Question about Xerox Phaser 7300DN Laser Printer
Phaser 7300 error message...
Message is to re-seat toner, so I remove it and put it back, then it works fine. After a while the same message appears. It is not always the same color. I have removed all Imaging units as well as the fuser and transfer unit, cleaned it all up, and put it back together. Error message continues to pop up from time to time. What is the problem?
  • 6 more comments
  • pjboles Mar 28, 2008
  • eyvln May 08, 2008
    The guru appears right.- when i run a diagnostic the tonor sensor is going nuts! Is there a long term fix ie replace the top?
  • Anonymous Sep 30, 2008
    How can i get into the service diagnostics made ?
  • alidvannieke Sep 30, 2008
    How can i get into the Service Diagnostics mode ?
  • kinsum2002 Nov 24, 2008
    So shold I replace the sensor braod ?
  • Anonymous Dec 29, 2008
    I have been fighting this issue for a while. There does not appear to be one specific fix. I have heard everything from replacing the top cover, the flags, belt, build up around the auger in the cart, sensor board, the moon phase, you name it. I have yet to see a final fix.
    I just had a tech in on it again and he checked the sensor flags in service diagnostic mode and they seem to be working, he cleaned the gears that drive the toner cart lift (they are below the belt) cleaned and vacumed it out, I am still getting the error on occasion but it's better.
     BTW Anyone know how to get into the Service Diagnostics mode?
  • Kit Kat Meyerson Jan 10, 2009
    We have a xerox phaser 7300 that we do not get service for anymore so I'm trying to keep it running on my own. We got the "reseat magenta toner" message and it won't work to even print in just black and white so we're screwed. I wish I could keep it working. I cleaned it out and put in a new imaging unit since we had one in stock, and that didn't help. I turned it off for five minutes to reset it and it still doesn't work. Please help!
  • eyvln Jan 25, 2009
    I recently got a tech into to look at mine - it has all the same problems you describe: no magenta, reseat magenta, and this message sometimes swaps to different colors. My tech cleaned it very thoroughly - making sure the sensor flags moved freely, getting all the tonor out of every corner. My sensor flag diagnostic also shows one flag going wild. We swapped around the cartridges. Sometimes the printer works fine and prints beautifully but then the problem comes back again within ten minutes of being powered up. I tried the glasspaper on metal option - it worked occasionally but since the problem is intermittent and comes on the tech suggested he thinks it is not toner but overheating on the engine control board. Could this also be an option?? What are the types of costs involved in new sensor flags or a new engine control board - can they be installed by an amateur
    New Friend:
  • 97 Answers
The problem is a crazy design in the printer itself! I've now found a reliable fix for this problem which is relatively easy to carry out. You will find the details of how to do it here :
www.michelsplace
Posted on Aug 08, 2012
  • Michel May 05, 2013
    The solution is easy - see my post below.
    New Friend:
Michel's solution works! I had just bought my 7300N used and everything was great except I kept getting a "cyan toner is unseated" error message. I mean, I would run a test page and then I'd get the error...like every other page. I read through the other suggestions on this page and I tried the "crazy" suggestion of removing the foam on the flag and putting sticky tack on the side of the flags and my problem is solved. I've so far printed multiple pages with no trouble. So go to: http://www.michelsplace.co.uk/xerox-7300.html Michel mentions that the foam you take off is to sound deaden when the flags hit, but I can't hear anything different over the general hum of the printer, so I'm happy.
Posted on May 05, 2013
    Novelist:
  • 110 Answers
First thing you should try is the toner cartridge. Second, is to replace the toner Sensor Flags. Thrid, is to replace the Toner Sensor Board. Fourth, is to replace the Engine controller Board.
I usually fix this issue by replacing the Flags... if not I try the Sensor Board (usually doesn't work), and then I replace the Engine Controller Board as a last resort.
Replacing the FLAGS is the BEST solution. I have posted a video tutorial on YouTube on how to replace them. Search for Xerox 7300 Flag replacement or something and you'll see me and my video.
This is a VERY COMMON issue. But is simple to fix/troubleshoot. Good Luck.
Posted on Dec 24, 2009
  • 43 Answers
We have found that the toner sensor flags are magnetic, and may loos their magnetism over time. When we replaced the sensor flags problem went away. Note flags are located on the top cover assy.
