Question about Cyberhome DVR 1600 DVD Recorder
Unknown disc error
I havn't used my dvd for a while and i have loaded many different types of disc all new but the screen still says unknown disc and disc error
  • 2 more comments
  • Anonymous Feb 01, 2008
    i cant play dvd plates. Always say no dis. funny enough i can play vcd and audio plates with it.
    thanks
    Ejimogu Aloy Ifeanyi
    from Nigeria
  • aag101 Feb 17, 2008
    I also have the same problem. I can play audio disks but get unknown disc for DVD movies and when I try to record on DVD-RW. It used to work fine before.
  • chispa18 Feb 27, 2008
    When I turn on the dvd player and push the open button sometimes it will not open but states open then closed then loading, then no disc, when I can get the dvd player open it will close, then loading and then no disc no matter what dvd i put in there i have already cleaned my player, what is the problem with my player?
    chispa 18
  • rbenge Mar 21, 2009
    Almost every movie I have tried to watch within the last 3 monts gives me either unknown disc or no disc message. I have cleaned the system several times with a dvd cleaner and even getting that to load sometimes is a problem.
    Problem Solver:
  • 5 Answers
Have a electronics repair guy replace the power supply elco's.
Those are such bad quality that many errors result from them.
If you cant find anybody then contact me.
[email protected]
Ronald
Posted on Feb 21, 2008
    Sergeant:
  • 226 Answers
Get a good dvd cleaner I notice that alot of people have this problem. The optics get dirty and it won't read the dvd anymore,
some reason not play no 2 zone dvds.
Posted on Jan 24, 2008
If dvd cleaner does not work go to menu and do a system restore it worked for me
Posted on Jan 31, 2008
6ya staff
SOURCE:
Portable dvd player when you put disc in machine it comes up with wrong disc display on screen is it the settings
It would more likely be the types of discs used. They are either of a region code not compatible with the player, contain foreign/unknown data, or they are unsupported formats. For example, if the player supports DVD-R playback, and you put a DVD-RW in, the player will generate 'wrong disc' message if the player cannot recognise the disc or the contents on it.
The disc formats/types that can be played should be outlined either on the unit itself or in the instruction manual (if you still have it). If the player shows that message even with genuine shop-bought DVDs then there is a defect within the unit, workshop attention may be required to fix it, but it could be costly.
'WRONG DISC' usually means the disc inserted is of a different region code to the player, or the wrong format (DVD-RW instead of DVD-R as exampled above). Try using different discs before going any further.
May 04, 2011 | Televison & Video
My dvd player plays cds but wont play dvds says disc error or unknown disc
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load DVD's. The weak lens is also what's making it says "disc error" or "Unknown disc". It can still play Cd's because, Cd's does not contain large files, unlike DVD's.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all DVD's with no problem at all.
Good luck.
Apr 22, 2010 | LG RC897T DVD Recorder/VCR Combo
Disc not reading. toshiba dr420 dvd recorder.
Multiple problems with the DVD recorder one of them could be the lasers not reading correctly its software is messed up or there something wrong with this but to me it sounds more like the DVD recorder has a problem I've experienced this problem before not with this particular type of DVD recorder I fix the problem by unplugging the DVD player for about 20 seconds to a minute to give it a good reset.
Quick tip: most high Tech Device problems or unknown errors can be fixed by simple restart or reset hope this helps
Jul 28, 2009 | Toshiba DR420 DVD Recorder
After disc is loaded, it says "unknown disc."
Is it a pirated dvd? If it is, do you know some dvd players won't read pirated dvds? And if it isn't, then your dvd player may be dirty (the lens). For that you would have to buy a cleaning disk. You can get one at Radioshack. Or maybe what type of dvd type is it? Is it dvd-r, dvd-rw, or what? Some dvd players have trouble reading dvd-rw sometimes.
Hope this helps.
May 08, 2009 | Jwin JD-VD140 DVD Player
When loading a dvd message says unknown disc
turned out to be a problem with the scart lead!
Nov 25, 2008 | Televison & Video
Bush television & DVD error message 'unknown disk'
Some units jusy won't play certain types of recorded DVD discs. I would transfer one to a DVD+R type and see what happens. Buy a good brand like Memorex.
Hope that helps...
Geno
Mar 24, 2008 | Computers & Internet
Phillips DVDR3320V 'disc unknown' error
Hey there,
Have you tryed different types of DVDs. You might need to buy DVDs that say DVD RW.
Jan 27, 2008 | Televison & Video
Unknown Disc Message
machine might only take - dvd or + dvd only some take both types will show on front of machine just a thought
Nov 05, 2007 | Zenith ZRY-316 Video Recorder
Unknown disc error message
OKAY GUYS TRY USING THIS VERY COMPATIBLE MEDIA
(MEMOREX BRAND DVD-R) THIS WILL SOLVE A LOT OF YOUR PROBLEMS
Aug 27, 2007 | Televison & Video
Dvd "unknown disc" message coming up
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
Mar 23, 2007 | Daewoo DV-6T955B DVD Player/VCR
Cyberhome DVR 1600 DVD Recorder Logo
271 people viewed this question
Top Cyberhome Televison & Video Experts
Demonic-2011
Demonic-2011
Kahn Chaddock
Level 1 Expert
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
