Cannot access any of the USB or DVD drives
ACER Power series desktop
Anything I plug into the USB drive to read has a message say access is denied drive not accessible. DVD drive will not read discs either. But the printer still works and that uses the USB. Not sure what to do.
    Sergeant:
    Champion:
  • 317 Answers
Check under Device Manager in your PC properties, you may have "Enhanced USB" disabled.
Posted on Jan 24, 2008
WHY WONT MY STOREJET 320 GB DRIVER INSTALL. SAYS ACCESS IS DENIED ?
first check whether the device is working on another computer. if it is then there are driver issues on the computer you got this message from. if not then your casing interface is not working right. you can get the data off the hard drive by removing the casing and plugging the drive to a desktop computer.
May 09, 2014 | Transcend TS320GSJ25M2 - Storejet 25M2 320...
Pen drive access denied
USB ports and devices make connecting to another computing device convenient.
USB technology has been around since 1996, and is a feature found on most modern computing devices.
If your device is denied access to one of its USB features, do some troubleshooting to isolate and resolve the problem.
Viruses
Some computers come with a security feature that automatically denies access to a USB device, such as a flash drive, if harmful content is detected.
Installing an anti-virus software application and regularly scanning the computer and any connected USB devices can help you avoid experiencing denied access to a USB device.
Avoid opening USB flash drive files that you cannot identify or do not recognize, as these types of files are how viruses find their way onto unprotected computers.
Incompatibility
Inserting an incompatible device into your computer's USB port can also cause you to be denied access to your device's USB features.
For instance, if your computer supports USB 1.0 technology and you insert a USB 2.0 or USB 3.0 connector, the computer can experience interfacing problems that may cause a "USB access denied" prompt or situation.
If other USB devices begin to malfunction after inserting an incompatible USB cable into your computer, turning the computer off and back on again may resolve the situation.
Formatting
USB flash drives, also known as pen or thumb drives, are among the most common types of USB devices used in conjunction with computers.
Most USB flash drives are formatted using one of three types of formatting methods: FAT16, FAT32 or NTFS.
If you've formatted a USB flash drive using one method, used it on the computer and then reformatted the drive using another method, you can be denied access to the flash drive through the computer's USB port.
Wiping the flash drive clean and reformatting it again can resolve this type of problem.
Considerations
Many computer accessories, including printers and pointing devices, connect through the machine's USB ports and can interface interchangeably with multiple computing devices.
This feature increases the risks of picking up viruses and experiencing unauthorized reformatting. Limiting the amount of computers your USB devices accesses can help you avoid these situations.
Damaged USB cables can also make it impossible to access USB devices when they are connected to your computer.
USB cable damage usually occurs at the points where the cable and its connectors meet. Replace any damaged USB cables.
You have to be the computers administrator to change any values on any hard drive on your computer.
Click start control panel user accounts on the users tab click the name of the computer Administrator you must have full control.
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
http://www.webopedia.com/TERM/U/USB.html
Sep 06, 2013 | Computers & Internet
Acer Desktop USB & DVD Drive Access Denied
ok e lock is i think is a software of acer, you need to put the password of elock on your usb port, before u acess that.
Sep 08, 2009 | Acer Power 1000 PC Desktop
C drive access is denied
user login or administrator?
Aug 27, 2009 | Computers & Internet
CD/DVD drive and external harddrives via USB not acessable
I once had a problem like this. It turn out that i just forgot to plug of my external drive. because of the lack of power of the device, it wasnt functioning properly. Try to see if you have two USB plugs, or one Usb plugs with a power cable.  Re check if both of the plugs are indeed connected properly.
Feb 01, 2009 | Acer Aspire 5100 Notebook
I am unable to use cd/dvd drives & usb
log in as administrator und use the user management control in control panel to enable your account to a power user
Oct 01, 2008 | Acer Aspire™ T180 PC Desktop
Acer E-lock program
It depends on the version of the program but just try
start -> run (or hold the windows key and then press r)
type in services.msc
in services listing find the acer service, right click, disable
the startup mode and stop it. restart the pc. You may need to
give the dvd drive or usb drive a new letter from the computer
management. but, unplug the usb devices, and after restart
just plug them back in.
Thanks,
Ekse
Sep 25, 2008 | Acer Aspire™ T180 PC Desktop
Pen drive:access problem
There should be a lock and unlock button on the pen drive itself make sure it is in the unlock position.
Keep me posted.
Thanks,
Lee
Jun 21, 2008 | Computers & Internet
Dvd drive not writing
bluetooth have a problem acer aspire 3680 xp
Apr 21, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
194 people viewed this question
David Payne
David Payne
