Question about Sony KP-53S65 53" Rear Projection Television
Double vision what is the cause of double vision on this sony kp-53s65 53 in. television and how do you fix it?
  • 1 more comment
  • michelmark Jan 24, 2008
    Cool.. thanks for your reply but where do you buy this replacement part that you say are 10$ each and what is the exact name of these item(s) I am asking the suplier for?
    thanks. will be doing this over the weekend. I'll let you know if it works.
  • michelmark Feb 03, 2008
    Hello. I can not seem to locate the ic's since there are not just one heat sink located in this unit. Is there a specific heat sink that they are located on? Can you possibly send me a pic of the ic that I am looking for on the site you reconmended?
    You have been a big help and I appreciate all of your replies.
    If in fact I am unable to repair myself, would you possibly have any knowledge to what a tv repairman would charge for such a repair? Thanks again.
  • Sony Master
  • 8,617 Answers
Convergence ICs are bad it causes the red and/or blue to jump out of alignment making it look 3D. You have to convergence ICs located on a large aluminum heat sink with an STK number stamped on them. You can purchase new ones for about 10.00 each. they have to be soldered in. If you can solder you should easily be able to repair this yourself. Let me know if you need anything further.
Posted on Jan 24, 2008
  • Sonny Berry
    Sonny Berry Jan 24, 2008
    electronix.com just input your STK numbers off your ICs
  • Sonny Berry
    Sonny Berry Feb 03, 2008
    go to this link they have a picture of a convergence IC STK730-150 that is not your number but it will show you what yours looks like its in the second line of products on the far right side of the page sells for 3.95 your numbers are probably different but they will be identical looking to that IC.
    http://electronix.com/
  • 579 Answers
You are probably describing a convergence problem where the colors seperate. Very common on rear projection TVs.
1st - try to run the convergence feature in the on screen menu.
2nd - try resoldering the STK convergence amps
3rd - you'll have to replace the amps and any burned resistors feeding them, then readjust the convergence.
Hope Ya Fix It!
  • Greg Collins Feb 03, 2008
    They are big flat modules about 3 inches long with the pins along one
    edge and part number on the front starting with STK. I have had
    trouble with the cheap $10 knock-off modules. Get the original
    brand and many of them even have upgraded substitutes to prevent this
    common failure from reoccuring. Post you p/n and I'll find it for
    you.
    We usually charge about $400 for a convergence job.
MY TV HAS DOUBLE VISION WHAT CAN I DO TO FIX IT?
Most likely is an issue with transformers that control convergence. My old Mitsubishi had same problem twice...$300 for guy to fix first time..new set second time.
Oct 01, 2009 | Sony KP-48S75 48" Rear Projection...
Red lines, blurry picture
try this link. It fixed my sony.
www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 29, 2009 | Sony KP-51HW40 51" Rear Projection...
Double vision on a sony kp-43t90?
you likly have a convergence problem (is that a crt projection TV?)
Sep 18, 2009 | Sony KP-43T90 43" Rear Projection...
Picture is distorted, double vision, looks like 3d.lines are arched or curve. colors don't line up. screen is bowed or warped. its a sony kp- 57ws600, 57 in. rear projection television. can you help me...
Try going into the video section of your menu, and pressing RESET on your remote control. If this doesn't fix it, try your quick start guide for setting the convergence and focus.
May 17, 2009 | Sony KP-57WV600 57" Rear Projection...
Double vision in red and green
Its failure of convergence ICs and will be replaced.
Convergence ICs are mounted on silver heat-sink on D board of TV
Let me know exact model number to help you with more technical info.
Mar 21, 2009 | Sony KP-57WS500 57" Rear Projection...
Television is out of whack
Convergence chips are bad. Goto www.TvRepairKits.com to get a repair kit
Jan 20, 2009 | Sony KP-43T90 43" Rear Projection...
Double Vision....
the problem on my sony projection tv is double vision,what equipment i need and how much it is. also is it easy to fix on my own?
Mar 08, 2008 | Sony KP-51HW40 51" Rear Projection...
Double vision
replace the stk ics. they are located inside the tv with lage heat sinks. i do believe sony runs stk392-510. youll have to look at the ics to know which ones for sure.
Oct 04, 2007 | Sony KP-51HW40 51" Rear Projection...
Double vision on my samsung HDTV 1080i
Replace the convergence ICs. you will need two of them. They are located on a large aluminum heat sink with STK numbers. They cost about 10.00 each. They need to be soldered in. Its an easy repair if you can solder. Let me know if you need any additional info.
Sep 16, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
122 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
