Question about Canon PowerShot A80 Digital Camera
Canon A80 Autofocus
Hi friends, Can anyone help please? My A80 will not autofocus, it seems to hunt through the range but never seems to give a sharp image. Any advice would be very much appriciated. Kindest Regards. Brian. Ps. I have a strange that it has also lost the ability to get the exposure right as well.
  • Canon Master
  • 4,738 Answers
This might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Jan 26, 2008
I dropped my 70-200 2.8 canon IS lens. The lens appears finebut autofocus no longer works* What are my best options for repair? My lens is less than a year old bought new. It is also very tough to move the...
Best option for repair is CanonUSA repair service (presuming your are in USA). Your warranty will have their contact info, or you can get if from their web site. Though still under warranty, since it was dropped, I'd guess they would charge for the repair (but might be kind enough to give you a break on costs). Another possibility is a local Canon authorized repair shop, but what, and the extent, of damage may preclude anyone other than Canon's repair location from attempting any repair. Dropping it is a bummer, huh?!
Oct 10, 2010 | Canon EF 70-200mm f/2.8L IS USM Autofocus...
What is the purpose of the limit/full switch
It limits the focus range. In full, the camera will hunt from one end of the focus range to the other as it seeks to autofocus. You can limit the hunting to one end or the other if you know what you're shooting. This saves time (and battery power) by not hunting focus all over the place.
Jun 10, 2010 | Canon Sigma 105MMF2.8 EX Macro AF Lens for...
Canon ef 50mm 2.5 macro autofocus broken. Buy new or have it fixed ?? can u advice ?
I thought mine was broken but i cleaned off the copper tips on the bottom with a clean eraser very gently, and afterwards i put on the lens and it worked. I would give that a try if you have not already
May 10, 2010 | Canon Normal EF 50mm f/2.5 Compact Macro...
D90 won't autofocus at distance
Mine seems fine. The only other thing I would think to check is the focus lock is off and the focus area setting.
Apr 28, 2009 | Nikon D90 Digital Camera with 18-105mm...
Autofocus on my Canon 28-135mm f/3.5-5.6 EF IS fails
Hello. First, check the contacts on the lens mount--you're looking for bent pins, oxidized(odd-colored) metal, damaged contact points, etc. The camera must communicate reliably with the internal circuitry of the lens unit. If there is any dirt, moisture, intermittent contact going on, the sensitive focusing electronics will be effectively blinded. If all is fine with the contacts, then the problem lies with the circuits in the lens that provide critical focusing data to the camera. Movement of certain parts causes electrical changes to occur at a calibrated rate--if the camera loses connection, it can't tell if the lens is actually adjusting. You'll have to send the lens in for repair--http://www.usa.canon.com/consumer/controller?act=SupportIndexAct. This address should get you started.--Hope I helped!---Rick
Mar 19, 2009 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Autofocus not working
If you don't know how to fix it yourself send it to Sigma UK (01707 329999). They are quite resonable charges for that sort of fault. Their website give a price guide depending on lens and fault. Steve
Jan 31, 2009 | Sigma Zoom Telephoto 170-500mm f/5-6.3 APO...
When I do a close up and then back off as it gets close to the
Hi.
If the camera is in autofocus, it might be hunting focus. This usually happens when you zoom out. You can avoid this by putting your camera in manual focus while zooming out.
Hope this helps!
Nov 12, 2008 | Canon GL2 Mini DV Digital Camcorder
Autofocus jumps around and often will not settle on the correct setting
what i do is usually put it onto manual focus then back to auto focus, what it may be is that you are using the wrong lens for your subject :/
Feb 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Rebel T2 300X Won't Autofocus or Take Picture. I can manually focus and take a picture, but when autofocus is on, it focuses for a second and then goes out of focus and won't let me snap a...
This may be a problem with the autofocus itself, try the following:
  • If you have a different lens, see if the autofocus works with the other lens. If it does, there may be something wrong with your lens.
  • Clean the contacts (the little metal things between the lens and the camera) with a slightly moist, lint-free cloth
  • Try replacing the battery in the camera
If none of this helps, you may have to take your camera to a qualified repair person to get them to have a look at it.
Feb 25, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Lens stops functioning
Have you tried this same lens with other cameras? Do you have another camera body you can try? or perhaps a friend with a Canon EOS Camera? Also try the following please: Remove the lens. Look at the lens mount contacts, take a Cotton swap with some rubbing Alchol & clean the contacts very well, both on the lens and the camera body. Is your camera reading the lens aperture range correctly (at least most of the time)? Also since you replaced the PCB on the lens, isn't it under warranty? Let me know if this works. Thank you, AJ.
May 23, 2007 | Canon Zoom Telephoto EF 100-400mm...
Canon PowerShot A80 Digital Camera Logo
43 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
