Maytag washer somebody removed the bolts the motor and the belt from a maytag sav2655aww washer what are the part numbers?
    President:
  • 1,314 Answers
It really depends on where you buy them gan go here and get part numbers http://www3.sears.com/
Posted on Jan 24, 2008
How do you replace a belt on a maytag washer model # SAV2655AWW
Tip it to the back, so you can see under it
Real easy to change belts
Apr 26, 2011 | Washing Machines
I have a maytag washer, toploader which was working fine until recently. Now when it starts rotating, there is a burning smell all in the area. What causes it?
Hi
Your washer uses a belt to transfer the power to the tub from the motor. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer.
Remove the old belt & remove the bolt holding motor. Now remove the motor, remove & replace the plastic isolators with the new ones supplied with the belt on the motor spindles. After re-installing the motor & bolt adjust the new belt.
Please post back for any further assistance.
Daniel
Jul 31, 2010 | Maytag Dependable Clean Top Load Washer,...
I hear the belt floping around in my front loader washier,how do i fix it??
Get the service panel off. Then remove 4 large bolts and the washer motor and pump will come out. Put that on a work table and remove the pump.
Service Manual Amana/Speed Queen/Maytag washer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 29, 2010 | Maytag SAV5710 Top Load Washer
My neptune washer smells like rubber burning when i wash clothes
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer.
The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer. Remove the old belt & remove the bolt holding motor. Now remove the motor, remove & replace the 2 plastic isolators with the new ones supplied with the belt on the motor spindles. After re-installing the motor & bolt adjust the new belt.
Daniel
Jul 26, 2010 | Maytag Neptune MAH6500A Front Load Washer
How to replace the belt on the Maytag Neptune FAV6800AAW?
See if my Clutch Fix post will help. I also have links to Service Manual which will be big help. The drive belt can be walked on the Clutch Pulley but it is a very snug fit even with the drive belt tension bolt loosened. Watch you fingers as you walk the drive belt onto the clutch pulley….Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Trying to put belt back on magtag sav2655aww. do
Maybe this breakdown250 will help, not sure, hope so.
Nov 11, 2009 | Maytag SAV5710 Top Load Washer
MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
May 12, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer SAV2655AWW - pulley wheel replacement
WHICH PULLEY FELL OFF YOU HAVE 3 OF THEM ONE IS A "IDLER PULLEY FOR DRIVE BELT" ANOTHER IS "PLASTIC HELIX, TRANSMISSION DRIVE PULLEY" AND LASTLY IS "PULLEY FOR TRANSMISSION DRIVE" GO TO www.repairclinic.com ENTER MODEL NUMBER AND SCROLL ALL THE WAY DOWN TO THE RED 100 CLICK IT AND LOOK FOR PARTS 550204, 889619, AND 889618. YOU MAY HAVE TO WORK ON THIS FROM THE BOTTOM TO GET TO THE PULLEY. IF YOU HAVE A MECHANICALLY INCLINED FRIEND, IMPLORE HIM OR HER TO HELP YOU UNLESS YOU CAN GET THE TUB OUT AND WORK YOUR WAY DOWN
Apr 18, 2009 | Maytag SAV2655A Top Load Washer
Water leaking under washing machine
Had service technician come out to inspect. Problem determined to be the bearing and seal/belt. Estimated cost $350.00. It cost $450 when new....Went out and purchased a Speed Queen. Hope to have better luck.
Dec 29, 2008 | Maytag SAV2655A Top Load Washer
How to replace Maytag Washer belt
I have a model sav2655aww maytag washer. And it needs a new belt but I dont know how to replace it! Can the pump be removed with out removeing the motor ? Also the tub keeps going off center whats with that ?
Sep 03, 2007 | Maytag SAV5710 Top Load Washer
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
