Question about Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ...
Not able to receive a fax
How do I set up my fax machine to answer?
SOURCE: cannot recieve faxes
I just spoke with customer service live chat.
-press the "Fax Mode" button
-press the menu button
-The Fax menu screen will be displayed
-press down arrow button 5 times until the screen displays "Ringing and Answering."
-press the select button
-the display will show the "Ringing and Answering menu
-press down arrow button 4 times untip "Pick-up On?" is highlighted
-press the right arrow button 2 times until the screen displays "1st ring"
-press the "select" button and now "1st ring" will be set as the default.
Posted on Dec 28, 2007
SOURCE: Lexmark x215 printer/fax/scanner
I have an X215 also. It is not built to suit a duo line hence no fix is available.
Posted on May 23, 2008
juanesquiz
  • 5 Answers
SOURCE: Receiving Fax using a phone line with voicemail on a Lexmark 5470
well, your voicemail can configure to key tone?? or have some one configuring options????
Posted on Nov 26, 2008
  • 2692 Answers
SOURCE: how do i receive a fax?
Here is the link for your Manual for instructions. .
http://www.lexmark.com/publications/pdfs/2007/5300/en.html
Posted on Mar 09, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: Hi i can't send and receive faxes. My phone
    Here's the link to download the Lexmark X7170 User's Guide: http://bit.ly/c8EHEn. Go to Faxing for the instructions on how to go through the settings on the printer. For setting the printer to ring to answer at 0, set it to pickup on the 1st ring. To turn off the distinctive ring, set the ring pattern to any. Hope this helps.
    Posted on Jul 20, 2010
    How to set the tax
    First, to make sure it will work, your fax machine should be going directly to the phone jack, with the answering mach/phone (if any) going to the ext port in the back of the fax machine. That way, the fax machine can "eavesdrop" for any fax tones for every call. If you want to use the fax machine to work with an answering machine on the same line, make sure to set the answering machine to 2 rings lower than the fax machine. Let's say, you have the answering machine set to 4 rings, your fax machine then should have 6 rings. You can set the number of rings for your fax machine under "basic fax setup" of the "menu". Otherwise, you can set the fax machine to auto answer by pressing the auto answer button.
    Apr 04, 2011 | Office Equipment & Supplies
    THE FAX ANSWERS BEFORE THE ANSWERING MACHINE. ALL ALONG THE FAX WOULD ANSWER FAXES AND THE ANSWERING MACHINE WOULD ANSWER CALLS. NOW THE FAX ANSWERS ALL CALLS. ON FOUR RINGS. WHAT SETTINGS DO I HAVE TO SET...
    You have to set the fax to at least one more ring than the answer machine. When the phone rings the fax wakes up and listens after the answer machine picks up, if it hears a fax it will take over and print the fax.
    Jan 13, 2010 | HP PSC 2210 All-In-One InkJet Printer
    IT WILL RING BUT GOES TO ANSWERING MACHINE DOES NOT RECEIVE FAX
    >first run fax test, press set up go to tools menu then select run fax test,all entries should be pass
    >then check your connections, do you have one line or number for your fax and phone?or a separate line or another number for fax and another number for phone?
    >let me assume you only have one number for fax and phone..
    >check connections, this should be downstream connection, the fax machine using the black phone cord provided by hp should be connected directly to the phone jack using line 1 at the back of the fax and the answering machine or the telephone should be connected to ext 2 or line 2 at the back of the fax...there should be no other devices phone or answering machine connected directly to the phone jack.
    >next set rings to answer on the fax machine higher than the answering machine...if your rings to answer on answering machine is 4 rings, set the fax to 6 rings...if it is a voice call the answering machine will pick it up at 4 rings then if it detects that it it a fax tone then it will transfer the call to fax.
    >also check if auto answer is on in your fax
    >you can check auto answer and rings to answer by pressing set up or menu button on your machine look for it in basic fax settings or advance settings
    >also check if your voice prompt for your answering machine is not too short there should be like at least 5 seconds after cutting your message to allow the machine to transfer the call to the fax if it is a fax tone.
    Sep 14, 2009 | HP 1040 Plain Paper Inkjet Fax
    How to set hp1040 fax to work with aout answering
    If you are using the same phone line as your fax, you can start by connecting the answering machine on Line2 or 2-Ext at the back of the fax. Set the fax to answer on two rings higher than the Answering Machine. (for example: if answering maching is 4 rings, fax is 6 rings)
    And then, turn on the auto answer.
