Question about KitchenAid KGRA806PSS Gas Kitchen Range
KitchenAid Superba gas stove and oven
In the past week, I've noticed that the "Start?" query is no longer displayed on my control panel when I start the oven. In addition, I'm finding that the oven is not reaching temperature as confirmed with a separate oven thermometer, although the control panel indicates so. Also, if I have the door open for a few moments, I note that although the control panel displayed 350F at the moment I opened the door, the temperature displays drops drastically to something like 240F and starts to climb again. I hear the burners igniting and the temperature is more in line with what the separate oven thermometer reads.
I think all this started when I forgot to hit the start button once. what's up with all this? Any thought?
Tech007
  • 63 Answers
SOURCE: Oven "bake" doesn't work...
sounds like the bake glow bar needs to be replaced it is under the bottom cover inside the oven good luck
Posted on Aug 29, 2007
craigjamesbt
  • 65 Answers
SOURCE: stove burners won't ignoite
just to be clear I am assuming that you can in fact see a spark traveling from the ignitor to the metal surface over where the gas should be expelled... that being the case you must remove the the gas burner from the stove and check for damage or sign of deterioration ie: cracks, rust holes, missing sections etc. more than likely if there is no damage after 7 years of use the problem will be in the form of carbon and rust deposits inside the burner pieces or associated piping (pipe that are in the burning side of the system don't tear into the gas side) *NOTE THIS WILL NOT KEEP GAS FROM COMING OUT BUT MAY PREVENT IT FROM EXITING IN THE PROPER PLACES DESIGNED FOR LIGHTING* you can clean these carbon deposits by tipping the open end face down and tapping the burner pieces with a block of wood or similar device. These deposits should fall out as a heavy black or reddish brown dust you can also try vacuuming it and running an appropriately size drill bit through each of the burner holes to clean them as well or you can probably just purchase a new one by ordering it from the place you bought the stove
Posted on Apr 26, 2009
  • 49 Answers
SOURCE: Does Kitchenaid have a fix for this problem? Who
the hi-limit thermostat has been tripped. it needs to be replaced and also make sure that the cooling fan is working ok. thermostat is located behind the back panel. looks like a disk the size of a quarter with two wires on it
Posted on Nov 08, 2009
SOURCE: Ran Self Cleaning - Display went blank & Oven Door stayed locked
Solution #3 was very helpful. Took off the back panel and found the small black fuse. Removed the fuse and joined the two black wires, oven now turns on and oven door opens. Don't think it would be to safe to leave like this but going to get the part and put the fuse back in myself. Very easy to fix (just a million screws) so save yourself the expensive service charge!!!!
Posted on Apr 14, 2010
heatman101
  • 43501 Answers
SOURCE: KitchenAid KGRT607 - Oven won't light reliably, can smell gas.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on May 15, 2010
Clock will not reset on Kitchenaid Superba WEMS double oven - timer works, but no clock
KitchenAid KODE507ESS
(this MAY be your model??)... you did not specify?...
This link MAY have your DISPLAY PARTS:
KitchenAid Range Stove Oven Display Board
Anthony
Mar 03, 2018 | KitchenAid Ovens
How to unlock a kitchenaid superba stove
How-To Unlock A Kitchenaid Superba Oven - YouTube
? 1:24
www.youtube.com/watch?v=yKNGTVCEiuM
Sep 22, 2014 - Uploaded by Public Relations & Promotions
How-To Unlock A Kitchenaid Superba Oven ... Repair - Deadoven after self clean mode, blank display, locked door Kitchen
Sep 09, 2015 | KitchenAid Kitchen Ranges
I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
I don't have a manual. and I've been searching for it...does anyone know which one I need?
Sorry I couldn't help with your problem, mine is similar to your though!!
Jan 22, 2011 | KitchenAid KEMC308K Double Oven
The electronic display went out on my gas range so I can not start the oven. I can still use the gas burners on the stove, but without the electrical panel I can not start the oven. I checked the wire...
This is often due to loose or corroded connections in the wiring.
Unplug the range.
Open the rear of the control panel.
Remove,then re-attach all wires on the control.
If you see any terminals corroded,clean them with a pencil eraser.
If this does not correct the problem,the clock must be replaced.
Dec 18, 2010 | Frigidaire FGFB75D Gas Kitchen Range
My beep quit! Beep used to work when the oven came up to temp, the timer timed out, or a button was touched. Can it be reset or will I need to replace it? Where's the control board located and how do I...
We have a Kitchenaid Superba gas stove and the beeps would not sound. We thought the control panel was shot, but we have a WONDERFUL repair man. Here was his re-set.....open oven door, push the cancel button, push stop-time button and hold that button for about 5 seconds. When the beep sounds let go and the panel is re-set. WOW!!!!
Oct 23, 2010 | KitchenAid KGRT607 Gas Kitchen Range
My oven will not turn on. I notice the clock is not on but the burners do work. I have a kitchenaid superba oven with a glass cooktop.
You can download an electrical schematic from the kitchenaid web site. In the back of the stove, you will be able to trace the wires to find a loose connection. Be careful - make sure you disconnect the power before you start. You don't want to accidentally touch 220V.
Oct 03, 2009 | KitchenAid Ovens
Kitchenaid superba stove
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven. The Control Lock is preset off;
however, it can be enabled.
When the control is locked, only the TIMER SET/START and
TIMER CANCEL pads will function.
The Control Lock is preset unlocked, but can be locked.
Before locking, make sure the oven, the Timer and Timed Cooking
are off.
To Lock:
1.
Open the oven door.
2. Press and hold the number pad 3 CONTROL LOCK for 5
seconds.
A single tone will sound and “START?” will appear on the
display.
3. Press START. “CONTROL LOCK” and a picture of a lock will
appear on the display.
To Unlock:
1.
Open the oven door.
seconds.
A single tone will sound and “CONTROL LOCK” and a picture
of a lock will disappear from the display.
Sep 29, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
Kitchenaid Superba Gas Range
It appeared to be something to do with the plenum and cleaning - repair man came - cleansed and it was okay. MK
Jan 15, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
KitchenAid KGRA806PSS Gas Kitchen Range Logo
560 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
