in approx 22 minutes.
But, I do not recommend to convert a makita charger model DC18RC at 110 volt to 240 volts.
The reason is as below:
1. This will void product warranty ! If you follow this mod, you do it on your own risk !
2. There are several comments that described
same model # but with different design and components.
Please beware that this mod might not work on your charger
or worst, will damage it.
Only perform this mod if you know your way around with electronics !
Sep 20, 2013 | Makita Drills
What is the standard plug for stoves newhome el916. Is it the general 13A plug
I can't find an online manual for the model of the appliance you are talking about, so I'm unable to figure out the wattage it draws. Nor do I know where you are in the world and the voltage you are running at, so I can't tell you straight off. But I can tell you how to figure it out very easily:
I imagine that know what your main power supply voltage is (either 240 volt or 110 volt).
You can look at the appliance and there will be a data sticker with the wattage rating on it somewhere (or it will be in the install/Owner manual).
Now you have these 2 bits of information we can do a simple sum:
Watts divided by Volts = Amps
Therefore example calculations look like this:
If you have a 500 watt appliance on a 240 volt system 500/240 = 2.083 so use a 3 amp fuse
An appliance with a 750 watt motor on 240 volts: 750/240 = 3.12 so use a 5 amp fuse
A 2KW (2000 watt) appliance like a hot air blower on a 240 volt system: 2000/240 = 8.33 amps so use a 10 amp (or more commonly 13 amp) fuse
A 500 watt motor on a 110 volt supply 500/110 = 4.5 so use a 5 amp fuse
A 1KW (1000 Watt) appliance at 110 volts: 1000/110 = 9.09 amps so use a 10 amp (or more commonly 13 amp) fuse
etc etc etc.....
If the sum comes out below 13 amps, you can use a 13 amp plug. If it doesn't you need to hardwire it into a proper cooker supply.
Jul 29, 2011 | Stoves Ovens
How many amps a fuse in breville mixer
Not knowing the model of the mixer you are talking about, or where you are in the world and the voltage you are running at, I can't tell you. But I can tell you how to figure it out. Simply do this:
You obviously know what your main power supply voltage is, either 240 volt or 110 volt
You can look at the mixer and there will be a data sticker with the wattage of the motor on it
Watts divided by volts = Amps
Therefore, if you have a 500 watt mixer on a 240 volt system 500/240 = 2.083 so use a 3 amp fuse
a 750 watt motor on 240 volts 750/240 = 3.12 so use a 5 amp fuse
a 500 watt motor on a 110 volt supply 500/110 = 4.5 so use a 5 amp fuse
etc etc etc.....
Hope this helps
Jul 26, 2011 | Microwave Ovens
What amperage breaker required for neptune 5500 dryer? Also, it shows 120/240 volt on back canit be wired for 110 current? Thanks, Mark
No it can NOT be wired for 110 .Actually everything it the unit runs on 110 volts except for the heating element which needs 220 volts..As far as the circuit breaker is concerned you need a minimum of 30 amps
Nov 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Can ce 2000 be converted from 110 volts to 240 volts ? How much would it cost?
You could get an outside box called a Step down transformer that would deliver 110 volts to the amp. A quick look on Google should come up with prices.
All you need however is a new transformer. If you can find the specifications for the one in the amp it will be much easier to get a new one. All you need to know is the outputs of the secondary windings of your amp's transformer and current ratings. The primary winding will be 240 on the new one and 110 on the old. But you can get one with both!
If you ask Crown they might even convert it for you or put you in touch with someone who will.
Nov 18, 2010 | Crown CE2000 2-Channel Amplifier
Hello i have a Sony Vaio PCW-W2 that i brought to canada from uk. how do i switch voltage to 110?
u can find voltage converter connectors......try using that....u can ask for travel adapters....hope u find them
Mar 08, 2010 | Sony Computers & Internet
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
Change gas/110volt fridge element to gas 240volt
You need transformer converter 110 to 240VAC.
Regards ,
Edgz
Jan 26, 2008 | Refrigerators
SpeakerCraft BB835 8-Channel Amplifier Logo
158 people viewed this question
Top SpeakerCraft Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
Ronny Bennett Sr.
Ronny Bennett Sr.
Craig Butler
Craig Butler
Are you a SpeakerCraft Audio Player and Recorder Expert? Answer questions, earn points and help others
