Question about Kenmore 46462 Front Load Washer
Kenmore front load washer he2plus
Washer show full time of (28) minutes but only wash for (7)minutes
  • robert samples May 11, 2010
    what happens after the 7 minutes
The machine has to be level
Posted on Jan 29, 2008
My HE2 Plus vibrates terrible. Moves all over the place. Anyone else with this problem
Posted on Jan 25, 2008
We are seeing F24 for the first time today on our Kenmore HE2plus front loading washer. What does it mean? How do I solve it?
Hi
F24 is a water temperature sensor error. You have to unplug the washer and check the water temperature sensor and its connections, if that is fine then check the resistance of the heating element and the part that is bad should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2plus Front loading/ model 4754. Full of rinse water. Will not eject the water. Flashing an F-21 error. What is the F-21 problem,
Welcome to FixYa.
Try this link of my solution for this issue...it is very common.
http://www.fixya.com/support/t7367730-f_21_error_displayed
Let me know how it goes and if you require further assistance.
Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today.
Good luck.
Regards,
Macmarkus :)
Jan 07, 2011 | Kenmore HE2 Plus Front Load Washer
F21 error on kenmore he2plus washmachine. Door locks. Due to no spinning and water remaining in the machine? I run the rinse/drain&spin program (15 minutes) several times. it stays at 15min remaining...
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 23, 2010 | Kenmore HE2 Plus Front Load Washer
Error codes
Kenmre HE2 Plus front loader has a F 28 error. Whats the problem and how do I fix it?
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore front load washer (HE2Plus)
check to see if you still have a warranty on the washer other than that check the inner door seal if worn or crimped try to fix or replace it
Dec 16, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore (HE2PLUS) front-loading washer leaking out the front door,,,,,,,,C. Pellecer
check the inner door seal it may be damaged that may be why it is leaking
What is code f21 on kenmore he2plus washer and how do i fix it
It means you have a drain problem. It could be a pressure switch or the drain filter plugged.
Jul 14, 2009 | Kenmore HE2 Plus Front Load Washer
F 01 code won't come off, washer won't start
you have to buy a new ccu unit in sears if you dont have warranty the cost is betwen 175 to 200 $$
Aug 12, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 46462 Front Load Washer Logo
108 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
