Question about ViewSonic VP191b 19" LCD Monitor
Viewsonic monitor wont say on for more than 3 seonds
  • 152 Answers
SOURCE: How do you remove the outer case on Viewsonic VG930M-3 LCD
kauffman014, As far as opening the monitor up you may want to visit YOUTUBE and search for lcd monitor repair/ disassembling monitor/ or something like that. I did see a 9-11 min video there that was fairly good on un-snapping the rear cover from the front bezel of what I think was a DELL unit. Also visit run by a jestine yong. don't pay any attention to his ad to purchase repair course in lcd/fpd servicing!! only look at the pic's of the insides of lcd monitors and the power supply boards/inverter boards. On gateway's, and dell monitors the pedestal must be unscrewed from the rear cover first. The pedestal is really screwed down to the steel FPD chassis that covers the circuit boards and provides a ridgid mounting surface for the unit as a whole. Work on a flat surface with screen facing down on a blanket or lots of newspaper to prevent maring of the FPD!
There should be some phillips screws that fasten the steel shield to the left/right sides of the FPD frame. Once you get down to looking at the Switch-Mode-Power-Supply (smps) board look for large filter capacitors (electrolytic polarized aluminum can) that have the tops of them bulging upward as compared to normal ones that are flat. You will also need to inspect the bottom (solder side) of the board where all the leads of the components from the top side are soldered. You are looking for very thin hairline 'thermal' and or 'vibration' circular FRACTURES around the leads of the larger and bulkier (heavy) components. Yeah...use a big magnifying glass or better yet a 10x or 20x inspection microscope. One last thing, I highly recomend taking digital pic's as you disassemble the unit so it can be put together again without leftover parts. hope this info helps you out. Get back to me if you find out anything. I'm louie12fix on fixya or lmistyrel@ BYE for now.
Posted on Mar 28, 2009
0 characters
1 Points
Our viewsonic monitor is VX2235WM-3 the
The short answer is no, becuase by time you pay the $50 for the backlight, and $75/hour for the tech to fix it, you can buy another 22inch for the same price and have a 5 year warrinty.
Have a nice day
Aug 29, 2011 | ViewSonic VX2235WM Monitor
Vp201b wont turn on
Checkto see if you do have 12vdc output from the power supply module as shown in my pictures:
Look for bad caps (leaking/bulging tops).
May 19, 2010 | ViewSonic VP201b 20.1" LCD Monitor
3 shaded vertical bars on monitor about 3 inches
That the sign of failed T-CON board on the LCD panel, new panel will be needed. It will get worst with more lines appear.
Apr 24, 2010 | ViewSonic VX1932wm Monitor
Viewsonic tv sound but no picture wont turn off have to unplug
For 2 years older monitor, look for bad caps with bulging tops first, post back what you see inside so we can guide you further, see example of failed VIEWSONIC with bad caps:
Feb 15, 2010 | ViewSonic VA1930WM LCD Monitor
Display on mac mini only shows no signal and turns black
his step-by-step guide describers how to obtain and install ViewSonic VA720 drivers for Mac.
1. Define your ViewSonic Monitor device model.
2. Define your operating system to install your ViewSonic Monitor device. Note: Update Drivers in Mac
3. Browse Monitor Drivers.
4. Find ViewSonic Monitor Drivers.
5. Select ViewSonic VA720.
6. Download ViewSonic VA720. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install ViewSonic VA720.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
May 03, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic vp930b-3
MY VP930b has the same problem.
It takes a very long time (5-10 minutes) before it becomes normal.
Aug 04, 2008 | ViewSonic VP920b 19" LCD Monitor
Viewsonic VA2012w Wont go into standby with computer.
turns out it may be a heating problem. cut a few extra vent holes in it and seems to be fine.
Sep 08, 2007 | ViewSonic VA2012WB Monitor
ViewSonic VP191b 19" LCD Monitor Logo
42 people viewed this question
Top ViewSonic Computer Monitors Experts
Kirk Augustin
Kirk Augustin
john h
Are you a ViewSonic Computer Monitor Expert? Answer questions, earn points and help others