    Mar 22, 2009 | HP 1040 Plain Paper Inkjet Fax
    Can I use as phone/answering machine and fax
    no, this machine does not have a message center. the only way is to hook an actual answering machine up to the "ext" jack on your fax. set fax to answer on 1-2 rings, and set your answering machine to answer on at least 4 rings, and set your fax receive mode to "tad" which means telephone answering device.
    razors
    Feb 09, 2009 | Brother IntelliFAX 4100 Laser Fax
    Not receiving any faxes but sending
    Note: check your equipment for:
    Fax machine must be connected to an answer machine
    Receiving a fax automatically:
    1 Make sure the Fax Auto Answer light is on.
    2 To set the number of telephone rings before the printer automatically receives faxes,
    Receiving a fax with an answering machine
    When a telephone ring is detected, the answering machine picks up the call.
    If the printer detects a fax, it receives the fax and disconnects the answering machine.
    If the printer does not detect a fax, the answering machine receives the call.
    2 Set the answering machine to answer incoming calls before the printer does.
    For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls
    after five rings.
    3 To set the number of telephone rings before the printer automatically receives faxes.
    Oct 31, 2008 | Lexmark X5470 All-In-One InkJet Printer
    I can't figure out how to set up my fax machine so it won't mess up my phone and answering machine either.
    Telephone wire goes to fax, out to answer machine, Important to set fax on answer machine mode and set the ring count to pick up AFTER the telephone answer machine. Set fax ring count to 5 rings, and answering machine to 3 or 4. When some one calls answer machine or you pick up first, then if no one will leave a msg. fax tones are different than voice tones, they are called CNG tones. Most new fax machine will sense this and if a fax will go to fax only. Ring count is the key. Also you could set fax up for maual mode and would not jump to anser machine or fax till you want.....good luck
    Aug 28, 2008 | Office Equipment & Supplies
    How do I set up my X7170 to receive a FAX?
    Link
    Receiving a fax You can choose to receive a fax automatically, manually, or through an answering machine.
    Note: For your All-In-One to receive a color fax, the machine from which you are receiving must also support color faxes.
    Automatically Recommended for a dedicated fax line
    Your All-In-One automatically accepts incoming faxes using the automatic answering mode. When the Auto Answer light is on, the All-In-One receives a fax after the specified number of rings set in the Options menu.
    To set a number of rings for the automatic answering mode:
    1. On the control panel, press Mode repeatedly until Fax is selected.
    2. Press Options until ANSWER FAX WHEN appears.
    3. Press + to choose After 1 ring, After 2 rings, After 3 rings (default), or After 5 rings.
    4. Press Select.
    5. Make sure the Auto Answer light on the All-In-One is on.
    When the number of rings that you set is detected, the All-In-One automatically receives your fax.
    Manually Recommended for a shared fax and telephone line
    You can choose which incoming faxes to accept by setting your All-In-One to manual answering mode.
    1. Make sure the All-In-One Auto Answer light is off.
    2. Press *9* on the telephone after you answer the telephone and hear fax tones.
    3. Hang up the telephone.
    The All-In-One receives your fax.
    Answering machine Recommended for a shared fax and telephone line
    To receive a fax with an answering machine connected to your All-In-One, set the answering machine to answer incoming calls before the All-In-One does. For example, if you set the answering machine to answer calls after 3 rings, set the All-In-One to answer calls after 5 rings.
    3. Press + until After 5 rings appears.
    4. Press Select.
    When a ring is detected, the answering machine picks up the call.
    • If a fax is detected, the All-In-One receives the fax and disconnects the answering machine.
    • If not, the answering machine completes the call.
    Note: You must set up the equipment as shown in connecting to an answering machine.
    May 21, 2008 | Lexmark X7170 All-In-One InkJet Printer
    Fax answer machine
    FAX RECEPTION THROUGH AN ANSWERING MACHINE:
    This mode is recommended for a shared fax and telephone line.
    To receive a fax if your All-In-One is connected to an answering machine:
    On the control panel, press Fax.
    Set the answering machine to answer incoming calls before the All-In-One does. For example, if you have set the answering machine to answer calls after 3 rings, set the All-In-One to answer calls after 5 rings.
    To change this setting on the All-In-One:
    Press Options until Number of rings appears.
    Press the right arrow (+) until After 5 rings appears.
    Press Select.
    Make sure the Auto Answer light on the All-In-One is on. When a ring is detected, the answering machine picks up the call.
    If a fax is detected, the All-In-One receives the fax, and disconnects the answering machine.
    If a fax is not detected, the answering machine completes the call.
    Feb 18, 2008 | Lexmark X4270 All-In-One InkJet Printer
    How to set Ans/Fax receiving mode of SCX-4521F?
    Try setting the receive mode to FAX/ANS. If you want the fax not to pickup before a phone call comes in, you should set the number of fax rings to a higher number, like "5" for instance. Set the answering machine rings less and the fax higher. The machine will usually record a message first and then detect a fax tone.
    Jan 24, 2008 | Samsung SCX 4521F All-In-One Laser Printer
    Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ... Logo
    176 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