Posted on Jan 23, 2009
    President:
  • 2,072 Answers
TRY FIRST (Solutions without parts):
1. Toner cartridge sensor is dislodged or stuck. - Reseat and verify movement of the toner cartridge sensor. It may be necessary to remove the flag and sand the pivot shaft and smooth to provide free movement. 2. Toner is packed in the sensor window of the toner cartridge. - Remove toner cartridge and Image unit together as an assembly and tap on a table or counter to clear toner sensor window. 3. toner sensor magnets are not properly seated. - Verify the toner sensor magnets are properly seated in the actuators.
TROUBLESHOOTING TIPS AND HINTS:
Test the toner sensors in service diagnostics. Inspect the Toner Sensor Flags for smooth movement. It may be necessary to remove the flag and sand the pivot shafts smooth to provide free movement. Inspect the wiring harness from the toner sensor board to the engine control board. Use service diagnostics to test the Imaging unit drive motor. Remove the imaging unit keys from the back of the imaging unit and swap the imaging unit and toner with another color.
CAUSE:
The problem has been isolated to the Top Cover Inner Frame molding that holds the toner sensor flags for each color. The Top Cover Inner Frame molding has too much variation where the toner sensor flags are seated causing the flags to bounce more than the algorithm can handle. This creates a false error of missing toner cartridges.
Posted on Jan 24, 2008
I GOT THE SOLUTIONNN SEND ME SOME MONEY IF U LIKE IT
U KNOW THE LENS CLEANER THAT COMES WITH THE TONERS? OPEN THE PACK USE A PIECE OF THAT PACK TO COVER THE TOP OF THE TONER MAGNET AND CHECK IT OUT
Posted on Apr 23, 2010
I watched the video replaced the sensor flags and it repaired the cyan and magenta reseat error message. However, now I getting the message for the black toner and cannot clear it. I was not having a problem with the black before. Please help.
Posted on Mar 05, 2010
So should replacing the sensor board is the best solution?
Posted on Nov 24, 2008
The "Reseat Toner Cartridge" message keeps appearing, if I open and close the lid the message goes away and it seems to print normally.
There is a firmware issue that causes that problem.
You can download it from the Xerox.com site and upgrade your machine. The instructions on doing that upgrade are also on the site.
Go to Xerox.com. Then click Suport and Drivers, then enter 7300, then to drivers and downloads and scroll down to the firmware update.
Feb 10, 2010 | Xerox Phaser 7300DN Laser Printer
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
Error message: cyan imaging unit is either missing or unseated
The problem is with the top cover assembly. It could be a few things. I would first try the toner sensor flags(the magnet may not be strong enough to read properly). Also replace the toner cartidge because it's magnet may also have gotten weak. Third, I would try the Toner sensor board.
I have had this problem with many printers and normally it is just the flags because of the weak magnets.
Feb 10, 2009 | Xerox Phaser 7400/DXF Laser Printer
False reading of toner cart status
Sounds to me like you actually have the wrong part number. There are more than one cartridge for the Xerox printers, They have different chips on them. One is for billable accounts, one or more than one for accounts that pay for prints. There also was as i remember a spring type clip they left off some cartridges.
So with what you have tried and the old cartridges work fine, strongly suspect bad carridges.
Dec 01, 2008 | Xerox Phaser 7300DN Laser Printer
Phaser 73000 wants to reseat or replace a newly installed toner. When checked toner status is unknown.
Is the Toner OEM (new from xerox) or remanufactured? Make sure that the tab that you have to push down on the toner is firmly in the locked position. Reboot the machine and see if that fixes your problem. If it doesnt put the old carridge back in see if the error persists. If it doesnt then you could have a defective toner cartridge.
Phaser 7300 Error Code/Message
Seems to be something to do with the Ram.
More help HERE
Jun 01, 2008 | Xerox Phaser 7300DN Laser Printer
Phase 7300 sensor flag error
I will give you a link. Call Britt and tell him Rick suggested you call him.
If he has the part he will make you a far better deal.
Here ya go.
https://www.partsdrop.com/store/
Apr 14, 2008 | Xerox Phaser 7300DN Laser Printer
Error message
Cause:
This message is related to the on-board SRAM on the Print Engine Control Board Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Replaced the Print Engine Control Board,
Dec 19, 2007 | Xerox Phaser 7300DN Laser Printer
Error Msg: Maintenance drawer A is missing - Phaser 8200
There is supposed to be an orange chip on the back of that tray.
If that is not present or seating properly that will cause that problem.
Pull out the green tray and see if the chip is snapped on the back ot the maintenance tray.
Oct 17, 2007 | Xerox Phaser 8200 Laser Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Xerox Phaser 7300DN Laser Printer Logo
1,642 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
