FixYa.com
Tags:
GE Â 230/208 Volt Built-In Room Air Heat/Cool Unit Air Conditioner
Ge zoneline hvac
posted by ixlnfantasy on Jan 24, 2008
the fan and the compressor kicks on, and you can feel the heat forming on the unit. The blower does not seem to be blowing the heat out of the unit. Any suggestions?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 25, 2008
Not Rated (0)
edgz
Rank:Master Master
Rating: 81%, 11 votes
Pls check following......
1) If the Fan run and the Blower not function its min loose the hub or screw of the blower ,fix the hub or screw .
2) May be the the shafting of fan motor not rotate, repair the shafting or bushing of fan motor.
3) Check the Capacitor if this low capacitance or open (not function) using Multi-tester to check the parts.
4) Check the Fan motor wire if this loose connection.
if does not working,go to the nearest repairman to help the problem.
Thank you & have a nice day
Edgz
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Air Conditioners problems?
Air Conditioners
heater has stopped working, no
heater has stopped working, no... Answer This...
Air Conditioners
intertherm 3 ton ac unit
intertherm 3 ton ac unit I took... Answer This...
Air Conditioners
I wish to change the
I wish to change the set temp... Answer This...
Air Conditioners
blower runs constantly even...
blower runs constantly even... Answer This...
Air Conditioners
we have black mold in
we have black mold in our attic... Answer This...
Repair Service
Find Air Conditioner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
