Question about HP OfficeJet 7410 All-In-One InkJet Printer
Fax not answering or receiving
I have an HP 7410 all in one fax machine. Suddenly I cannot send or receive faxes. I have checked the phone line and it appears to be fine (has dial tone and calls out); however, when someone sends a fax it rings on my end, shows it is connecting and then beeps three times and no other activity. On the sending end there is no ring and it shows "dialing". The sending report shows my machine does not answer or is busy. The machine is printing fine and I have reset factory defaults. Any ideas? Thanks in advance.
Traci Hannah
hannaht@hughes.net
    President:
  • 4,402 Answers
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02151&lc=en&cc=us&dlc=en&product=391194&rule=44610&lang=en
Visit the HP Support and Drivers Home page .
Posted on Jan 24, 2008
Why did my fax machine suddenly stop working?
Check that the memory is not full. Also, make sure a setting like (auto-dial 9 for outside line) is set incorrectly.
May 17, 2015 | Office Equipment & Supplies
No dial tone. cannot receive or send faxes - it's not the phone line or the modem or the cable. not what?
Make sure the phone line from the wall is plugged into the "line in" jack on your machine
Dec 12, 2011 | HP 640 Inkjet Fax Machine
My faxes will not receive because of communication errors
Scenario 1
In the HP Solution Center, click Settings, point to Fax Settings & Setup,
and then click Fax Setup Wizard.
After you have connected the phone cord to the port labeled 1-LINE, run the
fax test again to make sure it passes and the HP All-in-One is ready for faxing.
Try to send or receive a test fax.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
Scenario 2
If you are not using a distinctive ring service, check to make sure that the
Distinctive Ring feature on the HP All-in-One is set to All Rings. For
information, see Change the answer ring pattern for distinctive ringing.
? If Auto Answer is set to Off, you will need to receive faxes manually;
otherwise, the HP All-in-One will not receive the fax. For information on
receiving faxes manually, see Receive a fax manually.
? If you have a voice mail service at the same phone number you use for fax
calls, you must receive faxes manually, not automatically. This means that
you must be available to respond in person to incoming fax calls. For
information on setting up the HP All-in-One when you have a voice mail
service, see Fax setup. For information on receiving faxes manually, see
? If you have a computer dial-up modem on the same phone line with the
HP All-in-One, check to make sure that the software that came with your
modem is not set to receive faxes automatically. Modems that are set up to
receive faxes automatically take over the phone line to receive all incoming
faxes, which prevents the HP All-in-One from receiving fax calls.
124
HP Officejet 6300 All-in-One series
User Guide
Note Some digital answering machines might not retain the
recorded silence at the end of your outgoing message. Play back
your outgoing message to check.
If the HP All-in-One shares the same phone line with other types of phone
equipment, such as an answering machine, a computer dial-up modem, or a
multi-port switch box, the fax signal level might be reduced. The signal level
can also be reduced if you use a splitter or connect extra cables to extend
the length of your phone. A reduced fax signal can cause problems during
fax reception.
To find out if other equipment is causing a problem, disconnect everything
except the HP All-in-One from the phone line, and then try to receive a fax. If
you can receive faxes successfully without the other equipment, one or more
pieces of the other equipment is causing problems; try adding them back one
at a time and receiving a fax each time, until you identify which equipment is
causing the problem.
If you have a special ring pattern for your fax phone number (using a
distinctive ring service through your telephone company), make sure that the
125
If you have an answering machine on the same phone line with the HP All-in-
One, you might have one of the following problems:
- Your answering machine might not be set up properly with the HP All-in-
One.
- Your outgoing message might be too long or too loud to allow the HP All-
in-One to detect fax tones, and the sending fax machine might
disconnect.
- Your answering machine might not have enough quiet time after your
outgoing message to allow the HP All-in-One to detect fax tones. This
problem is most common with digital answering machines.
The following actions might help solve these problems:
- When you have an answering machine on the same phone line you use
for fax calls, try connecting the answering machine directly to the HP All-
in-One as described in Fax setup.
- Make sure the HP All-in-One is set to receive faxes automatically. For
information on setting up the HP All-in-One to receive faxes
automatically, see Set the answer mode.
