Question about HP LaserJet 3330 All-In-One Printer
79 Error I have a 79 Error code on my HP 3330. I have unplugged it several times, for as much as 5 minutes, and replugged it, and I still received the same message. I read somewhere to "upgrade the firmware", but I don't understand what that means. A search didn't turn up anything. I appreciate your help.
  • lynnlowry Jan 24, 2008
    The download won't run. Where the section is for "Progress", it is blank and to the right is a )" (sadface)
    President:
  • 1,950 Answers
If you would like to try to update the firmware. You can download it here from HP.
Posted on Jan 24, 2008
  • Damen Wong
    Damen Wong Jan 24, 2008
    After the download, run the file to begin fixing your system.
  • 796 Answers
Here....see if u could find here something
  • isaac johny
    isaac johny Jan 24, 2008
    here is the site from wer u can get the new drivers..........
    click here
    Genius:
  • 1,067 Answers
Perform the following steps to troubleshoot the issue:
1. Remove and replace the power cord from the unit.
2. Wait approximately 35 seconds for the scanning assembly to "walk out" and then quickly remove the plug again.
3. Repeat steps 1 and 2, three to four times until the head moves approximately 1 inch away from its normal resting place.
4. Replace the plug and let the product fully finish the boot cycle
5. Please ensure that the current firmware update (20021018W) is installed. You can download and install the same from the link given below:
http://welcome.hp.com/country/us/eng/support.html
  • 2 more comments
  • Anonymous Jan 24, 2008
    Scanner bulb " --> "79" error code
    of LaserJet 3330 all in one :
    Need replace HP parts P/N: C9124-60103
    to fixed problem.
    Find HP parts -> http://hkprinterparts.com
    hey i just offered him firmware update as u can see make sure u ready post so we dount double up fixes ok otacon thx nick
    dont forgetto rate this as fix ya
    save the download link ok 1st to hard drive then run setup
6ya staff
SOURCE:
Trying to receive fax but cant
yOU DO NOT SAY WHAT FAX MACHINE YOU HAVE.
tHERES A DETAILED TROUBLESHOOTING FOR HP LaserJet 3300 Series Printers - Troubleshooting a 79 Service Error AT
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay?javax.portlet.begCacheTok=com.vignette
Feb 25, 2014 | Office Equipment & Supplies
Designjet z2100,what is System Error 79:04
I researched and found several options to fix, hope it works for you.
There are two (2) ways to fix 79 Error:
Advanced Computer User Solution (manual restore):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Error 79) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Click here follow the steps to fix error 79 and related errors.
To Fix (error 79) you need to follow the steps below:
Step 1:
Download (Error 79) Repair Tool
Step 2:
Click the "Scan" button
Step 3:
Click 'Fix All' and you're done!
Compatibility: Windows 7, Vista, XP
Download Size: 1.5MB
Requirements: 300 MHz Processor, 256 MB Ram, 22 MB HDD
79 Error Code is caused in one way or another by misconfigured system files in your windows operating system.
So, If you got 79 Error then We strongly recommend that you Download (Error 79) Repair Tool.
This article contains information that shows you how to fix your windows 79 error both (manually) and (automatically) , In addition, this article will help you troubleshoot some common error messages related to 79 error code that you may receive.
Nov 14, 2012 | HP Office Equipment & Supplies
Error 79 Power Off Power On I power off and then Power on and still receive this error. Please Help. Thanks
Printer has a firmware problem.
Go to www.hp.com
Select support and drivers.
Select your printer
Find the firmware that you need and upload it and install it.
Make sure that you follow the directions to the letter.
Dec 25, 2010 | HP LaserJet 3330 All-In-One Printer
My hp Laserjet 3330 Had error 79
Firmware error. Unplug the power cord. Wait 30 seconds. Plug it in, power it on. If the error comes back, you will have to upgrade the firmware.
May 20, 2010 | HP LaserJet 3330 All-In-One Printer
My 3330 says scanner bulb is warming up then it gives me a error 79 message no ,matter how many times i restart it
The error 79 on that machine means that the scanner assembly has failed to align/calibrate. Could be due to a bad calibration strip on the scanner glass, have you ever sprayed glass cleaner directly onto the scanner glass? If so this can stain the calibration strip and render the scanner useless. It is probably best to have the machine serviced by HP.
Feb 05, 2010 | HP LaserJet 3330 All-In-One Printer
79 error
hI
Ok try this it will some times work
A solution:
  • Unplug
  • Hold down "*" & "enter/ menu buttons"
  • While holding down both buttons, turn power on
  • Wait until something like "initialize" shows up on the display
  • Let go of buttons
  • Wait until display reads "ready"
  • Unplug for 10 seconds, then plug back in
Let us know if it works for you
All The Best: Pineworks
Jan 27, 2010 | HP LaserJet 3330 All-In-One Printer
79 error displayed power on power off and the
Hi
I can only say try it may work.
A solution:
  • Unplug
  • Let go of buttons
  • Please let me know if works for you.
  • All The Best Pineworks
Jan 11, 2010 | HP LaserJet 3330 All-In-One Printer
79 error
it is the online printer it have no on off switch off is very essaincial use a power stafe
Jul 02, 2009 | HP LaserJet 3330 All-In-One Printer
After getting error 79 won't print
A solution:
  • Unplug
  • Let go of buttons
  • Hope it works for you
Apr 24, 2009 | HP LaserJet 3330 All-In-One Printer
My hp laser jet 3030 keeps reading 79 error power on power off, pls hep with an answer
Try to perform a soft reset
1. Press MENU/ENTER.
2. Simultaneously press then release the * button and the # button to enter the Developer's
menu.
3. Press the < or > button until the message REINIT FFS appears on the second line of the
control-panel display.
4. Press MENU/ENTER.
5. The process takes approximately 2.5 minutes. During that time, the control-panel display
will change several times before returning to Ready.
6. When the Ready message appears on the control-panel display, press CANCEL to exit the
Developer's menu.
Jan 21, 2009 | HP LaserJet 3330 All-In-One Printer
HP LaserJet 3330 All-In-One Printer Logo
189 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