- Make sure the Rings to Answer setting is set to a greater number of
rings than the answering machine. For more information, see Set the
number of rings before answering.
- Disconnect the answering machine and then try receiving a fax. If faxing
is successful without the answering machine, the answering machine
might be causing the problem.
- Reconnect the answering machine and record your outgoing message
again. Record a message that is approximately 10 seconds in duration.
Speak slowly and at a low volume when recording your message. Leave
at least 5 seconds of silence at the end of the voice message. There
should be no background noise when recording this silent time. Try to
receive a fax again.
Scenario 3
The HP All-in-One might be dialing too fast or too soon. You might need to
insert some pauses in the number sequence. For example, if you need to
access an outside line before dialing the phone number, insert a pause
following the access number. If your number is 95555555, and 9 accesses
an outside line, you might insert pauses as follows: 9-555-5555. To enter a
pause in the fax number you are typing, press Redial/Pause, or press the
Space (#) button repeatedly, until a dash (-) appears on the display.
You can also send the fax using monitor dialing. This enables you to listen to
the phone line as you dial. You can set the pace of your dialing and respond
to prompts as you dial. For more information, see Send a fax using monitor
dialing.
? The number you entered when sending the fax is not in the proper format or
the receiving fax machine is having problems. To check this, try calling the
fax number from a telephone and listen for fax tones. If you cannot hear fax
tones, the receiving fax machine might not be turned on or connected, or a
voice mail service could be interfering with the recipient's phone line. You
can also ask the recipient to check the receiving fax machine for any
problems
Dec 03, 2010 | HP Officejet J3680 Multifunction Printer...
Can't receive fax's......how do you set it up to receive...thank you
again.
Scenario 2
124
User Guide
fax reception.
125
One.
disconnect.
Scenario 3
dialing.
problems
Dec 03, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I have no dial tone on my fax machine and i cant send or receive faxes
Remove the phone line from the back of the fax and connect a standard phone (not a business PABX or PAX system phone) to the line. Ensure dialtone is available. (Make sure in doing this that you are also testing the cable from the phone socket to the fax). If no dialtone, replace cable or fix line.
Check that the line is connected to the 'line' port on the fax, not the 'phone' port.
If still no dial tone, it may be modem fault (in the fax). Seek specialist attention.
Feb 12, 2010 | HP 640 Inkjet Fax Machine
Our HP Office Jet 4255 all in one suddenly won't receive faxes for some reason. It has been working fine up until now. We can send faxes, but for some reason the phone just keeps ringing and won't...
CHECK THE TELEPHONE NO.
Verify that you are dialing the number correctly. (i know its funny to ask)
Verify that you are dialing the number correctly. You must dial all of the numbers required to make a phone call from the same line. This includes numbers that must be dialed to access an outside line or to access long distance services.
TRY DIALING FROM THE FRONT PANEL
manually dial the number from the front panel of the fax.
If you have been using a speed dial or are faxing from the computer, print the page to be faxed and manually dial the number from the front panel of the fax. If the fax can be sent when dialed from the front panel, recreate the speed dial setting and insert some pauses.
Check the connections
Check the TELEPHONE LINE
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Try using a different telephone cord.
Jan 05, 2010 | HP OfficeJet 4255 All-In-One InkJet...
I have two problems with my OfficeJet 6310: 1. The fax screens appear Hebrew. Similary, If I try to use the copier from the printer. This is continuously caused by HP Update 2. I can not send out a...
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax
Jul 05, 2009 | Computers & Internet
Cannot receive faxes, but can send
I can send faxes from my HP Fax 1010, but cannot receive them. I can dial the number from another phone but it will keep ringing and the machine never picks up. We have tested the phone line and all seems well. Is there some setting on the fax machine itself that I need to change in order to receive? Any assistance you can provide would be greatly appreciated.
Aug 25, 2008 | HP 1010 Plain Paper Inkjet Fax
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 07, 2008 | HP Officejet 4215v All-in-One Printer
HP 7410 fax tone when answering machine starts
you can only have it set to fax or phone at a time; the computer does not know if it is a fax or phone call. Therefore if you are running your fax software it will treat all calls as a fax. You really need two phone lines, one for the fax and one for the phone.
Dec 28, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
263 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
